Question about White Mountain F69206X 6 Quart Ice Cream Maker
My barrel on my white mountian ice cream is leaking from the seams of the wood. it is only one year. its not allowing the brime to come from weep hole
  • 864 Answers
The wood will shrink when it is dry. It will swell up and close the seams if kept wet. Place the barrel in a container and fill with water inside and out to get the seams to swell and close before you use the freezer to make ice cream.
Posted on Jul 19, 2009
On the soft Serve side of my Taylor ice cream machine it is freezing up and not letting any product come out pump still works don't know what the problem is I take everything apart clean it put it back...
if the product is frozen in the barrle for sure then you have a bad micro switch that is telling the compressor to keep running, but that product would be super frozen and come out in the shape of the barrel. if it is the consistancy of ice cream then your pump gasket might be bad and not properly pressurizing your barrel and giving you the impression of a frozen barrel.
Feb 19, 2015 | Taylor Ice Cream Makers
White Mountain 69204 ice cream motor gear slips
Sometimes the gears in the unit become worn and have to be replaced. This might help.
White Mountain Ice Cream Freezer Motor Repair
Sep 04, 2013 | White Mountain F69206X 6 Quart Ice Cream...
Barrel Therm Bad, keeps beeping on right side
Pretty much what it sounds like, the thermometer in the freezing chamber (barrel) died, and you can't operate until it is replaced. Drain all yogurt and clean and unplug. You need to call a technician out; call 800.255.0626 to find out your local service center.
Sep 15, 2012 | Taylor Crown C713-27 Soft Serve Ice Cream...
I was wondering, I have two two barrel taylor soft serve machines from an old Carvels Ice cream store. The model numbers are c-712-33 and 8771-33, They were on a glycol machine, DO you have to have a...
This particular Model C712-33 goes into a heat cycle every 24 hours depending to pasturize the mix ,usually good for two weeks.Then the machine must be brushed cleaned.The timer can be disabled as to allow for regular operation.
Jan 18, 2011 | Taylor 632-27 Ice Cream Maker
Why won't the freezer freeze the ice cream? It freezes around the outside of the cannister only.
According to White Mountain, this happens because the ice brine gets too cold. The procedure they recommend is as follows:
After you put your cream can in the tub and attach your crank or motor, fill the tub with ice and run for two minutes to cool the cream can. Then, put two cups of rock salt on top of the ice and let it continue to crank. After the ice level has dropped 2-3 inches, put more ice on top and another two cups of rock salt and let it continue to crank until the ice cream is done.
Sep 24, 2010 | White Mountain F69206X 6 Quart Ice Cream...
NOT FREEZING PROPERLY
If your outer bucket is leaking down the liquid brine solution it won't freeze properly. The rival buckets are bad about leaking. You might try pre-conditioning the outer bucket before making your attempt at freezing. Just fill the bucket to the weep hole with water and let it sit for about half an hour, then pour out all but about 4 inches of it and start adding ice and salt.
Jul 04, 2010 | Rival 8550-X 5 Quart Ice Cream Maker
How long does it take to make ice cream?
Not long at all, maybe 20 minutes.
Jun 02, 2009 | Ice Cream Makers
I need the directions for the Rival 8550 Ice cream maker
Fix Icecream mix as dircected on internet or where ever you get the recipe. Then layer ice and rocksalt around the out side of the aluminum can and then start motor.. takes about 20 minutes. or when can stops, but if you wait this long.. good chance of breaking the dasher ( mixing paddle). Note: if you have the wooden bucket, soak it in warm water for about 15 minutes to get the wood to swell and seal up.
Jun 24, 2008 | Rival 8550-X 5 Quart Ice Cream Maker
Musso Ice cream maker freezes and then heats up during use
go to Http://www.catering-machines.com they have full list of spares or parts for Musso stella.
All parts for the musso ice cream machine including lid, motors, gear wheels, gearbox, musso paddle Musso serial numbers start L1 = Musso piccolo L2 = Musso stella L3 = Musso Club L4 = MUSSO CONSUL.
Jan 14, 2008 | Musso Stainless Steel Pola Ice Cream Maker
White Mountain F69206X 6 Quart Ice Cream Maker Logo
492 people viewed this question
Top White Mountain Ice Cream Makers Experts
Andrew Taylor
Andrew Taylor
Are you a White Mountain Ice Cream Maker Expert? Answer questions, earn points and help others
