I use HP laserjet m1212nf MFP, but if i try to install the scanner, m1210 driver appears. i cant find exactly m1212 driver. tnx
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
SOURCE: Looking manual for my HP LaserJet M1212nf MFP,
You can get one from HP.com, I reccomend downloading the current install directions and software, all which should be for free. Follow the directions exactly, many HP printers only partially function if you plug and play.
SOURCE: HP LaserJet 3050 - can't scan to a pdf format
This is the only solution I found within the software. I went to the actual printer and hit the 'scan to' button. I selected SETUP from the menu options. It pulled up some software on my computer that shows the interface between the computer and the printer. I hit the NEW button. The next screen gave me some options and there was a checkbox option that said 'Show the TWAIN dialog after the scan...'. I checked that box. When I went to the next screen, it offered me PDF as an option and I made that my default. This process sets up a new menu option on your drop-down list when you scan. I named it 'PDF to computer' so I would know to pick it for pdfs. I tried to add it to the list of options available on the printer menu, but the new option I created disappeared after I hit UPDATE. But when I tried to scan something it was showing on my options list. When I tested it, it opened some software I never saw before and showed the image as it scanned, which I guess relates to the checkbox I marked. I've tried several times for hours at a time to find any kind of fix for this that didn't involve converting a file to pdf or loading a different software. This fix I found on my own just by hitting buttons on the printer. If you don't like this option, there is some free software out there that uses the scanner to create pdf's. I just didn't want to go that way.
SOURCE: HP laserjet M1212nf MFP fax
HP laserjet M1212nf MFP fax memory full, how can I clear the fax
