Question about AudioBahn A8001DT Car Audio Amplifier
How can i get this amp out of protection mode?
I have an Audio Bahn A8001D amp that won't work. How can i get this amp out of protection mode? And do i need all 3 fuses in amp for it to run?
    Novelist:
  • 123 Answers
You have a short circuit. I don`t know this particular piece of equipment but you should check all the output transistors/chips. Try disconnecting ALL the supplies to ALL the output devices and switch on, It should fire up, If it does, reconnect the positive AND negative supplies to one channel. If it still fires up, reconnect the next channel until you find the faulty channel then you could try doing comparison checks between the bad channel one of the good ones. These amps tend to use MOSFETS and are extremely intolerant to bad or loose connections. I hope this helps. You`ll probably find that you`ve got poor wiring, That will be your original fault. Ensure you make ALL connections good and sound before reconnecting the amp up with new devices in or you WILL be back at square one with no amp again. Ian
Posted on Jul 19, 2009
Kenwood kac 628 red light comes on and no audio output
The red light you describe on your amp, is the protection mode warning light. An amp goes into protect for many reasons. Here's a checklist.
1st check the fuse (s) on your amp and make sure they are not blown.
2nd check the inline fuse next to your car battery (if you have an inline fuse)
3rd, disconnect the speaker wires with amp on, does the light go off?
4th check your ground, this may be ok if you have tried another amp with the same wires.
5th.if none of these turns the protect mode off, it may be an internal fault.
you may have blown transistors and it is a tricky job to repair and costly.
Jan 28, 2013 | Kenwood KAC-628 Car Audio Amplifier
My reciever went to protect mode after my speaker wires touched. I removed all cables and power for an hour but stays in protect mode. I also changed 2 15 amp fuses inside but nothing unless I take fuses...
Yes, you can do this easily.
Perform the following steps
(1)Plug your amp to AC outlet.
(2)Switch it on.
(3)observe time taken for switching off.
(4)immediate to shut down over current protect(5)3 seconds to shut down DC protect.
If over-current protect do the
following steps
(O)unplug the amp.
(1)download NR806 service manual.
(2)open the amp metal cover.
(3)measure 7 large white resistors resistance loacated next to power transistors mounted on a large heat sink with black probe touching the middle pin and red probe to first/left or third/right pin.
(4)If this 3 Pins large white colour 0.22ohm x 2 resistor is open with infinity ohms ,
(5)replace it and jot down this channel for example left surround faulty. Usually only 1 channel went faulty.
(6)the two large power transistors next to this white resistor 0.22 ohms x2 should also be replaced.
(7)plug the amp
(8)switch it on
(9)if ok, troubleshooting get done
(10)if not ok
(11)replace ALL the components of this power amp channel.
(12)pre-amp section no need to check.
Nov 23, 2017 | Onkyo TX-SR806 Receiver
How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
May 07, 2010 | Onkyo TX-SR605 Receiver
Wire diagram for audio bahn AWIS12P
they are so many ways to run a dvc sub, let me know what ohms the coils are, and i will give you the ultimate bass that will hurt your hearing.
Feb 04, 2010 | Jl Audio DWC254 Mb Quart 10 Auto Bahn Car...
Audio bahn a 1800
If it has cooled down and still goes into protect mode, it likely has shorted output transistors. To eliminate other possible causes, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 23, 2008 | AudioBahn A8001DT Car Audio Amplifier
Crunch GP 3000 D Pro
It's very likely that the output transistors have failed in the amp. They will need to be replaced.
Jun 14, 2008 | Crunch Drive V-600 Car Audio Amplifier
DAB2204
try turning down the volume level on the power amp.
And see if that works.
Dec 27, 2007 | Digital Audio 840 WATTS 2, CHANNEL HIGH...
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
My amp plys in burst
Make sure you have the correct speaker load.  Try one channel and one speaker (4 ohm single voice coil) at a time and see if there is one channel that is the problem.  See if it will stay on with no speakers attached.
Oct 24, 2007 | AudioBahn A8001DT Car Audio Amplifier
Amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Jan 01, 2007 | Soundstream XTA880.2 Car Audio Amplifier
AudioBahn A8001DT Car Audio Amplifier Logo
123 people viewed this question
Top AudioBahn Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jerry Naidoo
Robert Rankin
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
