Question about Panasonic Palmcorder PV-DV203 Mini DV Digital Camcorder
Same dew dection problem with no help from Panasonic
For what ever is worht I have the same problem and Panasonic will not offer any help unless I send the item for repair at my own expence.
Stupid as it may sound, After much investigation and navigation, dissasambling, cleaning and unsuccesful attempts. Dew detected message kept coming on . Found a solution that worked for my and many others apparently.
Remove the battery, take the cam firmly and hit it with the palm of your hand exactly bellow de base of the battery seat (lower BACK side OF THE CAM,) TWICE or three times. Hit it hard, Put the battery back on, turn it on and it shoukld work like magic. Try it, I thought the same thing you are thinking now when I read this. please go ahead an try it good luck
Posted on Aug 26, 2009
  • crispbilly Nov 15, 2010
    IT WORKED !!!!!!!!!!!!!!!!
  • furnasp Apr 19, 2011
    i hit it till my palm bleed, still.... nothing
Thanks Marcelo_vice. That wirked great.
Posted on Jan 17, 2010
I have a Panasonic NV-GS 35 digiatl video camera. 'Dew Indicator' error is coming . How can I remove this problem??
hi,dew means you got humidity level to high inside the camera
,press eject,removed the battery and try to use an air dryer an blow air inside the mechanism
thats where the dew sensor is located , for few minutes the let it cool down in a dry place
thats should reset the sensor system, if its not work that mean you will have to
replace the dew sensor.
hope that will help you,thats all i can do from here.
regards Alan.
Dec 25, 2010 | Panasonic NV-GS35 Mini DV Digital...
Get "DEW DETECTED" warning on screen, powers off.
Also try this, take the bottom cabinet off, with the lcd panel facing you and the camera turned upside down and the cassette housing pointing away from you you will see 2 wide gold cables plugged into the right side of the board, realitively the same size, the gold cable that is between the main pcb and the mechanism assy is the control cable pull it our of the connector and clean it with alcohol, you can even take it one step further and evenly trim just a hair of the cable off all the way across just so that it has a new place to set. This has worked for me over 100 times in the past years. Seasoned camcorder technician 13 years experience.
chrisveal@msn.com
Aug 13, 2009 | Panasonic PV-DV103 Mini DV Digital...
My palmcorder keeps saying dew detector
To find this information you will have to either go to the Panasonic customer support website and enter your palmcorder model number and check out the frequently asked questions to see if they have already asked this question and have a answer in the form. the website is (http://www.panasonic.com). you can call the customer support telephone number at 1-800-211-7262. Between the hours of 9am-7pm EST. You can also use the customer support e-mail at www.consumerproducts@panasonic.com Give them the Brand name and model number of the palmcorder. Tell them the problem you are having with dew dector and ask the for assistance. I Hope this information helps you with your palmcorder problem.
Mar 21, 2009 | Quasar VM-D51 Camcorder
Dew warning on Panasonic NV-DS29B Mini DV
I had the same problem, and solved it by having the heads cleaned.
Aug 27, 2008 | Panasonic NV-DS29B Mini DV Digital...
Fix Dew Detect for Panasonic 700X
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
May 15, 2008 | Panasonic PV-GS300 Mini DV Digital...
Warning Dew Detected
Where are you keeping that camera? I would return this camera if it keeps happening (before warranty expire).
May 14, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Dew detected
This may sound stupid, but it worked for me.
Turn your camera on. When you get the dew detected warning, take your battery off and just hit the spot where your battery was a few times with your palm, not too hard, but not really soft. Put the battery back on and it should be fixed unless you actually do have a dew problem!
If that doesn't work, try drying it out with a hair dryer.
Dec 28, 2007 | Panasonic PV-L680 VHS-C Analog Camcorder
DEW indicator / battery
In your owners manual on page 52 you will find a list of authorized service centers. Give the one in your area a call. Give them the brand name and model number of the camcorder. Tell them you are having a problem with the dew warning coming on while using the camera with the battery. They should be able to help find a answer to this problem.You can also call the panasonic customer support telephone number at 1-800-211-7262 between the hours of 9am-7pm EST. Give them the brand name and model number of the camcorder and ask them for help with the problem of dew indicator coming on while in use with the battery. I hope this information helps you with your camcorder problem.
Nov 20, 2007 | Quasar VM-L450 Camcorder
HELP, my panasonic keeps shutting off. Dew? condensation?
Put it in a very dry place, and let it sit for a few days. How is it getting either dew or condensation? Once dried out, keep it in an airtight plastic bag.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Help! «Dew Warning» in Panasonic camcorders
The dew sensor is in most if not all makes and models. No maker has the corner on dew sensor failures. What is a problem today is that service fees nearly outstrip replacement costs. The part itself is cheap, putting it in costs. A great tech can fix the issue in about 10 or so minutes.
Panasonic Palmcorder PV-DV203 Mini DV Digital Camcorder Logo
423 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
