Question about HP Pavilion DV6700T Notebook
My computer will not go to the logon screen
I thought that I could fix my HP dv6700 computer when one side of the computer came completely apart (top separated from the bottom) well I took the computer apart, and it just turned out to be one of the screws had fallen out, luckily I was able to tighten the piece back inot place, but when I put everything back together the display was not working. It flashed the HP logo and that was all, so I took it apart again and finally discovered that it was a cord that had come undone, and I plugged it back in and it finally displayed that screen that says some problems occured while starting your computer, and there were two options to click, start windows normally or scan windows for problems. I have done both of those options now, and all that my computer will do is act like it is going to the logon screen (on the bottom of the screen it says copyright Microsoft Corporation with the scrolling indicator that something is loading) but it goes no farther than that. No matter how much time I give it, and I have already tryed removing the battery and checking the charge and none of that helps.
Removing back cover of hp dv 6915nr
Back Cover?
1) Display Cover: The plastic cover that is on the opposite side of the LCD screen. Sometimes referred to as Top Cover.
Display Assembly is removed from laptop first, then LCD screen assembly is removed from the Display Cover.
2) Base Enclosure: The plastic bottom part of the notebook.
A laptop is disassembled from the Top down to the Bottom.
The bottom 'cover' (Base Enclosure) is not removed first. It is last.
3) There is no back cover per se. Half of the cover for the back (Bottom half) is part of the Base Enclosure. The top half is part of the Palm Rest.
(The back has the Vent in it)
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
[Use the dv6700 service manual. Go down to the subheading HP Pavilion dm1 (dm1 is in blue)
Scroll to the right, click on dv6700. Note that it is a PDF file, and may take up to 30 seconds, before you see the first page come up ]
What is it you are trying to do? What hardware component are you trying to access?
Post back in a Comment.
Regards,
joecoolvette
Display assembly is removed. Palm Rest Cover is removed, and so on.
Jan 14, 2012 | HP Pavilion dv6915nr Notebook
I have an hp dv6700 but it doesnt want to work because when i turn it on it says configured stage 3 of 3 0% complete and it turns off
It is possible that the computers operating system has become corrupt for one reason or another, my guess is that your computer is over 3+ years old(dv6 series is old) if formatting and reloading your operating system doesn't fix this issue, it may be your hard drive that has failed(or failing)
May 06, 2011 | HP Televison & Video
I have an HP DV6700 Laptop Computer. The internal powersupply prong is loose...How can I fix it?
The laptop needs to be disassembled down to the motherboard, the power plug is not soldered to the motherboard, it is actually a satellite card attached to the motherboard via a small cable. The entire assembly can be purchased on Ebay for under 30 bucks. Below is an example of the listing. I will include a link to an illustrated disassembly guide.
Ebay: http://cgi.ebay.com/HP-DV6000-V6000-DC-Jack-USB-Board-DAOAT8TB8F2-/260636627698?pt=LH_DefaultDomain_0
DV6000 disassembly: http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
Aug 11, 2010 | Computers & Internet
I have an HP Pavilion dv6700 and use vista. I pu...
As for your situation you should check your product on the hp site to see whether you need any updates or patches for drivers, bios, or hp softwares that might be the cause of the problem.
May 20, 2010 | Computers & Internet
My HP Pavilion Dv6700 turns on but nothing on the screen as in its black, BIOS do not show. Please help!
Looks like the post itself fails on the system from what you have told here. Its easy to reset the bios. Download the actual bios flash program on a completely formated usb drive. Fix the usb on your laptop and keep fn+esc keys pressed and switch on the laptop. It will rewrite the bios and once rebooted the system should work. Good Luck.
May 05, 2010 | HP Pavilion DV6700Z Notebook
I broke the screen on my lap top and not sure what the resulotion is i have a hp pavilion dv6700
The DV6700 model carries the 15.4 WXGA High-Definition inch display, which outputs a maximum resolution of 1280 x 800.
Apr 23, 2010 | HP Pavilion DV6700T Notebook PC
HP Pavilion dv6700. no screen.
Please run system restore to an earlier date.
Start system holding down f11 key till you hear a beep then follow the screen instructions.
Good luck.
Mar 21, 2010 | HP Pavilion DV6700T Notebook
HP Pavilion dv6700 has system failure when connecting to TV
Try updating ALL Video Card & HDMI Drivers from manufacturers web site, that will probably be the best chance at a fix, this is a driver issue. Connect up this way... Start TV... plug in Cable to TV & PC, now, startup PC.
Feb 16, 2010 | Computers & Internet
Hp vs19e just died
those capacitors are polarized they have a neg and a pos side were they seated correctly? could also be transistors going bad but my bet is some cap was in backwards.
Mar 22, 2009 | HP w19 19" LCD Monitor
HP Pavilion DV6700T Notebook Logo
78 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
