Question about Magic Chef CMV1000B Microwave Oven
Magic Chef mco153ubf
Bulbs underneath burnt out and when turning on microwave it just hums .Changed the bulbs and still get the same results. Everthing else seems to work.
I had the same problem. My Magic Chef, MCO153UBF Microwave had similar problems. The Magnatron, Cooling fan, Turn table and under hood lights were not working at all after hearing a pop sound under the control panel. Thought it was the fuse but the fuse was fine after testing and replacing. I checked the circuit breaker wired to my house and saw it had a break to my kitchen outlets so i flipped the switch to get back the kitchen outlets. Then I checked the microwaves Control Panel ( Printed Circuit Board) underneath and saw to traces were burnt. I soldered the two trace lines and the fixed the problem.
Posted on Feb 17, 2008
  • Magic Chef Master
  • 9,098 Answers
We see this a lot. The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya:
Posted on Nov 22, 2007
How do I change the light bulb in a magic chef microwave?
  1. Unplug the Magic Chef microwave from the wall outlet.
  2. Remove the screw from the light cover located on the left side of the underside of the microwave. ...
  3. Unscrew the light bulb, then screw in the new light bulb.
  4. Raise the light cover, then secure the cover with the screw that was originally removed.
More items...
How to Replace a Magic Chef Microwave Light Bulb ' Hunker How do change the light bulb in magic chef microwave Google Search
Oct 24, 2017 | Magic Chef Microwave Ovens
Magic Chef MCO153UBF microwave
There are two things that come to mind, the magnetron is starting to fail, or the strapping has come loose on the fan motor housing, unplug microwave oven and remove top, [several screws] carefully inspect the fan for any loose mounts and tighten.
Jun 09, 2012 | Magic Chef Microwave Ovens
Where can I get a light bulb and base for Magic Chef microwave model #MCP13E1ST?
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Just take the old one with you.
Dec 06, 2009 | Magic Chef MCD1311ST Microwave Oven
Magic Chef MCO153UWF
Tin foil or steel plates in a microwave will burn it out. I suspect it is or has burnt out. Never put anything steel in a microwave.
Mar 12, 2017 | Magic Microwave Ovens
Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 11, 2008 | Magic Chef MCD1311ST Microwave Oven
Magic Chef Over the Range, MicroOven, model MCO153UBF
I tried the usual things, then checked the outlet in the cupboard where the unit is plugged in.....It was okay, but then I noticed a separate electrical cable going into the wall at the outlet. I went to the breaker box downstairs, found a breaker marked "Microwave Oven", flicked it off and on and away the microwave oven went....It is now okay. I guess the thermostat had turned everything off when it became too hot....
anyway all okay now....thx Janet
Jul 22, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave would not turn on
Sounds like the control board is bad.
Sep 24, 2007 | Magic Chef MCD1311ST Microwave Oven
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Magic Chef CMV1000B Microwave Oven Logo
401 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
