It is a 13 year old phone so it may just be worn out. You can try a hard reset but it may be the display that has failed. The vibration is telling you that it is booting up. First try removing the battery for 5 minutes and put it back in.
HardReset.info: At the very beginning hold down the Power key in order to switch off the cell phone.
HardReset.info: In this step press and hold the Volume Down + Power button for a few seconds.
HardReset.info: You should release held keys when the Recovery Mode starts.
HardReset.info: Afterwards press Volume Down a few timies to highlight "wipe data/factory reset", and then push the Power button to confirm this option.
HardReset.info:
Next, select "Yes--delete all user data". Use Volume buttons to scroll and Power rocker to select.
HardReset.info: When the Recovery Menu appears once more on the screen, choose "reboot system now".
https://www.hardreset.info > devices > nokia-x2-02
Power button to turn on device. Remove Screen Lock on NOKIA X2-02 · First step is to open phone's Dialer or go to Standby screen. · Then tap this code using ...
Make sure that your device is on. · Next press and hold * key + 3 key + Call button + Power button. HardReset NOKIA 2680 slide · Release holded buttons, when ...
On the main screen type: *#06# for checking the IMEI (International Mobile Equipment Identity). *#7780# reset to factory settings. *#67705646# This ...
How to Hard Reset Nokia 2680 slide · Press and Hold * key + 3 key + Call button + Power button until you see logo Nokia. · Then release all hold buttons. · It will ask ...
Switch on the cell phone. Factory Reset NOKIA 3220 · Now goto Menu -> Settings -> Restore Factory Settings. · Then please enter your security code. * The default ...
Missing: c- ' Must include: c-
How to Hard Reset Nokia 3220 · Press and Hold * key + 3 key + Call button + Power button until you see logo Nokia. · Then release all hold buttons. · It will ask ...
Missing: 2 ' Must include: 2
HardReset: Make sure that your device is on.
HardReset.info: Next press and hold * key + 3 key + Call button + Power button until you see logo Nokia.
HardReset.info: Now enter your lock code.
* The default lock code is 12345
HardReset.info: Then your phone will reset and restart.
Hi There,
Assuming you are locked out of your phone, follow the steps in the link below to reset your phone. Beware though, your data will be lost/deleted by doing this. Hopefully you had your phone setup to sync your data to your google account, if you had then most or all your data will be restored once you sign back into your google account. Also you will need the google account details the phone was setup with in order to complete the restore. The only way you will not need this information is if the phone was not setup/linked to a google account. Hope this helps. https://www.hardreset.info/devices/samsung/samsung-j100f-galaxy-j1/hardreset/first-method
