Question about Uniden Lands Phones
Wifi interference?? does the uniden cordless phone model 3315 interfere with wifi broadband?
  • 199 Answers
The short answer is that it could interfere with the wi-fi, but your wi-fi should not interfere with your phone because it uses WDECT, "wide-band digitally enhanced cordless telecommunications" engineering. No matter how tight the bandwidth is on any RF transmission, power, proximity, and harmonics all play a roll. Ideally we want the power from our transmission to occupy the target frequency but the reality in RF is that this is nearly impossible without DSP filters. I have pasted some extra info below to help answer this question.
Digital Enhanced Cordless Telecommunications
(DECT), known as Digital European Cordless Telephone[1] until 1995, is an ETSI standard for digital portable phones (cordless home telephones), commonly used for domestic or corporate purposes. It is recognised by the ITU as fulfilling the IMT-2000 requirements and thus qualifies as a 3G system.
The four most common frequencies today are 900MHz, 2.4GHz, 5.8GHz and DECT 6.0:
900 MHz Currentlythe most common frequency for cordless phones, 900MHz phones may offera greater range than other frequencies. However, the 900MHz spectrum iscluttered and may result in interference with baby monitors and other900MHz cordless phones. Radio scanners can also easily pick up thisband. 2.4 GHz 2.4GHzphones offer better clarity and security than 900MHz, but mayexperience some interference with microwave ovens and wirelessnetworking (wi-fi) products. 5.8 GHz Themost advanced cordless phones available, 5.8GHz phones transmit on anew, open frequency and have the least chance for interference. Theywill not interfere with wireless networking (wi-fi) products. DECT 6.0 DECT6.0 operates on the 1.9GHz frequency. Though newly approved in the US,this frequency has been used for many years in Europe and can increasecall clarity and security. The wi-fi friendly DECT technology easilyintegrates into homes with wi-fi and internet services because the1.9GHz frequency is exclusive to DECT, making it interference free forcordless communications.
Posted on Jul 19, 2009
SOURCE:
We have a Uniden N32 Model XDECT7055. How do I remove the red flashing light on top of all the phones.
If that is the Voice Mail Waiting indicator light at the top of the handset and on the base, you need to press Menu on the base. Use the up/down arrows to select VMWI Reset. Press Menu again to select this sub-menu. Use the arrows to highlight Yes and press Menu again. You may need to contact your telephone company to make sure that the voice mail service is still compatible with the Frequency-Shift Keying message notification. Some broadband (particularly DSL) systems can cause telephone interference. Check with the broadband provider if you need a DSL filter (or similar item) to keep the interference from corrupting the VMWI information.
The procedure is on page 17 (19 of the PDF) of the manual for the Uniden XDECT7055. This is available here: https://www.uniden.com.au/resources_main/pdfs/XDECT_7055_3WP_OM.pdf .
I hope this helps.
Jul 23, 2016 | Uniden Cordless Phone
Only get static when answering machine comes on to record
Check for interference from appliances (microwave ovens, TVs, etc.) or wireless devices (baby monitors, WiFi equipment, etc.). Move the handset or base away from the interference source.
Jun 16, 2015 | Uniden D3097 Cordless Phone w/ Wireless...
Will a cordless phone interfear with your internet or the cordless phone if its to close to your internet box?
A wireless router and wireless network adapters can have interference issues with cordless phones. It depends on the network adapter frequency and the cordless phone's frequency. Most problems will occur with a phone that uses 2.4GHz. This frequency will interfere with 802.11b/g networks and single-band 802.11n wireless signals.
A DECT cordless phone operates at a different frequency from the 802.11g and 802.11n single-band and will not interfere with a wi-fi network with those modes.
However, some routers and wireless adapters can use the 5GHz range (802.11n and 802.11ac, among them). These can have a problem with cordless phones that use 5.8GHz. However, there is a simple solution to avoid much of the interference at 5GHz. First determine the frequency range of your phone by getting the FCC ID from the base of the phone. Then use Google or another search engine to find "FCC ID Search Form". It has been at http://transition.fcc.gov/oet/ea/fccid/ in the past. The first three characters are the Grantee ID for the search form. The rest is the product ID. Look for the SAR report for the phone and then (probably on the second page) find the TX frequency range and the Max RF output power tested. Now go to the wireless router's setting page and make sure that it is using channels that do not use the same frequency and power range. See http://bradsfavorite.com/avoid-interference-5-ghz-wifi-5-8-ghz-cordless-phones/ below the 5GHz Wifi Frequencies for a table with the channel and frequency ranges for routers.
I hope this helps.
Nov 01, 2014 | Lands Phones
We bought a Panasonic KX-TG 8321 AL cordless phone last christmas and it was working well until recently. It suddenly started picking up interference from the adsl wi-fi transmitter to the point we need to...
Unfortunately the EMI/RF interferances are a conflicting part of our day to day life.
Now you have this conflict of the wifi with your cordless to interfere.
So one option is to keep the base phone off to another location away from the wifi.
Move the antennae away from the strong signal pick up to lessen the interference. If porblem started recently it can be fault in the base unit changing. frequency
Sep 28, 2010 | Panasonic Cell Phones
Can the d-link dir-615 interfere with the telephone?
It can interfere with cordless phones. It won't with a wired phone.
The cordless phones operate in the same frequency band so sometimes they wil interfer a bit. What will hapeen is the voice or sound quality won;t be as clear or if real bad it will drop calls. The 2.4 and 5.8 ghz phones can have problems with the wifi and the microwave.
The newest Dect 6.0 style phones are designed to be immune from both microwave and wifi interferance. We went through a series of phones at home before we found out about the DECT 6.0 types and all of our problems went away.
Jun 02, 2010 | D-Link DIR-615 Wireless Router
My phone cuts off laptop wireless
Wifi typically operates in the 2.412Ghz - 2.472 Ghz depending on the channel selected. ideally the Wifi modem/router and the DECT phone should be operating in completely different bandwidths.
If your DECT phone is cutting off your Wifi wireless connection, then they must me operating in similar/same range: you need to change either your Wifi or DECT frequency 'channel' to minimize this interference.
Also make sure that there is a least 3 meters between the DECT base station and your Wifi modem/router to eliminate Transceivers static RF/EMF interference.
Hope it helps: let me know how you go.
Jan 12, 2010 | Uniden Cordless Phone
Uniden 3315 Frequency Problem
Your phone has Digital Enhanced Cordless Telecommunications (DECT), known as Digital European Cordless Telephone[1] until 1995, The digital filters will prevent interference from the bandwidths used by phones and wi-fi.
Your phone also incorporates dynamic channel allocation which switches frequencies when noise(static) is encountered.
Eventually your conversations take a wire route down the road. You are getting some "cross talk", an actual scientific term used to describe signal transmission from one line parallel to another by magnetic eddy currents. I would call the phone company and have them trace the problem.
May 13, 2009 | Uniden Lands Phones
Extra Static on the phone recently
Try and position the base away from any sources of interference. The most common interference is caused by wifi or wireless routers and microwave ovens. Both these operate on similar frequencies well in your case a harmonic of anyways. If the antenna is adjustable on the base try and tweak it alittle and make sure the base is in the horizontal position. Hope these hints help.
May 07, 2009 | Uniden 5.8GHz Cordless Phone
GE Dect 6.0 Cordless - Loud Static
question is are you running a pc and router/ modem on the same land line
if so you will need the line filters to the phone base
the computer data is transferred by the same land line and there is every possibility that the different frequencies is what is causing the static
reference from a uniden trouble shooter ( will be common as the phones use the same medium)
lots of noise or static on the line === possible solutions --check for interference from appliances ( microwave , tv etc ) or wireless devices ( baby monitors wifi equipment etc)
move the handset base away from the source
if you have any device that uses the phone line , add a DSL or telephone line filter to the system
it is possible from the times you state that the interference could be coming form a neighbour or further down the line so the filter may be the option
available from phone shops or places like JAYCAR
Jul 11, 2017 | Uniden Cordless Phone
Open Questions:
RE: Uniden D1384 2 Cordless Phone Handset System;Both Phones Use BT 1008 2.4V 700mAh Batteries Please answer each question separately and clearly without unnecessary information. ---- I have 2 cordless phones, one on the base and the other on the charger. ---------------------------- 1a. Even though the base and charger are plugged in, there is no safety hazard removing the batteries in both phones because only the wireless signal between the handset in the charger and the main base AND the wireless signal between the phone in the base and the base itself will be interrupted-Is that correct? ---------------------- b. If the battery is removed from the phone on the base, can the phone on the charger still make outgoing calls and receive incoming calls? ----------------- c. If the battery is removed from the phone on the charger, can the phone on the base still make outgoing calls and receive incoming calls? --------------------------- 2. For safety reasons, should I be home while a new battery is charging for the first time or is that unnecessary? --------------------- 3. Since there is no safety hazard removing the batteries while the base and charger are plugged in because only the wireless signal is interrupted, is there a safety issue if one of the phones happens to ring while the battery is being removed? ------------------------ 4. Can phones remain on the base and charger once fully charged or does doing that have a negative effect on the batteries? I always place the phones back on the base and charger immediately after use and when not in use. ------------------------------- 5a. Can disconnecting a fully charged battery in order to check the specs on it and then reconnecting it 5 mins later without making or receiving a call reduce the charge meaning that is normal for it to recharge for up to 5.5 hrs once the battery is reconnected and the phone is placed back on the charger OR should the full charge remain the same as before the battery was disconnected because the phone was not used to make or receive a call? --------------------- b. Is it 'bad' for the phone/battery/both to keep removing a fully charged battery OR does removing it just increase the charging time when the battery is reconnected? ------------------------ I appreciate the insight. ----------*Also, My questions are 'spaced out' while typed but appear as a long paragraph when 'updated'-How can my questions appear separated? ------------------------ *Is there an option to receive email alerts when someone replies to my thread (so that I do not need to remain signed in)? ------------------------
Jun 17, 2019 | Uniden Lands Phones
Lands Phones Logo
1,872 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
