Question about Lexmark X2690 All-In-One InkJet Printer
Printer not communicating
Lexmark X3580 used to work on old computer with XP. Now installed on new Dell computer with Vista, and won't work. Not even a titter! Says computer can't communicate with printer. Tried all it says, uninstalled/reinstalled numerous times, checked USB, updated driver and that didn't work, had to resort to system restore as couldn't get rid of all the **** after uninstallation (and still can't) and am reluctant to download loads of unwanted stuff. Googled and seen loads of people have the same problems with Lexmark, tried loads of remedy's and still nowt. It just sits looking pretty on the desk.
jhall1793
  • 60 Answers
SOURCE: Communication problem with notebook/printer
You've encountered 1 of the many issues with Vista. The OS is so gargantuan that Microsoft had to ax many of the drivers that were included with XP.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1019285789_0_en,00.html
Copy & paste the above URL into your web browser & that will take you right to the driver download page. Select the red highlighted "Driver Download" for the 1200 series printers. This will send you to the Operating System selection page. Once selected you'll see the red highlighted .exe file. Select "download now". You should see a pop-up asking you to save the file. I like to send downloads to the desktop to facilitate installation of the software. You can later drag & drop it into whatever folder you like.
Make sure to remove the XP drivers before installing the Vista drivers. Also remember to unplug the USB cable from the printer prior to installing the Vista drivers. The installation software will prompt you when to re-install the USB cable.
Good luck.
Posted on Feb 28, 2008
Ajkill
  • 2035 Answers
SOURCE: Printer stays offline on Vista
To help you resolve this problem, try the suggestions below.
The Basics:
1. Check your cables and their connections. Reconnect the parallel or USB cable to the computer and to the printer. Make sure there is a direct connection, with no scanners, switchboxes, or hubs inline. Other devices can sometimes cause communication problems between the computer and printer. For more information on this issue, see 'Scanners and Other Devices' below.
2. Remove the power supply cord and reattach it to the printer. The printer should make a noise soon after the power cord is reattached. Note: This is a general diagnostic that seems to fix minor communication issues.
3. If you are using a parallel port, verify that your computer is set up for bi-directional communications. If bi-directional communication is not enabled on your computer, the parallel port mode setting in the computer CMOS setup will need to be set to either bi-directional or ECP. Do the following:
1. Right click on My Computer and select Properties.
2. Click Device Manager. You should see a section called Ports (COM & LPT). There should be a (+) sign to the left of that section.
3. Click on it, and look for ECP Printer Port (LPT1). You may need to contact your PC manufacturer if any of the following are true at this point:
* It does NOT say ECP in the description.
* There is no listing for Printer Port or any variation of'LPT.
* There are question marks or exclamation points next to the LPT1 port listing.
Let your PC manufacturer know what you are trying to accomplish and what you have done up to this point.
4. Go to Start, Settings, Printers. Right click on the Lexmark object and select Properties.
5. Click the Details tab.
6. Under Print to the following port, it should say LPT1 for parallel cables and USB Lexmark or USB00x (<x> = 1-9) for USB cables. You can change these values by clicking on the arrow and selecting a new value from the list. Click Apply, and OK.
If you are using a USB cable and the USB value is not in the list, try uninstalling and reinstalling the driver as detailed in your manual.
If you are using a parallel cable and do not see LPT1, you will need to ask your PC manufacturer to walk you through the process of turning your parallel port on. You will also need to make sure the Lexmark printer is set as default. If not, right click on it and select the default option.
7. If the printer does not work when connected directly to the computer's port and you have complied with the steps above, there may be a hardware problem. In this case you should perform a self-test on the printer. (Click Start a New Search above this solution and enter self test in the search field.)
Scanners or other sharing devices could cause communication problems.
* If you are using a parallel connection, please verify that your cables, scanner, or other sharing devices are IEEE-1284 compliant .
If you are using an USB connection, they need to be at least USB 1.0 compliant.
* If the printer prints normally without the scanner/sharing device and its cables, there might be a problem with the scanner/sharing device. Please contact the manufacturer for information on how to fix such issues.
Note: Although connecting devices through a scanner (or other sharing device) may work, we do not recommend or support the use of such devices as they can interfere with the signal strength that is sent to the printer. Please contact the manufacturer of the scanner/sharing device regarding communication issues for that specific device.
USB Issues:
2. Click Device Manager. Click on the plus (+) sign next to Universal Serial Bus Controllers. The host controller listed here is the software that runs your USB ports. It is linked to a chipset on the motherboard that requires frequent updates to satisfy the needs of newer products such as your printer.
3. Look at the name of the host controller. Some of the more common names are Ali, Intel, AMD, Via, and SIS. You will need to contact your PC manufacturer to get help updating these specific controllers to the newest driver set.
If YOU are the PC manufacturer, check the manual for your motherboard to find out who makes the chipset for the motherboard. Again, Ali, Intel, AMD, Via, and SIS are some of the more common manufacturers of chipsets.
4. Look for either Lexmark USB Printer or Other Devices in the Device Manager.
5. If you see anything with Lexmark..., click on the plus (+) sign to its left and look for Inkjet Color Printer below it.
6. If it is present, double-click on it. Tje next screen should report that the device is working properly.
7. If you see any question or exclamation marks listed in the Device Manager (small yellow icons next to the listings), double-click on those items to obtain information on what's wrong with the items. This information is useful for troubleshooting the system.
8. If not or there is nothing present, you will need to uninstall and reinstall the printer driver software, or download a newer version from our web site. Click here and follow the link to our Drivers & Downloads center.
It is also recommended that you connect your printer to a USB port that is hardwired or "part" of the motherboard. USB ports that are located in the front of the PC and those that are located in the expansion card slots may cause communication issues if used for printing. You should always try to use the USB slot that is located near your peripheral slots, i.e., your mouse, keyboard, parallel and serial ports.
Multiple PCs:
The printer cannot be connected to multiple PCs at the same time. This includes, but is not limited to, using both the USB and parallel ports of the printer and the use of switchboxes. The system board on the printer will get confused at multiple requests for status, even if one computer is off and the other is on.
Docking Stations:
If you are using a docking station, try using the printer with a different, standard computer with parallel equipment as a test. You may want to contact the manufacturer of your other device for information on the correct functioning of a pass-through device. If the printer does not function correctly when directly hooked to a computer, the hardware may be at fault and the printer will need to be run through the self-test.
Converters/Adapters:
Lexmark printers do not support USB/parallel adapters and will probably not work. Nor will any USB/Parallel constructed cables. Our printers require either an IEEE 1284 bi-directional parallel cable, or a USB v.1.0 or 2.0 A/B style cable. Some printers can only use the parallel cable, some can use only the USB, and some can use either one. However, Lexmark cannot support printers hooked up to computers with a cable that attempts to cross between parallel and USB platforms, as this will cause communication issues.
Software Interference:
A piece of software may be interfering with the printer's communication ability, or your computer may be experiencing a system resource problem. We can try to alleviate these issues by putting your computer into Selective Startup mode. This will prevent any software applications other than Windows from loading when the system starts. To do this:
1. Click Start, Run.
2. Type MSCONFIG on the Open line, then click OK.
3. When the System Configuration Utility opens, place the marker dot beside Selective Startup. Below that, deselect Load Startup Group Items. Then click Apply and OK. You will be prompted to restart the system.
4. When your system restarts, only the Windows operating system should be running. You should not see any icons in the lower right-hand corner of the screen, beside the clock.
5. Try your action again. If it works, the source of the problem was one (or more) of the applications that were loaded into memory.
6. You can return your system to its original configuration by clicking Start, Run, typing MSCONFIG and clicking OK. This time, select Normal Startup, click Apply and OK, and restart the computer.
Posted on Mar 15, 2008
map9966
  • 2351 Answers
SOURCE: computer will not communicate with printer
Ckeck in control panel & se if the driver software installed. It should be listed in Add/remove programs. If it is, power up the piinter & load windows Vista update service. See if Vista has any patches for you're printer. If no, goto Lexmark & go to the driver section for you're P4350 printer software for Vista. While in Vista update, install any updates listed.
Click on the link provided.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:479:0:0&searchLang=en&os_group=Windows%20Vista&target=
Creat a folder on you're desktop & down load the latest driver software in-to the folder you created. Uninstall any Lexmark software that might have been in add/remove programs. Install the driver software you downloaded. If all this still fails, call Lexmark since this is a new printer. The number should be in you're manul. Or you can go here for free support.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569481_0_en,00.html
Luck!
Mike
Posted on May 29, 2008
  • 461 Answers
SOURCE: Cannot get printer to work on Windows Vista Home Basic
This model does not have a Vista driver listed on the Lexmark Website. Other than attempting to use a generic driver or driver for another model I don't know what other options you have.
Posted on Jan 08, 2009
tbock86
  • 68 Answers
SOURCE: computer won't communicate with printer
Make sure that the printer driver you are using is compatible with your version of windows. If so, open all printers in "control panel" and make sure that this printer is the preferred printer and not an old one you might still have installed.
Posted on May 09, 2009
Lexmark 5470 printer not working on Windows Vista
If you just connected the printer to your Vista PC, the drivers probably didn't load.
If you haven't yet, you need to install the Lexmark drivers first before you can use your printer. Unplug the printer before installing, then plug it in when prompted by the software.
Lexmark drivers:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Mar 24, 2009 | Lexmark X5470 All-In-One InkJet Printer
Computer not communicating with printer
You stated that you just got a new computer and are trying to hook up your old printer to it. Here is the Lexmark website to download new drivers for the VISTA? operating system driver for your printer. Use the control panel printer install along with the new downloaded driver.Whee asked where the driver is, just let it know where you placed it. I would first uninstall the printer .
Dec 28, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
I just bought a new DELL computer with the windows vista program. I alredy instaled the software for my Lexmar X1240 printer with the 1200 series disck. I can not print because each time I try to a window...
This is from the Lexmark Support page:
Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model. (From Lexmark Support)
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Here's the support page:
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
If you need more help, just ask.
Oct 17, 2008 | Lexmark Office Equipment & Supplies
Lexmark x3580 not working properly
it must be the usb drivers problem.is the pc detecting as "new hardware found " when you connect the printer usb wire to the computer.
just click the link below and enter the approtiate model number of ur printer and download drivers.
www.lostmydrivers.com
thanks.
Sep 18, 2008 | Office Equipment & Supplies
Computer will not communicate with printer
Go out to Lexmark web site and look for a vista update in their software download section. So this should solve your problem.Most of the cds which come with equipment do not contain vista software and drivers.
Aug 06, 2008 | Dell 962 Photo All-In-One InkJet Printer
Luck!
Mike
May 29, 2008 | Lexmark P4350 All-In-One InkJet Printer
X1100 lexmark printer not communicating with computer
ya go to lexmark .com download ther vista verison driver for your printer ok dont use cd at all those for xp ok
Jan 23, 2008 | Computers & Internet
Lexmark won't work with vista
Yes works with Vista but you will need to use Vista driver not XP
Rate this solution then Download here
Delete old install before reinstalling!!!!
Release Notes Attention: To prevent issues during the installation, please uninstall all previous versions of this driver prior to installing this web package. File Information File Name: cjr1200EN.exe null.gif Version: 1.0.11.3 null.gif Released On: MAR 05 2007 00:00:00 null.gif File Size: 42452912 KB null.gif Products: Lexmark X1240, Lexmark X1250, Lexmark X1270, Lexmark X1280, Lexmark X1290 null.gif Languages: null.gif Operating Systems: Windows Vista null.gif Application: n/a null.gif Owner Name: Lexmark null.gif Data Stream: Lexmark Host Based Solution, Lexmark Scan and Copy Control null.gif Security: null.gif Install Instructions:
Dec 25, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
I had this same problem...drove me crazy for a week. Called the geek squad at Best Buy and they mentioned something about a"patch" (which I had no idea what that meant) on the website of the printer. I went to Lexmark website, and selected 1200 series and windows vista (which is what's installed on my computer) A page came up to install a driver that made the two compatible and it worked!!!
Apr 10, 2007 | Lexmark X6170 All-In-One InkJet Printer
Open Questions:
See all Lexmark X2690 All-In-One InkJet Printer Questions
Lexmark X2690 All-In-One InkJet Printer Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
