Question about Lexmark X1270 All-In-One InkJet Printer
Will not install
I recently changed computers. When I try to install it with disc, it gets to point which says "setup is updating your system" and then "Click finish to complete set up", and then nothing happens.
  • 1,463 Answers
Re: Will not install
Seem today the lexmark site is down this be the cause for not installing the printer
Posted on Nov 19, 2007
0 characters
3 Points
Computer was recently updated to Windows 7 and now if I try to scan something I get the following message ... "Refer to device documentation to troubleshoot." I've tried re-instaling w/disc...
Make sure you go to Hp's website and download the drivers for windows 7 support. Also when installing HP printers make sure the printer is not attached to the computer while driver installation is preforming. Only attach the printer to the compter after the driver is installed and the system reboots.
Mar 10, 2011 | HP Officejet 6500 Wireless All-in-One...
Faxing on my Dell Pc
dear Smitty1935
Kindly remove all the drivers and install once again the drivers , please note , do not take option reinstall, remove the drivers and then install the fax drivers
Jan 01, 2008 | Dell 924 All-in-One InkJet Printer
After updating the firmware in hp laserjet 4350 , printer disk not initialising is showing
Hi ,
Please try sytem restore for day before when you updated the firmware.
Steps to perform system restore:
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as an administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore
3. On the Welcome to System Restore page, click to select the Restore my computer to an earlier time option, and then click Next
4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK. ajayonline_0_1.png
5: On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
6: Log on to the computer as an Administrator. Then click OK on the System Restore Restoration Complete page. ajayonline_0_2.png
After completion the printer should work as it used to.
Thanks. Ajay Virvan.
Nov 16, 2010 | HP LaserJet 4350 Printer
I recently changed my computer and it is 64 bt. do I need to download a different setup for this as opposed to my former 32bt computer?.
Have you tried to use the install disc you have ?
If it wont install, pop over to kodak / support and download your drivers / software if it is available
Oct 17, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
Pc asking for system disk but i have no was working fine until i changed the dvd rom
Any new Hardware install you need to setup, with some,sys drivers are installed, so auto install takes place.
Guessing, your "Poota" fails to find new drive prog, so it is asking for the setup disc to the dvd drive?
Go too DVD drive company, look for update driver download.
Do you have the dvd prog dvd/CD ??
Nov 13, 2009 | Printers & Copiers
Changing the network settings
do you still have the disc the came with the printer if you do dont worry just insert the disc into the computer then restall the installation then follow the steps in the screen and the end the computer is going to pring all the paper
May 06, 2009 | HP PhotoSmart C4385 All-in-One Printer
I just tried to scan with my Lexmark X1270 that worked fine the other day now it says AIOC exe has encountered a problem what has happened t change how it works
You need to update the driver for your printer. Using your install disc, just follow the normal install process which will work as an "Update Driver".
If you do not have your original disc, follow the steps below:
  1. Make sure you have the regular printer driver installed. If you don't, you can grab it from the Lexmark website and install it.
  2. Next, keep your USB cords plugged in but turn your printer off.
  3. Download the All-In-One Center Software here.
  4. Unpack the archive, open the "Applications" folder, and double-click Setup. This will install the application - it can take a bit.
  5. Once the application is installed, turn the printer on and try a test scan. If it works, you're good and can quit reading.
  6. If you get an error when running a test scan, don't panic. Reinstall the regular printer driver, using the "Update Driver" option that appears.
  7. Restart your computer.
  8. Do a new test scan. This should bring up the All In One Center's loading screen, which will start searching for programs (this can reallllly take a while). When it's done, everything will be working beautifully again!
Feb 22, 2009 | Lexmark X1270 All-In-One InkJet Printer
I have a hp4135 printer/scanner/copier. i've about had it w/hp. it will not stop coming onto my computer to install. i think the install disc is defectiveas it will not install the scanner part. it goes to...
First, download the install here, if you do have a defective CD there is no point wasting time with it. Next, uninstall everything that the software setup and remove the printer from the printer window. Make sure that you are a local administrator.
Remove the printer from the computer and reattach it in another USB port you haven't used for this printer yet then cancel the Windows Hardware Wizard when it tries to run. Run the installer and do the Next, next, next thing. If it lags out on your on step 4, just wait a bit. If you get nothing after 7 minutes or so force quit the installer and use Add Remove Hardware and the extracted inf file left by the installer.
Finally, The HP auto update software sucks. It nags and needs administrative privileges to run. Since it is completely unnecessary to the printer running remove it from the start up folder.
Jul 30, 2008 | HP Printers & Copiers
My photosmart 7762 will not print from the internet
The internet provider should not have anything to do with this. If by chance they installed some software when you switched, try uninstalling it and then try printing. It does sound like a driver issue though and i would have asked you to reinstall the driver. If by chance this happened after updating to a newer driver for your printer, try an older one off of the disc that came with your computer. Good luck!
Feb 17, 2008 | HP PhotoSmart 7760 InkJet Printer
Lexmar 1270 will not install
seem's today there web site is down
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
Top Lexmark Printers & Copiers Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Printer and Copier Expert? Answer questions, earn points and help others
