Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
My DC17 hose has no suction and is constricting
    Sniper:
  • 83 Answers
You have a blockage in the wand - take the wand off of the back of the machine, separate the wand from the hose by pushing the red button where the hose is attached to the wand. Hold the wand up in the air and look trough it. If you don't see light coming through the other end you have a blockage in the wand. Take a long object like a stick or a metal hanger and remove the blockage. I am confident that this is where the blockage is but...if you can see through the wand the blockage is in the u-bend, but the hose won't constrict then...remove the u-bend which is attached to the vac at the bottom next to the long gray hose - it is attached to the machine with a plastic screw - turn the plastic screw 45 degrees anti-clockwise and clear the blockage from the u-bend.
Posted on Jul 30, 2009
I discovered my Dyson 17 would loose vaccum and yet I could not hear anything while the floor brush was running. After letting the unit sit for 15-20 minutes it would have suction again. I think there is a thermal overload within the vacuum motor that is causing to to quit. Has anyone else experience this and what is the cure?
Posted on Aug 19, 2009
Starts to vacuum and sounds like a valve opens and start letting in air. Suction drops to nothing. I have cleared all paths and confirmed nothing is blocked.
Posted on Aug 16, 2009
    Problem Solver:
  • 7 Answers
Try taking the pre filer out that the blue sponge thing replace the housing and see if the sucton improves maybe the prefilter needs cleaning
Posted on Jul 28, 2009
  • 97 Answers
Check for a clog
Posted on Jul 20, 2009
2 Suggested Answers
pippall
  • 1486 Answers
SOURCE: my DC17 suction hose doesn't have any suction occasionally.
check the seal on the filter is not broken,And check for any blockage at the bottom of the pickup pipe.
Posted on Nov 18, 2009
Dyson 07 wand cap removal
http://www.dyson.com/support/dc17/dc17-animal/diagnosis-root-menu/dc17filterwashvid/flo-dc17-wand-suction/flo-dc17-remove-the-wand-from-hose - This should help you!
Aug 05, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Poor Suction
The flexible hose between the beater bar housing and the connection to the dust bin might have come loose or has a hole in it. Check this hose for your low suction problem.
May 15, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I don't get much suction from the hose on my DC17 All Floors. I don't see any obtacles in the hose. The suction when upright is fine.
The way your Dyson DC17 is designed, there is a suction divert mechanism that diverts the suction to floor when the vacuum cleaner head is pushed down, and then back to the hose when the vacuum is in the upright position. If you are getting suction from the hose when the vacuum is upright, but no suction after the handle is reclined, this is actually the normal function for the Dyson DC17.
You can check to see if the filter is dirty. The washable filter on your Dyson DC17 is located directly underneath of the dust bin of the vacuum cleaner. After removing the dust bin, lift straight up on the part the bottom of the dust bin rests on. This is where the pre-motor filter is located for the DC17 models. If this filter is not cleaned on a regular basis, then it can start getting clogged, and you'll notice a loss of suction on the vacuum cleaner.
If you have further questions, please visit the link below where you may download the instruction manual. There are some trouble shooting guides at the back of the manual that you may do to try and diagnosis this further.
Dyson DC17 All Floors Instruction Manual:
http://media.dyson.com/downloads/us/floorcare/manuals/dc17_opmanual_usa.pdf
If this was helpful, please be sure to rate the repair as helpful by clicking on the thumbs up icons on the top of the repair.
Thank you very much,
Chris Jones
GoVacuum
Mar 23, 2010 | Vacuums
Poor suction with hose on dyson dc17 . Vacuum works well otherwise
your hose is plugged up. with the machine on try bending and banging the hose around to get rid of the obstruction. you will hear the motor change in pitch when the hose is unplugged.. this should help.
Mar 09, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
A Dyson dc 17 Animal and the wand/hose has lost suction
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Jan 30, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Our DC17 is loosing suction. How many filters muist be cleaned?
This video is for replacing the clutch & belts, but it also shows how to take out the hose underneath & inspect it for holes or damage to see if that's causing suction issue http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
Dec 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My DC17 suction hose doesn't have any suction occasionally.
Nov 18, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson DC17 will not turn on unless the handle is pulled back.(into the vacuuming position) The attachment hose will not work at all (0 suction thru it). I've checked the hose and made sure there is no...
Not sure if I can help, but I'll try. The DC17 has two motors: the vacuum motor and a separate motor for the brush bar. It is normal that the brush motor works only when the handle is pulled back in the vacuuming position - that's the way it's made. So, when you say "my DC17 won't turn on", I'm not sure if you mean the vac motor, the brush motor, or both. If the vacuum motor won't turn on, then you've got a problem I can't help you with.
As for no suction through the hose, I have to ask... are you sure your vacuum motor is working at all? Even with the hose stored away, the machine still relies on suction through that hose. If you're sure the motor is working, then either you've got a blockage that you haven't yet found (there's at least one inspection port, a sort of U tube at bottom right of machine, that you need to check), or it could be that you've got a hole in the flexible hose (which opens only when the hose is extended).
Sorry if this is a bit garbled, but I'm puzzled by your problem. If you want to come back with more details I'll try again for you!
Feb 17, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
1,748 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
