Question about Sony SDM-HS95 19" LCD Monitor
SDM-HS95P monitor 19" Sony doesn't work
I have a SDM-HS95P monitor 19" Sony. It doesn't work. The monitor, when plugged in goes dark, nothing in the display. I think problem with power supply, it is not coming. Can you help me to fix?
  • 6 Answers
SOURCE: Sony SDM-HS75 tft lcd monitor
I HAVE ONE SONY MONITOR MODEL SDM HS75.
IT IS SHOWING LED BLINKING FAST NO DISPLAY IF CAN ANY BODY HELP ME TO SOLVED MY PROBLUME.
ASHOK MY CELL NO.09322133048
email.ashoksharma4@gmail.com
Posted on Apr 18, 2008
SOURCE: black screen with message about no input signal
might be something wrong with your monitor's data cable
Posted on May 21, 2009
preachw996
  • 1179 Answers
SOURCE: Display orientation issue
Right click the mouse on an open area of the desktop, In XP select properties; Vista it's personalize. Go to the display settings and make sure it is set to portrait. Hope this helps.
Posted on Jul 02, 2009
SOURCE: My Sony SDM-HS74P display does not stay on.
I have the same issue and wrote the monitor off for now after checking all cables (and a different computer). The logic circuitry and panel are sill ok as I can see a faint image with proper lighting and close inspection, but no backlight makes it useless.
Since there are 4 lamps (CCFLs) on this model, the problem likely is not there but on the inverter circuitry driving them. This does not look easy to replace as this is part of a bigger board.
It looks like some could repair by changing a few (or even one) component on the board, but unless your are used to this (de-soldering and soldering back), you are kind of stuck.
I will attempt this if I have time as I hate junking 99.9% ok hardware. In your case since this is an old monitor you should just replace it if not technically (on the electronics side) apt.
Posted on Jan 04, 2010
budmrtn
  • 11361 Answers
SOURCE: No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
Posted on Apr 18, 2010
Dear Sir I have a problem with my SONY SDM-HS95P/B 19" LCD Monitor. When I turn on the screen the desktop appears for several seconds and than it became black as when you turn off, although the...
Check the caps on the power supply/inverter board first to see if it has any one of them with bulging/leaking tops or bad bottom seals.
See my pictures here (the caps in questions have my red marker on them).
http://s807.photobucket.com/albums/yy352/budm/SONY/Sony%20SDM-HS95P/
To have it repair will not be worth it, you can DIY repir if you have all the needed tools and know how to solder.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 24, 2011 | Sony SDM-HS95P/B 19" LCD Monitor
Looking for windows 7 driver for SDM-HS95P monitor tq
(If this does not explain enough for your issue, please take a few minutes to clarify the specific problem regarding this specific monitor style and Windows 7).
Being that this is an older style monitor, drivers may not be available for a newer operating system, (such as Windows 7). Here is the link to the sony drivers download page:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=SDMHS95P
The newest supported operating system is Windows XP.
The generic monitor driver for windows 7 should pick up this monitor without any need for specific driver installation. Just try plugging it in and it should register automatically.
Jun 10, 2011 | Sony SDM-HS95P/B 19" LCD Monitor
Sudden white screen
Check for 5 or 12vdc feeding the T-CON board, try reseating the connectoe to the T-CON board.
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Oct 08, 2010 | Sony SDM-HS95P/B 19" LCD Monitor
ETI information box appears on SONY SDM-HS95 monitor repeatedly
You might try checking you monitor setup, you should be able to shut it off by unckng the proper box
Apr 29, 2010 | Sony SDM-HS95P/B 19" LCD Monitor
Black screen with message about no input signal
May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
Sony LCD flat screen monitor
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
Vista Drivers
http://esupport.sony.com/US/perl/swu-download.pl?mdl=SDMHS95&upd_id=2252&os_id=4
sony gives this drivers that supports most windows version,try it with vista
Mar 15, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
Sony SDM-HS95 19" LCD Monitor Logo
191 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
