Question about Enlight Intel Xeon 470 WATT EN-470 MP (EN470MP) Power Supply
My printer keeps giving a paper jam error no paper is jammmed
I have a Brother MFC240 printer that continues to show a printer jam error, but no paper is jammed in the printer. I tried to uninstall and reinstall the software but it still shows the error. Now the printer will not print, scan, copy or anything. It will not even start. HELP!
    Scholar:
  • 106 Answers
Hi....
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
if this doesn't fix your problem then u can go the following links....
1) http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
2) http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/colormfc/mfc240c_all.html?reg=us&c=us&lang=en&prod=mfc240c_all
if these solutions helps you then rate for my solution...
thank you....
Posted on Jul 19, 2009
Brother MFC-8480DN Printer jammming
try to clean the document feeder, i think there so many scratch of small piece of paper that why the printer is paper jam.
Feb 07, 2014 | Brother MFC 7840W Printer
What does error 73 mean? the display keeps giving that error... i have a brother mfc490cw
It is my pleasure to guide you.
The machine does not work due to a paper jam or some sensor problem.
Quote
Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feed Problem.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us" http://www.brother-usa.com/support/CustServ.aspx.
FAQs & Troubleshooting http://welcome.solutions.brother.com/bsc/public/link.aspx?faqid=faq000495
UNQuote
Good luck and please post back that you are successful or that I can be more helpful.
Jun 09, 2011 | Brother MFC 490cw Color Inkjet...
Error 50 of Brother printer DCP-130C
Details of this error code are.
50,51,52,57,5A,5B,5C
5D,5E The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us".
May 01, 2011 | Brother DCP 130C All-In-One InkJet Printer
Paper jams??
click here to download yor required drivers
May 12, 2010 | Brother MFC 6490CW InkJet Printer
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Small piece of paper jammed in my brother 240C. Can't see if but I know it is there. how do I get it out?
  1. Turn the printer off and on to see if it can automatically clearsome or all of the jam. Many printers provide an error-code listing onthe front panel display for the area where the jam occurred. If yourprinter shows an error code, be sure and check the printer manual tosee if that identifies the area of the printer where the jam occurred.
  2. Step 2 Turn off the printer.
  3. Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper.
  4. Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  6. Step 6 266_a1.jpg Ifyou find a piece of jammed paper, remove it by holding it with bothhands and pulling firmly (see A). The goal is to keep the paper fromtearing. If several pieces are jammed together, try pulling out themiddle piece first to loosen the jam.
  7. Step 7 266_a2.jpg If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  8. Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 26, 2009 | Brother Multi-Function Center MFC-240C...
Paper jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 15, 2009 | Brother DCP-330C All-In-One InkJet Printer
Mfc240 all in brother printer
i need the install utilities cd to program my mfc-240 machine
Sep 06, 2008 | Brother Multi-Function Center MFC-240C...
Computers & Internet Logo
245 people viewed this question
Top Enlight Computers & Internet Experts
Larry Maranto
Jerry Umali
Raymond Solomon
Level 1 Expert
Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
