Question about Williams Sport & Outdoor - Others
Efi code ec 99 flashes on my 2007 arctic cat atv. what does this mean and how do i fix it.
zr800o1le
  • 19 Answers
SOURCE: 2006 Arctic Cat ATV dies after about 15 minutes of riding
It Sounds like your Stator is going bad.
I would have it checked/Diagnosed by a Local Shop.
Posted on May 12, 2009
  • 29 Answers
SOURCE: I have a 2009 arctic cat 250 atv. It has started
HELLO; It sounds like you need to reajust the linkage DAVE, now if this quad is that new call the dealer and ask for a tip from them. GOOD LUCK....GREASY
Posted on Oct 02, 2009
  • 32 Answers
SOURCE: '06 Arctic Cat 250 DVX and the radiator fan won't run
are you getting power to the fan?if you are then this means the fan is bad.to test for power un plug the conector to the fan,start the machine and get it up to temp.take your wire tester 12 volt and see if it has power.if it does then the fan is faulty.if it dont then there is a bad wire you will need to chase it down with your tester.good luck.
Posted on Nov 04, 2009
SOURCE: 1995 ZR580 EFI Arctic Cat power loss
I have a 1995 artic cat zr580 efi oi only gets up to 70 mph it has nep plugs, new drive belt gas filter and a brand new battery I took it upstate new york (old forge) was left behind by my riding buddies I hear that there is a chip for the EFI that wears out is this true
Tony
Posted on Dec 31, 2009
nova2nv
  • 197 Answers
SOURCE: need to replace my stator on 99 zr arctic cat
Remove rewind then flywheel.Lower rewind housing bolt may be a little tough to get out being its on the bottom.Flywheel needs to removed with standard 3-bolt puller and may make a load pop when comes loose.Housing around stator needs to be removed,4 allen bolts hold this in place.Do not install flywheel until stator housing is bolted back in place.After you removed everything be sure to check and see if hood harness was routed under rewind housing because in the past a few had the wires smashed from engine pinching wires between stator housing and main frame.Best place to buy stator from is Dennis Kirk,$213,just did one on my 99 ZL600.
Posted on Jan 16, 2010
Testimonial: "thanx for the advice.Happy trails"
Arctic cat 500 auto
Hi Robert, Seems like your fuel pump is on it's way out, There's three links below, The 1st link is a youtube video showing how to test and fix a ( CAR ) fuel pump, The 2nd youtube video is a guy fix/clean an Arctic Cat EFI fuel pump and the 3rd is a youtube video of a 1998 Arctic Cat ZL 500 fuel pump...I hope they help....CHEER.
Fixing Car That Shuts Off Randomly
Arctic Cat EFI Fuel Pump Fix Clean Not Replacement
1998 Arctic Cat ZL 500 Fuel Pump
Apr 02, 2016 | ATVs
The starter engages and starts the motor fine when the motor is cold. however if you ride and try to restart the starter just spins and you can only start using the kick stater.
"ATV" service and repair manuals - CRXSi.Com
www.crxsi.com/reference/manuals/atv/
.. arctic cat 400 4x4 engine · 04 arctic cat 4x4 400 4 wheeler manual trans startergears ... 2000 2x4 red atv artic cat repair manual · 2000 300 arctic 4 wheeler instructions .... 2007 arctic cat 90 c c four wheeler wiring diagrams · 2007 arctic cat 90four .... Atv Arctic Cat 2010 - Arctic Cat Dvx 300 And 300 Utility Service Manual ...
Aug 12, 2015 | Arctic Cat 2007 90 DVX 2x4
How do the wires attach to the battery terminals on a '09 550 H1 Arctic cat ATV
Here is the service manual for your machine where you can see how the terminals are connected. http://www.mymowerparts.com/pdf/Arctic-Cat-ATV-Repair-and-Service-Manuals/
Mar 04, 2015 | Arctic Cat 2009 550 H1 EFI 4x4
Where is the alternator located on my 2008 arctic cat 700 efi automatic atv
probably has a stator and it'd be on the crank opposite side of the transmission
Jan 11, 2015 | Arctic Cat 2008 700 H1 EFI 4x4 Automatic...
Arctic Cat 2007 700 EFI won't crank over
Weak battery, bad starter. burnt fuse. here are the service manuals for all Arctic cat ATVs
Parts House Lawn Mower Parts and Chain Saw Trimmer Parts
Aug 31, 2013 | Arctic Cat 2007 700 EFI 4x4 Automatic
My 2007 arctic cat starts slow and hard. new battery. no help
If your engine is starting slow and the battery is good, your starter may be on its way out. Remove it and bench test it, or while starting if it becomes hot to the touch, it may be time to replace
Aug 25, 2013 | Arctic Cat 2007 700 EFI 4x4 Automatic LE
Sport & Outdoor - Others Logo
194 people viewed this question
Top Williams Sport & Outdoor - Others Experts
Are you a Williams Sport and Outdoor - Other Expert? Answer questions, earn points and help others
