Question about Air Tools & Compressors
IT WNT TURN ON craft man air compressor
IT WNT TURN ON ,I PLOG IT IN IT CRANK AN IT DIED AFTER 2 SEC WATHS WRONG?I IT IT LOOK TO HAVE POWER
  • 98 Answers
Check power supply , did it smell when it started up , if so motor could be bad are perhaps a capacitor
Posted on Jul 22, 2009
My air compressor works run for about 20 sec then cut off rear still sagging
Sounds a lot like an Air/Vacuum leak to the rear Shockies..... See a Suspension Specialist....
May 08, 2014 | 2004 Ford Crown Victoria
My air compressor will crank and run for 7 to 10 minutes and then die just like you turn the key off.
well you didnt mention what year or model number you got but some of the better IR compressors have a fuel saver mode that if they don't sense any change in load for like 15 minutes they shut off could be what your seeing , or could also be a safety sensor on the seperator tank not seeing any pressure build up (bad or damaged sensor?)
Apr 15, 2014 | Ingersoll Rand Air Tools & Compressors
Whats wrng with my 97 jeep grand cherokee it died and wnt start bak up it turns over but acts like not getting gas. I sprayed starter fluid and it started a sec thn died.
It is not getting gas. Could be bad fuel pump,and most are now in the fuel tank.If it is the fuel pump and it is in the tank,this can be a fairly major expense.($400-$500)This is not an unusual problem,and many auto repair shops can do it.
Apr 04, 2012 | 1997 Jeep Grand Cherokee
Builds up air pressure ,motor shuts down
We are distributors of all plastic materials, including complete fabrication of plastic parts, components and assembles like Acrylic sheets, polycarbonate sheet and UHMW.
1)Turn off your compressor or disconnect the power.
2)Remove the connector tube that sends air to the tank.
3)Remove the head bolts on top of the pump.
http://www.plastic-craft.com/novus-plastic-polish-buffing-kit.html
Aug 09, 2011 | Campbell Hausfeld 04 Gallon Twin Stack...
Wont run
Most likely it's a burned out starting capacitor. Running any tool that uses as much power as an air compressor does will usually burn out the capacitors. They burn out because there is too much voltage drop due to the resistance of the cord. The best bet is to buy longer hoses or if you must use an extention cord use a 10 ga. cord.
May 26, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air compressor won't stay running even with resetting
How quickly does it shut off? Is it reaching the turn off psi? or is it immediate.
If it is immediate then it is probably a power supply issue.
Air compressors are power hogs. For instance, a compressor may work fine on an outlet using the supplied power cord, but plug it into an extension cord that is insufficient for it and a repeat of your problem will occur. If you use an extension cord make sure it is made just for this kind of application. Also, if possible, give the compressor a dedicated circuit.
Another problem might be your unloader valve not working correctly. This reliefs the pressure inside the pump after the motor has stopped. it would sound like the pump is working extra hard at start-up.
May 19, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
Carrier 40MVC A/C Flahing LED
there is problem with the unit. the 2 flash codes indicates a problem.
i am just not sure what it is.
it could be a low voltage alarm,
a high voltage alarm
freezing evaporator alarm.
not cooling alarm.
reset it by un pluging the unit for 1 minute then plug it back and run it. observe if the compressor would start.
if it start, check if it is cooling,
if it starts to cool, check the coil of the evaporator if it is freezing..
you could trace from there what is wrong with the unit.
pls keep me posted..
kindly use the ask me button,
tnx 4 using fixya,
drcool
Sep 06, 2008 | Heating & Cooling
Air Tools & Compressors Logo
71 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
