Question about GE (PSS26MSRSS) Side by Side Refrigerator
Food is melting,dial all the way to 9, still melting
  • GE Master
  • 4,654 Answers
Well we need to unplug and remove the food from freezer. Defrost with a hair dryer and look at the defrost heater below the evaporator coils. If you need my help you will have to email me.
Posted on Jul 19, 2009
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
Is the dial to adjust temp coldest set at low numbers or high number?
The dial inside the fresh food compartment, the bottom compartment
set to middle or above (higher numbers mean colder). Usually 5 to 9 if it has numbers.
Freezer knob in the middle if it has one. (If you set a freezer knob to "colder" it cuts
off the cold air to the lower compartment). Hope this helps
Jun 29, 2011 | Kenmore Top Freezer Refrigerator
On the 1-9 scale, where should I set my freezer and refrigerator temperature?
5 is normal. if packed with alot of food go higher 6 or 7. and very little food 3 or 4. depends on how often its openen i.e. large family . 5 is avg.
Mar 05, 2011 | Hotpoint HSS25GFP Side by Side...
I just had a professional mover move a Kenmore 20 19.5 cubic foot side by side refrigerator out of my sister's condo to my home. It was in the upright position at all times and moved gently. It was...
is the fan motor running in the freezer..?if its not locate it an turn fan blade to see if it spins freely retry the frig to see if it works ..is the coil in the freezer frozen up..?if so defrost it completly ..then recheck operation ..let me know ..good luck ..PS you may need to remove covers to get to motor //joe//
Aug 27, 2010 | Kenmore 57029 Side by Side Refrigerator
My Fridge is running Hot on the freezer side and the temperature is rising. Ice cream is melting etc. Fridge side seems OK but also not really cold. Which of the the settings on the internal dials 1 to 9...
It sounds like the condenser is dirty. It's under the refrigerator.
This is easy to do. Just get all the dust out of the condenser and things should start cooling down.
I hope this helps. Please leave feedback.
Thank You.
Aug 24, 2010 | GE Profile PSW26P Stainless Steel Side by...
Temperature in refrigerator is now at 60 degrees even with the dial at setting of 9 other side freezer is fine
sounds like the defrost system is cutting up, it melts the ice in the freezer compartment to allow cold air from freezer to travel to fresh food side and back again, could be a damper control but very rare event.we use to have to melt ice manually in freezers now we have automatic defrosters do it for us. this is not the easiest repair but the defrost sysem is replacable and not the end of your frig.u can empty frig and turn it off for 24 hrs with doors open and let it defrost naturally,so as to make sure that it is a defrostsystem, after 24 hrs turn back on and see if it works correctly after 6 or 8 hrs, if so definite defrost problem.
Oct 08, 2009 | Refrigerators
Freezer side cold fresh side not GE GSH22KGMD
Find the return air It can't come in if it can't get out. also if you were checking it with the freezer door open you will not feel the air. Just in case i have done that myself. if all air ducts are open and it's getting o I should be 20 in fresh food with the control on 9.
Sep 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer does not freeze fast enough, icecream gets very soft. The refrigerator is set on temperature level 9 and is not cold.
Setting the control to 9 may make the freezer ice up too much to work right. You can start with a manual defrost. That takes a long time, because the ice is below the freezer liner, stuck in the coils. You'll have to move your food elsewhere, like a cooler. I always take the freezer apart to get at the coils, use a hair dryer to melt the ice. Then you can check the defrost coil, it's like a toaster element. After all that, check the defrost timer too. It's usually down by the compressor area, about the size of a cell phone. It has a small dial on it that only turns one way. Mark it when the fridge is on with whiteout to see if it moves. It moves real slowly, so you will have to wait a half hour or so.
One way to speed up a defrost is to turn the dial on the defrost timer until it clicks. Then the compressor will turn off and the defrost coil will turn on. The freezer fan should be spinning. Feel the output from the freezer fan- anything? If no flow, you're iced up. Keep checking for flow, eventually it should get cold. When you get good airflow, and maybe it's not so cold anymore, you might be defrosted without having to take the whole thing apart. You may have to turn the dial more than once, if the compressor comes back on before you're defrosted. You can help the defrost with your hair dryer thru the vents in the front of the freezer, but not too hot, you don't want to melt any plastic.
Apr 25, 2009 | GE GTS18ABSWW Top Freezer Refrigerator
Deep Fryer doesn't get up to a proper temp.
9 TIMES OUT OF 10 THE TEMPATURE DIAL ON ANY DEEP FAT FRYER IS NOT FULLY ACCURATE TO MAKE SURE YOUR FOOD IS PROPERABLY COOKED YOU WOULD HAVE TO LEAVE IT THAT BIT LONGER
Jan 09, 2008 | Rival CF275 Deep Fryer
GE (PSS26MSRSS) Side by Side Refrigerator Logo
153 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
