Question about Dishwashers
SDW85 Hotpoint dishwasher is flashing the code ALO8 - help!!!
My SDW85 Hotpoint dishwasher is flashing the code AL08. Does anyone know what this means and how we can fix it? Thanks
SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Posted on Feb 23, 2008
SOURCE: Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Posted on Feb 24, 2009
SOURCE: Hotpoint FDW 85 Dishwasher
You just need to switch the machine off for approx 30 seconds from the mains and switch it back on again!!
AL99 means that there is a communication error within the machines software.
Posted on Jun 16, 2008
SOURCE: SDW60 - AL08 Error - No Hot Water
Hi fridge-1,
I had the same problem and fixed it by fitting a new control board .
Best of luck.
michael-howe
Posted on May 16, 2009
SOURCE: Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Posted on Jan 12, 2010
I have an hotpoint sdw60 dish washer that is flashing 2 yellow lights, these are numbers 5 and 7 (fast and dry 40c) and (delicate 50c) can anybody tell me what this means.thankyou
Hotpoint Indesit dishwasher flashing lights fault error codes ...
? 15:08
www.youtube.com/watch?v=FRLbrBPHcnE
May 3, 2015 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/hotpoint-aquarius-fdm-dishwasher-flashing-lights-and-there-fault-codes ...
Oct 02, 2015 | Hotpoint Dishwashers
Dishwasher not doing anything
hi does anyone know what error A06 for the Hotpoint Aquarius FDW70 means and if it can easily be fixed
Jun 13, 2013 | Dishwashers
Hi I have a Hotpoint fdw80 witch is displaying an error code AL10. Please can you tell me what this means so I can decide a course of action. Many Thank's Amanda
I found these error codes for the hotpoint fdw80
AL01 - Anti flood switch operated
AL02 - Valve or connections
AL03 - Time out - drain
AL04 - Thermistor (module)
AL05 - Circulation pump
AL06 - Time out - fill
AL07 - Not used
AL08 - Time out - heat
AL09 - Software recogntion error
AL10 - Heating circuit
AL99 - Communications error - connectors, cables etc.
H20 - Time out - fill (taps)
Now looking at AL10 error. Most often it is the heater element which is not effective due to scale formation. Make a solution of white vinegar and water (50:50) pour it onto the base of the dishwasher. Leave overnight and run dishwasher as normal. Somehow the vineger has to reach the heating element which is an inline heater. I am assuming normally you would use the hotwater connection from the kitchen tap.
If this does not help - depends how soon into the cycle you get the error you will have to replace the heater. I think it would look like this.
Feb 01, 2011 | Dishwashers
First switch off the machine and unplug it at the mains. Leave for 10 minutes then plug back in and re set your machine to the programme you want. It might be that the control panel needs re-booting. They are a bit sensitive and mine had a mind of its own, washed to its own agenda, left water in the bottom etc etc. so that might be the problem with yours. If that doesnt do it, go on the Hotpoint website and find the customer service number. Ask if there is anything you can do to solve the problem yourself before paying for a service call. It could be your heating element has packed up but try the easy fix first. Thats what I did and it cost just the price of a phone call. They were really helpful.
May 29, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hi fridge-1,
Best of luck.
michael-howe
May 03, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Al03 flashing on display on hotpoint ultima sdw85
Disconnect the power from the dishwasher completely for at least three minutes, it should reset.
This can happen after a lightning storm.
Sep 28, 2008 | Hotpoint Dishwashers
DISHWASHER
www.hotpointservice.co.uk has the fault codes and what they mean!
Sep 23, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Jun 15, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Diplomat dishwasher keeps flashing E2 anyone know what this means
dishwasher starts then goes to prewaash and beeps.When opened it flashes f2.
Dec 27, 2007 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Dishwashers Logo
187 people viewed this question
Top Dishwashers Experts
