Back to:
Tags:
Bosch HES 232 / HES 236 Electric Kitchen Range
Temperature fluctuating
posted by Winkie on Nov 19, 2007
I have a Bosch HES 232-U/01 stove that is 2 years old. The temperature in the oven is fluctuating quite a bit is is becoming unreliable for baking breads, cakes, etc. I had a repair person come out and when he *finally* got through to Bosch tech support, they said there was a service bulletin on the stove and I need part 445-300. What is the part and when was the service bulletin issued?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Kitchen Ranges problems?
Bosch HES 232 / HES 236 Electric Kitchen...
i am getting error code 153 when boiling water. What does...
how do you remove the top to replace dual burner switch...
I bought a used Bocsh Stove and the display language is...
2 (front) of 4 burner dosen't heat unless i start the oven...
Loading problems.
Repair Service
Find Kitchen Range Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
