I have i-rocks 3.5 sata hdd hard drive external. I can't find any paperwork on this device. How do I change settings. It's starts autoplay each time I start computer and files are often duplicated, wasting space and making it confusing as to which version is the correct one.
    Problem Solver:
  • 6 Answers
Right click on Start, left click on Explore. On the left panel in Explorer find your External hdd. Highlight the drive, right click and open properties.
You will find a tab that says Autoplay Select this tab and choose what you want this drive to do.
Posted on Jul 19, 2009
I'm trying to install a Western Digital Serial ATA Hard Drive into the external hard drive enclosure. There are no instructions as to what cables need to be attached and to where
USB external hard drive cases are supplied with SATA and power connectors attached to the circuit board in the case. If you canot connect it to the SATA hard drive then you may have the wrong drive case, your case may be a IDE or SCSI type.
Jul 07, 2011 | NexxTech 1 Bay USB 2.0 External Drive...
My laptop uses toshiba mk3265gsx sata hdd.. but it's now broken because of motherboard problems. but my hdd is not broken.. yet i tried to make it to be an external hdd so i bought an enclosure.. now when...
1. Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
2. To change the designation of a new drive to be a slave drive, skip to step 4.
3. To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
4. Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
5. Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
6. Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
Say "Thanks" by clicking the thumb icon in the post that helped you. Please click "YES" in solution that solves your problem as "was this helpful?"
Apr 20, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Want to replace 80Gb HDD with a bigger one. How? Do I have to copy everything from the original one to the new one before actually replacing it? how?
Before you change the 80 GB Hard Drive you can take the backup of your hard drive to the External Hard Drive or if you have any sata case so you put your new hard Drive in the sata case and make 2-3 partitions in the new drive and copy your data in the new hard drive except in first partition which will be primary C Drive for your laptop and will replace data when you install windows in it. after the windows is installed and your data is verified in your new hard drive you can clear your old hard Drive or use it as an External Hard Drive (as you like )
2nd thing which is more safer and reliable is that you make backup CD/DVDs for your data before proceed to formatting or even changing hard drives, it will be very useful and helpful for any unforeseen data loss
if you require more assistance regarding this feel free to reply to this post
Regards, BA
Jan 14, 2011 | Acer Aspire 9300 Notebook
Connecting a esata port to a sate external hard drive
I don't think there is a converter from USB to ESATA, but you could buy a new Hard Drive enclosure that has those options, but I am not sure if you are willing to take out the HD from the existing one.
Sep 09, 2009 | Iomega HDD External Desktop (32660) 80 GB...
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Sata HDD set in primary master in Bios
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Jan 04, 2009 | Maxtor Hard Drive
Nexstar.3 Sata external drive woun't start
I also have the same problem. I bought a 500gb WD HDD and it worked great via USB for about 4 days, not the computer does not have it. i am running windows xp home. i can also hear the drive working and the blue light comes on, but it is delayed. When it was working correctly it came on instantly and the computer found it instantly.
May 19, 2008 | Vantec NexStar-3 External 3.5inch...
External SATA hard drive will not wakeup after "System Standby"
All in one !!!
http://www.mediaatlantic.com/section.php/1730/0
This device will switch off all devices connected to it (including your hard drive) at the same time as your pc is switched off.
There are other models available.
Danechip.
Mar 27, 2008 | Intel Motherboard
Simpletech 500 gig usb plug in hard drive
Is the drive running when connecto to power ans PC?
Try it on another PC.
Check the power supply if it is operated from an external power supply.
It it is self powered via the USB then this is a possible problem- the PC power supply cannot cope - Removing other USB devices may help here
Feb 13, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
