Question about Pentax 67II Medium Format Camera
Not winding on
Out using the camera today just suddenly stopped winding on half way through a film, just seems to have jammed up solid??
Are you in a humid climate? take out nthe battery and clean with a dry cloth. if no good press the camera against your body and take a few shots-a waste but checks the wind on.
Posted on Jul 21, 2009
Everything seems to function well, actually, I've never used this camera. Got if off of ebay, so maybe I was gypped. Anyways, the film advance lever seems to be stuck. It only goes half way. I can put...
DO NOT force it. It's going to need to be opened up by a technician and checked out. It may, or may not be repairable (or worth repairing). Batteries will have nothing to do with whether or not the wind lever will function. It sounds like the camera has jammed on someone, so they sold it off (probably without stating that little issue). The Chinon cameras aren't especially high-end, you can probably buy 10 new ones for the cost of having that one repaired, but you'll only know by finding a shop and asking.
May 30, 2011 | Photography
After develop the pictures i found that some images are completely blank and the images are cut into half. Half develop and half not. what the cause of it?? thanks
Might be film coming loose when inserting in loading spool and skipping when winding forward after making a shot. Could try bending first 1/2" of film tongue before inserting in slot in windup spool so that it won't slip out and be sure film sprocket holes are engaged with film transport sprockets and a bit under tension when loading film before closing camera cover. Your 'half-frame' problem might be that you are shooting at a 'flash' shutter setting of 1/60 when not using flash.
Oct 08, 2009 | Canon EOS 5000 35mm Film Camera
Hasselblad 500cm body frozen/jammed
Check the release button lock tab, it may be engaged, holding the release button in
Aug 17, 2009 | Hasselblad 503CX Medium Format Camera
Jammed canon at1 slr
Believe it or not, i just put a new battery in it and BINGO, back to life again....cheers G.
Jul 22, 2009 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Stopped taking pictures
How old is the film in camera & when did you put in the film?
Polaroid's battery is built in with the film package.
If the package is old or been in the camera for a long time battery may be low or dead.
Try changing film out.
Good Luck! Hope this helped. Please rate.
MSG back if you need more help.
Mar 11, 2009 | Polaroid OneStep Express Instant Camera
Minolta X300 camera
Hello
First thing to check with this is are we are talking about the correct part of the camera, the rewind lever on this model is on the left hand side (as you look through the camera), make sure you have raised the rewind crank arm (small plastic arm) out of the central knob, then looking on the bottom of the camera you should find a recess with a chrome button in it, push this button in, it releases the wind on mechanism, you should now be able to rewind the film using the crank, make sure you follow the direction of the arrow on the arm otherwise you will wind the film into the canister backwards, this will make it very stiff to wind and maybe scratch the film, plus you processor will not like you for this either.
Aug 16, 2008 | Photography
Weird film exposures
check the developed film if the sproket holes are intact.
check your camera without film.
(1) open the back, do it as if you were taking pictures with different apartures/shutter speeds. If you can see the light coming in from the lens (no matter how little or how fast), your shutter and aparture diaphram are good.
if not, send it for service.
(2) if yes, check that the winding sproket wheel turns when you advance film.
(3) if it goes freely, try it again with finger pressing the sproket wheel. if this stops the wheel to turn, it is the gear/shaft inside disengaged. send it for service, of course.
(4) if your camera has a button for multiple exposure, ensure that it can be turned on/off as you wish, or you do not pressed it unnoticed.
good luck
pc-cook
Jan 19, 2008 | Nikon N55 35mm SLR Camera
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Nikon N50 SLR film
Hi: You may want to try changing the aperature setting,or removing the lens,then re-installing the lens. Good luck.
May 29, 2007 | Nikon N50 35mm SLR Camera
Pentax 67II Medium Format Camera Logo
155 people viewed this question
Top Pentax Photography Experts
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
