Question about Dirt Devil Easy Steamer Upright Wet/Dry Vacuum
I need a new manual for dirt devil easy steamer deluxe
Where can I get a another one?
  • 15,935 Answers
CLICK HERE for the owners manual in PDF format.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 19, 2009
I have water coming out of the side of what it looks like to me the pressure relief valve that is white. It happens when I pull the trigger, how can I fix this problem
Posted on Nov 14, 2011
5 Suggested Answers
SOURCE: Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Posted on Jan 24, 2008
SOURCE: dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Posted on Mar 28, 2008
luckyluke78
  • 333 Answers
SOURCE: How to clean Dirt Devil Easy Steamer Deluxe Carpet
You can download manual here:
See page 9
http://www.dirtdevil.com/CustomerService/Manuals/DirtDevilManual.aspx?ManID=8fac8b06-4ad7-49a7-ac82-6f608a77a3bb
Please leave positive feedback if I have helped you
Thankyou
Posted on Aug 09, 2009
  • 694 Answers
SOURCE: I have a Dirt Devil
I believe the following manual is for your machine. It's model # MCE6600. It's what comes up when a search is done for Easy Steamer Deluxe.
http://www.dirtdevil.com/manuals/?id=c6f182b2-b418-447d-951f-ca9456153b3d
Posted on Jan 10, 2011
Need manual for dirt devil handheld streamer pd20005
Many Dirt Devil manuals are available here: https://www.dirtdevil.com/manual-video-search/ . The PD2005 manual did not show up here. I did find it at Manuals Lib here: https://www.manualslib.com/manual/732336/Dirt-Devil-Pd20005.html . I also found the manual on the product page on the Dirt Devil MX site: http://www.dirtdevil.mx/easy-steam-handheld-steamer . The direct link to the manual here was http://docs.wixstatic.com/ugd/5ae076_fc923157085a43cb90e2113e69a6f7be.pdf . The manual is in English and Spanish, even though the host site is in Spanish.
I hope this helps.
May 19, 2018 | Dirt Devil Vacuums
I need an instruction manual for the Dirt Devil easy Steamer CE7 100, Code COOB Can you help me out with this?
Go to the Dirt Devil product support website and if it is available download it there.
Jul 07, 2017 | Dirt Devil Vacuums
I have a Dirt Devil easy Steamer delux,but lost the owners Manual,forgot how to use it ,can you help ?
Jan 10, 2011 | Vacuums
Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
Sep 04, 2009 | Dirt Devil Featherlite Easy Steamer Vacuum
Dirt devil easy steamer need directions to use
Mar 27, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Ok, perhaps I am an idiot!
If you go to this URL: http://www.dirtdevil.com/CustomerService/Manuals/default.aspx ...and enter the model number for your machine, then you can download a users manual. I would just give you the exact URL for the user manual, but I don't know your model number. If this helpful to you, please leave a good rating. Thank you! ;)
Aug 13, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Jul 15, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt Devil Easy Steamer Upright Wet/Dry Vacuum Logo
1,937 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
