Question about Lexmark X8350 All-In-One InkJet Printer
Printer dead, no lights, not powering up at all
The printer is completely dead. No lights, no sign of power. The only sound from it is a steady clicking when the power source is connected. The outlet is good and the power source is putting out 30W.
  • 42 Answers
Your power supply is probably dead you will have to replace it
Posted on Jul 20, 2009
Replaced the power supply TV was completely dead no blinking nothing replaced the power supply got green steady light but no sound or picture just green light fans TV stays on until i shut it off remo
ReCheck the connections.if the original power supply burnt out due to a short or system failure then you will need to check all the module boards for any evidence of burning.check the capacitors for signs of swelling or splits as these are usually the cause of no life.also I assume the power supply was the right volt/ amp as this May have blown an on board fuse on the main pcb.
Jan 11, 2015 | Pioneer PureVision Pro-1410HD 61 in....
No power
If it is not getting any power at all, only one of three things: cord is fried/dead; could be the outlet, try something else in the same socket; or, the board in the printer is dead.
1. Press the POWER button to power on the printer The device has a <POWER> button.
Connect the power cord from the printer to the electrical source.
Press the <POWER> button.
Wait until the device has completed its cycling process before submitting a print request or completing installation.
2. Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
  • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
  • Then reconnect it.
  • If you are still unable to obtain power to the device, try another power outlet.
  • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
3. Disconnect and reconnect the electrical cord to ensure a secure connection 4. The iP6000D may require repair
For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
5. Try a different electrical source / outlet
this will surely fix your problem..
Dec 06, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
How do you jump start a 2007 yamaha vstar custom 650?
Sounds like the battery is dead, charge it or renew itTo jump startAs the battery is so dead remove battery leads & connect to a decent power source
Dec 29, 2011 | 2007 Yamaha V Star Custom
Why is my samsung clp making a clicking noise?
Is the printer making a clicking sound when it is printing? Or is it just making a clicking sound but there are no light and the printer appears to be dead except making a clicking sound?
I know of a cause for either case.
Case 1. It is clicking when printing. Sometimes the toner cartridges are not seated properly in the imaging unit, and causes the gear on the cartridge to slip making a clicking sound as the gear is being turned. Try pulling out the cartridges and try turning the gear. It should turn smoothly without binding. If it binds, there is not much you can do about it except replace it when it goes empty. Reinsert the cartridge and check that it inserted completely into the imaging unit.
Case 2. Printer is dead, not printing except making a clicking sound. This is due to the power supply board failure. Usually the failure is due to a blown filter capacitor on the power supply board. The power supply is located on the right side of the printer. Remove the right side panel to get access to the board. The board can be either repaired or replaced. Hope this helps you.
Feb 22, 2011 | Samsung CLP 300 Laser Printer
My HP C4280 makes a loud clicking noise before it begins to print
Try perform these steps as --->
Please perform these steps as please disconnect the power cable and press the power key for 30 seconds and at the same time connect the power cable then turn on the printer and let me know the status
And also perform this steps as 1. Disconnect and then reconnect the power cord.
2. When the lights begin to flash, press and hold On and Copies button.
When only the On light is flashing, release the buttons.
When the On light is steady, 1. Disconnect and then reconnect the power cord.
When the On light is steady, the reset is complete. the reset is complete.
If the printer works then good
Otherwise Hardware issue
Jul 30, 2010 | HP Photosmart C4280 All-in-One InkJet...
HP 1700n laser printer. Won't reset.
Hi, first; lets’ start from scratch. Turn off your (Computer), turn off the (Printer), unplug the printer from the power outlet; do not make any changes to the computer. Disconnect (all) the printer cables from the computer; reconnect the cables to the computer, and plug in to power outlet. Turn on the computer (first), turn on the printer. Go to; Control Panel, (Hardware and Sound), click Printer; if the Printer is present; click to open, Properties, click (Drivers): Update Drivers. Restart computer. Thanks paul7of9
Jan 12, 2010 | Dell 1700n Laser Printer
Dangerous on road shutdowns.
Well it sounds like you are having complete power losses, so we'll start at the source, the battery. Check the connections to the battery, make sure they are completely tight and clean.  If there is any corrosion at the terminals disconnect them and clean everything with a wire brush.  Inspect the battery cables for corrosion, trace the negative cables to their connections, and pay particular attention to the connection points on the body and the engine block. Make sure these connections are clean and tight. Trace and check the positive cables (being careful with exposed parts of wires that could shock you) to their connections at the alternator and the power distribution block located behind the battery.  It doesn't sound like a bad battery, but if you notice bloating or cracking, have it thoroughly tested. It sounds like the problem should be isolated to the power source (battery, cables, and distribution block), as no other component failure would cause a complete lack of power to all vehicle systems.  Let me know how this goes, and we'll go from there.
Dec 14, 2008 | 1996 Jeep Grand Cherokee
Electrical Problems
Do not leave the car in the garage without the battery disconnected until you locate the source of the smoke, the best tool to find the smoke's source is your nose, smell the area around the source of the smoke, if you smell a really nauseating smell you found it, then look for signs of burnt wires or burnt components, also look for any oil that may have caused the smoke, but I doubt that was the source, this sounds electrical. I know of no problems for your car that would cause this, so most likely it is not a common problem.
Oct 19, 2008 | 2003 Mazda Tribute
Lexmark X8350 All-In-One InkJet Printer Logo
270 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
