Electrical Supplies Logo
D
Danny Mcleod Posted on Oct 28, 2016
Dewalt dg6000 runs but will not produce electricity
I checked all the breakers and the main switch all seem fine, engine runs but no power at the outlets, please help
Alan Relder
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 7 Answers
  • Posted on May 06, 2017
Alan Relder
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
7
Questions
0
Helped
3454
Points
17
High and Low Temperature Operation
Air temperature affects generator output. Output drops 1% for each
If the engine does not start:
1. Check the fuel tank for sufficient fuel. Refill with fresh gasoline if necessary.
2. Check the engine oil. Fill to the upper limit with fresh oil.
3. Ensure that the fuel petcock is open. The fuel petcock is open when the lever is perpendi-
cular to the ground (straight up and
If there is no power to the receptacles:
1. Turn the circuit breaker switches off and disconnect all electrical loads from the generator.
2. Turn the circuit breakers on and test the GFCI's by following the procedures in this manual
on page 1.
3. Place the voltage selector to the 120 Volt only positions (unless you are using a tool that
requires 240 Volts).
4. Turn the idle control switch off.
5. Turn the circuit breaker(s) off and reconnect the electrical loads. Be sure that the plugs are
securely connected to the receptacles.
6. Turn the circuit breaker(s) on.
7. If there is still no power at the receptacles, take the generator to an authorized D
service center. To locate a D
WALT service center nearest to you, call 1-800-4-D
E
2answers
My kipor generator runs but produces no power. What is likely to be the problem
We have a whole Help Center and Engineers dedicated to helping people fix their Kipor Portable and Inverter Generators.
In addition to this we have a "Parts Search Service" if the part is not listed on our site. Check us out on our site.
https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
2answers
What could be wrong if the generator cranks up but will not produce power?
Are your breakers tripped? Test the power side of the breakers and if there is no voltage there, then the generator may be shot.
No power at outlets
I have a DeWalt dg 6000 and it does not have electricity coming out of the generator to the plug out lit so what do you think about the power not working
Runs for awhile shuts down and will restart but will run awhile and shut down
Check your oil, you have a low oil sensor on your unit and if the low oil sensor will shut the engine down,
1helpful
Dose not genrate power
This Model should have a power line for the field coil. Rather than that try plugging in a drill connected to another drill (powered by a wall circuit) spin one drill with another while the engine runs. This will generate electricity back through the generator and power the field coil. Once charged it will start on it's own.
If this does not work I would recommend taking it to a local dealer like www.arcolawn.com to prevent wasting money chasing circuitboard problems. good luck
Joe
4answers
Where can I find a schematic for a dewalt dg6000 generator
Here is a 4.3 MB pdf manual for Dewalt generators: 2900 4300 6000 7000
http://waterheatertimer.org/pdf/Dewalt-2900-4300-6000-7000.pdf
Dewalt has service centers and parts sales, you'd think they'd be eager to post manuals on their webiste. Service centers are probably only place to get parts.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
