SOURCE: HOW TO INSTALL A NEW CHAIN ON POULAN 16'' BLACKHAWK CHAINSAW
hi likniz
unlock the lock nuts,take off the chain cover,change the chain,adjust the screw tightening chain,back the cover and the lock nuts.
best wishes savumihai71
SOURCE: 36cc poulan chainsaw carb settings
Poulan does not give the settings but they do give a toll free number to contact if you need help and that is 1-800-554-6723. Sorry I couldnt get more but that is all I saw
SOURCE: gas / oil mix for craftsman chainsaw 36cc
Fuel/Oil Mixture
Lou
SOURCE: I have Craftsman 36cc 16in Model-358-350461no oil to the bar.
We are prohibited from contacting you directly.
Oil System Plugged:
1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution.
• Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out.
• Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability).
• Start the saw and see if it oils when revved up (oozes down side of saw).
• If yes reassemble your saw. If no, continue with 2.
2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go.
• Carefully check the hoses for cracks especially at bends and connections.
• If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread).
• Please make extensive notes & some digital pictures will help during reassembly.
3. If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL for the location).
The IPL (exploded parts list) for your saw is the only detail for the oil system, it is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358350461&productCategoryId=1503220&brandId=0247&brandDescription=CRAFTSMAN&modelName=CHAINSAW&diagramPageId=00001&componentDescription=CHASSIS%20BAR%20CHAIN&documentId=P0205138&blt=06
It appears to have an outboard clutch, this will be helpful;
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
