Question about Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Natural Gas
Electronic pilot lights but unit will not fire
  • 864 Answers
Make sure the pipes are full of water. Check the thermostat to see if it is calling for heat. Make sure the thermostat is set to a temperature higher than the current temp of the water. If all those things are OK then the gas valve coils may have to be replaced.
Posted on Jul 19, 2009
Where can I find these coils?
Posted on Jul 20, 2009
Tip
How to fix Raypack that Runs for 2 minutes and then off with PLT on Screen
If your Raypack (mine is a 2100 but most have the same electronic ignition pilot) lights and runs for about 2-5 minutes an then shuts off, you need to clean the pilot sensor. The pilot sensor tells the unit the Burners are running. If the pilot sensor becomes corroded, carbon, etc. the unit will light but will shut off after a few minutes as it thinks the unit is not operating properly. The unit will try to re light, but fail, and then PLT will show on the main programming screen. To fix the probelm, shut off the unit power. Remove the pilot assembly which is located at the bottom right of the unit. There is one screw holding the pilot assembly in place. Gently remove the pilot assembly. There is a fork like probe sensor (not the one with ignition and gas feed) that needs to be cleaned. Take some rough sand paper and clean it thoroughly. Re insert pilot assembly and fire the unit. If this fails, clean the sensor again. Problem solved!
on Sep 25, 2010 | Heating & Cooling
We have a full tank of propane and the Rinnai RHGF 1001FA and is not lighting. does this unit have an electronic starter or do we need to light the pilot?
Caution This unit does not have a pilot do not try to light with any lighter or match. This unit uses "Electronic Ignition"
Sep 16, 2011 | Heating & Cooling
Not getting hot
The users manual, located HERE only has basic tips to check if the unit isn't firing or getting hot, As there is no pilot light, it seems that it is probably the unit's electronic spark that could be the cause. Does it give you a code on the display?
Sep 01, 2011 | Blodgett DFG-100 Gas Single Oven
I was called out because a tennants water heater wasnt working. I tried to restart the pilot. but nothing happened. I checked the gas line and it was getting gas. I checked the electronic starter and it...
if the heating element is out, the pilot will try and start , but if the thermocouple in the unit itself isn't letting the gas release,, it isn't going to fire up , Check the thermocouple , if its built into the controller valve,, your either going to have to replace that ( if its possible on that unit,, ) or get a new water heater
May 08, 2011 | General Electric Water Heaters
Water not hot even thermostate turned to high. The pilot light is on. Shoulder I be able to visualise the burner actually firing.,or hear it firing. I can see the pilot light clearly. Please help
If you have cold water now, you should hear the unit fire up and run while heating water. Proceedure would be; pilot is lit with thermostat at pilot setting. Once pilot is lit, you turn up to desired temp setting and you should hear the heater running. Depending on lighting, you should be able to see it slightly brighter and may flicker some while heating.
Apr 25, 2011 | Rheem Water Heaters
Pilot light on baxi bermuda 51/5 electronic, gas fire wont ignite, calling for heat but still doesnt ignite or click
Sometimes the thermostat wire (not sure of the technical name) gets oxidized and can't sense the heat (it's there as a safety measure so that when the pilot light goes out, the gas shuts off). If it isn't to hard to get to, sometimes you can use some aluminum foil to clean the wire so that it senses the heat of the pilot light flame. Make sure the main unit is off, and let the unit sit for awhile to make sure there is no residual gas hanging around. If this doesn't work, you might have to get a specialist out to replace that piece. Hope this helps.
Feb 17, 2011 | Heating & Cooling
How to replace a pilot
Probably no need to replace pilot. Just clean it. If your Raypack (mine is a 2100 but most have the same electronic ignition pilot) lights and runs for about 2-5 minutes an then shuts off, you need to clean the pilot sensor. The pilot sensor tells the unit the Burners are running. If the pilot sensor becomes corroded, carbon, etc. the unit will light but will shut off after a few minutes as it thinks the unit is not operating properly. The unit will try to re light, but fail, and then PLT will show on the main programming screen. To fix the probelm, shut off the unit power. Remove the pilot assembly which is located at the bottom right of the unit. There is one screw holding the pilot assembly in place. Gently remove the pilot assembly. There is a fork like probe sensor (not the one with ignition and gas feed) that needs to be cleaned. Take some rough sand paper and clean it thoroughly. Re insert pilot assembly and fire the unit. If this fails, clean the sensor again. Problem solved!
Sep 21, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Have a Raypak RP2100. When I turn it on the pilot lights fine but after a few minutes (~30 minutes) the heater turns off and PLT is indicated on the control panel. If I recycle the power it lights fine and...
Aug 01, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
William forshaire 435 runs well for awhile until
Try cleaning your thermocouple,and resetting it where was, which is located at the pilot flame. this should solve your problem.
Feb 23, 2010 | Heating & Cooling
Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Natural Gas  Logo
406 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
