Fuel Shutoff Valve 'A' Control Circuit/Open
http://www.autocodes.com/p0005.html
Please see my tip at http://www.fixya.com/cars/r5932051-check_engine_light_check. These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
The electrical connector to the IACV
can have 2 or 4 pins:-
pins: resistance between pins should about 10 OHMS +/- 3 OHMS. Resistance between either of the pins and the
valve body is greater than 10,000 OHMS
pins: resistance between diagonally positioned pins should be about 20 OHMS
How to fix? If the motor of the IACV has failed
then replace it. If the valve is gummed closed by baked
oil and carbon then clean it thoroughly with carburetor choke cleaner spray and
a cloth. Similarly if the entry and exit ports on the throttle body to the IACV
look blocked again clean them out thoroughly.
2) Throttle position sensor - How to check?
The socket for electrical connection with the TPS has 3 pins, one for
'ground', one for 5 volts 'reference' and a third (generally the middle one)
for 'signal' output. Back probe the signal pin in the connector to the TPS. Attach the positive lead of a voltmeter to
the probe and measure the voltage output as the throttle plate is rotated. If
working correctly the meter should show a voltage consistent with the throttle
position from approximately 1 volt when closed and 5 volts when fully open.
What is looked for is smooth
voltage increase with throttle change.
If there are drop outs in the transition or that there is no transition seen
the TPS is faulty.
How to fix? If the track is dirty causing drop outs, try cleaning it with residue-free electrical cleaning spray. If the track is worn it is perhaps easiest to replace the complete device. In some instances it may be possible to adjust the location of the central mount of the TPS contact arm along the throttle shaft by a few millimeters and in the process cause a fresh concentric region of track to be used.
