The school is using a D-Link DI-604 fast ethernet router for internet sharing and connected to port e1 on Linksys SRW224G4 + 4port Gigabit Switch with Webview and also have 4 D-Link DES-1024D switch and connected to port e5,e6,e7,e8 on SRW224G4 switch. I created 4 VLANs, vlan10 on e5, vlan20 on e6, vlan30 on e7 and vlan40 on e8. The computers are connected to the DES-1024D switch and have a sharing of files. That?s why all PCs can communicate to the other PCs and also to the other 3 DES-1024D switch. The DES-1024D switch 1 are installed on Computer Lab. Switch 2 are installed on Accounting Office. Switch 3 on Admin Office and Switch 4 on Faculty Room. The connection of PCs on Computer Lab can access the shared files in the other PCs in the offices (Accounting, Admin and Faculty Room) that are strictly prohibited. I want to secure the PCs in the Accounting, Admin and Faculty to not to access those shared files. In short all I want is the PCs connected to vlan10 cannot access the PCs in vlan20, vlan30 and vlan40 connected computers. So how do I configure my SRW224G4 for that?
  •  Robert
    Robert May 11, 2010
    That is very strange. If they are on different VLANs, then that should not be possible. Are you sure those VLANs are assigned to the respective switch ports? Those different VLANs are on different subnets right? The only other thing I can think of is maybe inter-VLAN routing is somehow configured at the router. To test that, do a traceroute from one host in one VLAN to another host in another VLAN. If that's what is occuring, you will probably have to configure some ACLs (Access Contol Lists) on the SRW224G4. If all else fails, replace the DI-604 with a Cisco router. One of those can handle VLAN traffic better.
    Novelist:
  • 154 Answers
Here's a link to the user manual and other information that will help you.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Aug 03, 2009
I need to know if the D link DI 604 Router can be used for a wirless networking
No, is the short answer. It only has the 4 ports which have to be wired with ethernet cables. So this Router is a wired router.
Mar 25, 2011 | D-Link DI-604 4-Port Cable/DSL Router...
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
Configuration:
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type 192.168.0.1 on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to 192.168.0.5 & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
Sep 15, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Cant share internet using a router
Hi There, what model of dlink router do you have?
Also, Or just check the ports you have in your router, the internet should be connected to the WAN port and the switch and/or computers to the LAN port(s).
If the router is new by default you should be able to access internet by plug everything the way I told you.
Also, by default the router ip address should be 192.168.1.1, type that into your web browser address bar, then you will have access to the router admin web page were you can see the status page, there will tell you if you have or not access to Internet really. Maybe the problem is that the router have no access internet access at all.
Mar 12, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Switched internet service providers now the router doesn't work
You might want to check the routers settings to make sure that it is not configured to use PPOE connection which is for DSl and the Broadband connection. You can find the routers address by searching google. Linksys uses 192.168.1.1. You can always try resetting the router by pushing the reset button usually found by the power plug in the back.
Feb 19, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
How to connect di-604
i connected with DI 604 since then i can not view the photos on my friendster account
May 09, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
D-link di-604
I have no success disabling the DHCP server. For me at lease, this will not work
Apr 02, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
348 people viewed this question
David Payne
David Payne
