Question about Briggs & Stratton Garden
Gas flow stopped mid mow, tank to carb has good flow,could float have stuck, only starts for a second or two, ??
  • swan0557 Jul 19, 2009
    checked the spark, a-ok. Fuel is not getting thru the carb!!! IF i PUT A SPOONFUL OF FUEL IN THE CARB IT STARTS TO BURN THE FUEL FOR A SECOND. nEED to know where fuel goes as entering carb and start from there. Got spark, no fuel.
  • 8,220 Answers
The ignition circuit starts and ends with the battery. When the engine is running the battery is continuously being recharged by an alternator or, on older systems, a generator. Current flows from the positive terminal of the battery to the ignition switch and an ignition coil. The ignition coil is really a transformer that steps up the 12-volt current of the battery to somewhere in the neighborhood of 25,000 volts. In engines of medium to high compression this kind of voltage is necessary to reliably arc across the gap on a spark plug and make enough fire to ignite the fuel/air mixture in a cylinder.
MORE HERE
Posted on Jul 19, 2009
  • Dan Webster
    Dan Webster Jul 19, 2009
    You must have a restrition in the venturi or a clogged jet. If all else fails put the whole damn carb in a bucket of carb cleaner and soak it a few days.
I just bought a mud blaster 110cc quad for my son, why does it start then 2 min later stop even with feathering the throttle?
#1 sounds like a fuel delivery system issue. Make sure the fuel tank flows freely to the carb. (remove the fuel line from the carb--from the gas tank and turn on the petcock--gas should flow freely) The needle and seat may need to be cleaned or replaced, this controls the flow of gas into the float bowl of the carb.(remove the drain screw from the bottom of the carb (with everything properly assembled- petcock on)..gas should continually flow through the bottom of the carb --10-15 seconds of continual gas flow will make sure its flowing properly! Both of these sound like a solution to your problem.
Jun 22, 2014 | ATVs
MOVER STARTS ONCE THEN QUITS ONLY USED 1 SEASON,HAVE TO SPRAY ENGINE START OR CARBURATOR CLEAN TO GET TO START, RUNS UNTIL THAT EVAPORATE-THEN QUITS,FILTER, PLUGS, GAS ALL CLEAN AND NEW SO AGGRAVATING,...
Hi, my name is Shaun. I will do my best to help you with your problem. By your description, it wounds like you are not getting any fuel to your carbuerator. This may be caused by sticking floats or a clogged needle valve. Try this. First, make sure your gas line is clamped shut or your tank is empty. Then remove the float bowl from the bottom of your carb. This will reveal the floats. Make sure they move absolutely freely. If you look closely, you will see that the floats pivot on a steel pin. Remove this pin to free the floats from the carb. Be careful to pay very close attention to how these parts go back together, especially where the needle valve is located. When you pull out this pin, the needle valve will come free along with the floats. Give the pin, float hinges, and needle valve a good scrubbing with some carb cleaner and a toothbrush. then use the straw attachment to shoot some cleaner up into the hole where the tip of the needle valve was located. Be careful, as there is a rubber gasket up inside there. Then disconnect your fuel line from the carb and shoot some cleaner in there. Reassemble averything except for the float bowl and put a little bit of gas in the tank. Observe the fuel flow from the needle valve. You should have a good, steady stream. Lift up on the floats and make sure the flow stops. If all of this checks out, reinstall the float bowl and give it a few minutes to fill up. Then prime and start your engine as normal. This should clear up your problem and keep you mowing for another season. Hope this helps. Good luck and have a great day!
Jun 21, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Gas flowing out of the hose from the carb
The float is stuck open by some trash at the float needle OR the float is bad and literally does not float any more. Remove the float bowl and clean the carb using spray carb cleaner. Gently lift the float and the flow of gas should stop. Lower the float and the flow should start again. Please rate my answer. Thanks. tombones49_75.gif
Apr 14, 2011 | 2004 Yamaha YZ 125
It starts and runs for 5 seconds and then stops...fuel problem?
I would drain the tank and carb completely and allow to air dry for a day. Then get some fresh gas *(clean out the gas can too) and try it again. If the problem persists the carb probably has fuel flow issues. A stuck fuel float or obstructed needle/seat.
Oct 06, 2010 | Toro Garden
Some water got into my gas can and I put the gas in the mow unaware of it. I mowed for about 30 to 45 minutes when the mow's engine begin to make a popping sound. IWhile draining the gas tank and...
If there is gas in the oil you drained from crankcase the carb is really dumping fuel(did you see black smoke?) If your carb has a drain plug drain it. If not you will have to take off the carb bowl and clean it. Check float operation, turn on fuel work float by hand to make sure gas shuts off when float rises to level position. If not may need needle and seat kit. Or adjust float.
Sep 28, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My Poulan 2005 17.5 HP, 42" mower runs a few minutes, then sputters and either almost dies, or does die. If it doesn't die, it will speed back up and I can mow 20 or 30 feet and it will sputter again, and...
I hope this helps as quickly as it helped me. Try cleaning the small vent hole in the gas cap. I had asked Fixya this question last year and it worked like a charm! Good luck.
Sep 21, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Riding mower 917.270510 abruptly stopped running
As it fired up with ether, your problem is related to fuel flow in the carburator. More than likely, you will have to remove it and clean all the ports. It might simply be the needle valve at the float is stuck, not allowing fuel to fill the bowl enough to be drawn in via air flow.
Apr 15, 2010 | Garden
I bought a 1985 GS 550 LF. It had been sitting for a year, so battery was dead tank & carbs were dirty, clutch cable was broke. I fixed the clutch cable, cleaned the gas tank, bought a new battery and...
Gas pouring out of the carbs means the float pin are not sealing in thus the over flow.
Go a little down thn .77in , best would be to bench set them.
Take a pipe say from the tank to the feed pipe of the carbs (best would be to remove the tank and place it higher on your work bench to get the gravity flow to the feed pipe of the carbs)
Allow the flow to the carbs and monitor the over flow, see which carbs over flow, remove the float bowl and reset the float and let it go a little less thn .77in, refit the bowl and retry the feed in and recheck..you will come to a point where gas wont over flow, open the bowl and see the level of the gas , it should be covering the jets, but remember that since you will have the float bowl out the gas will show low as when its submersed, the jet stem in the float bowl pushes the gas level up so dont get mixed up when you see the level low , i am sure you will be able to judge it for yourself.
I had the same problem in myYamaha(seca) XJ750R !981and finally managed to win over the problem going over it the way I explained.
Hope this helps! Good luck.
Jul 14, 2009 | 1984 Suzuki Gs 550 L
Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Needle and seat are stuck closed
drain the old gas out put some new gas in the tank and turn the fuel petcock to PRI or ON and check that there is a flow of clean gas to the carbs. Tanks that are badly rusted will require a filter in the gas line to the carbs. If not see the Gas Tank Page. If the gas starts to come out the carb over flow tube(s) tap the carbs gently but sharply with a plastic hammer or the plastic end of a screwdriver. Do this to each carb several times or until the gas over flow stops. If it does not stop you will have to take the carbs apart and find out why the fuel valve (needle and seat) is not working. See the Carb page. If it will not start, try to drain the fuel out of the carb with the float bowel drain screw. If nothing comes out, nothing is going in ! In other words the needle and seat are stuck closed. Again, if tapping the carb doesn't start the gas flow, take the carb apart to find out wh,,,
Nov 10, 2008 | 2000 Alfer VR 2000 Supermoto
Garden Logo
89 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
