Question about Vacuums
I lost my manual, and can't figure out how the machine sucks up the water?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
Hi, its hard to determin without knowing the make and model number of your machine, if you can get back to me with a make and model number i can try and locate a manual for you :-)
Posted on Jul 19, 2009
What cause it to stop sucking up the water?
has anyone answered.you or figured it out yet I just bought one and the suction wont work at all not from bottom or the attachment part heat works solutions works no suction at all help!!!please email me at taraamcgavran20@gmail.com
Jan 17, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
My steam vac stopped sucking up the water. How do
Hi There,
Here's a link to the instruction manual for your Hoover SteamVac. There is a trouble shooting guide in the back of the book that will explain how to check no suction problem.
If none of these suggestions fixes your machine, please just refer to my answer below the link, these are the problems you may have.
Here's the link:
http://www.hoover.com/pdfs/manuals/F5914900.pdf
There could be several problems that would cause the dirty water tank to be empty after you've cleaned the carpets. I'll try and walk you through each to help you diagnosis the problem.
Possible Problem #1: The dirt water tank lid may be the reason the machine is not sucking up the water. There is actually a gasket on the bottom of the lid where it connects to the actual tank itself. If the lid is not put back on properly (this is really easy to do, I've done this myself many times on my Hoover SteamVac), and the gasket is not sealing the lid to the tank, this will allow the suction to leak, greatly diminishing the suction power to **** the water back up. Try removing the lid and reinstalling it, making sure that it's put back on the correct way, and try to see if this fixed your problem.
Possible Problem #2: The Hoover SteamVac's like yours have a very poorly thought out design flaw to them on the attachment hose. Where the attachment hose connects into the SteamVac when the machine's handle is lowered to get underneath furniture2_bing.gif and is close to the ground it puts a lot of stress on the hose where it connects into the machine (not the end the attachments go on, but the other end). This will cause the hose to tear at the stress point. This is a very common problem unfortunately, and I suspect might be the cause of your suction loss. To check this, remove the dirty water solution tank from the machine completely. Step on the handle release pedal to lower the handle part to the ground. Look at the lower part of the handle portion of the machine for where the hose enters into the handle section, then follow the hose to where it connects into the machine. Right at the end of the hose, before the hose cuff that's connected to the motor, inspect this part on all sides to see if you have a tear here. If you do, this is the reason the machine is not sucking water up off of the carpeting.
Possible Problem # 3. If neither of the first two possible problems were the source of your suction loss, try this one. Turn the machine upside down (you should probably remove both the clean water tank and dirty water tank before doing this, just to ensure that no water spills when you turn the machine over) so that the brushes are facing upwards. Look right behind the brushes for two red plastic tabs that are slightly sunken into the bottom housing of the machine. Pull these two tabs upward as far as they will go. There is a metal filter screen that will be exposed when you pull the tabs. Make sure that this screen is clear of debris. This screen protects anything from going into the motor, and if it has debris blocking it, this can cause the machine to loose suction.
Also make sure that there is nothing in the clear plastic suction channel on the top of the machine where you can see the water being sucked up. Sometimes if something gets stuck in this suction chamber, this can also cause the machine to loose suction.
I really hope that this helped you find the cause of your suction loss. If you were able to diagnosis this problem, and would like me to help you fix the cause of the suction loss, I'd be more then happy to now walk you through the repair as well. Please just use the Clarification Request form here on the same page, and I will then help you out with your repair. I just ask that if this repair was helpful to you, please help other Fixya members to find it, and rate the repair helpful by clicking the 4 Thumbs Up icons in the top corner of the repair.
Thanks,
Chris Jones
GoVacuum.com
Apr 23, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover carpet cleaner does not **** water it blows
push the little square thingy down on the very front of the bottom bucket, then put the lid on before you put it on the machine, then let the force of putting it together push the front thingy up when you put the bottom bucket on the machine as one assembly..... it makes the seal right somehow..... ....my wife about pulled her hair out before we figured it out the hard way...... I may get a reward tonight......
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Sudsy water leaking from bottom of machine. Also it is not sucking the water out of the rug properly. Any ideas???
sounds like the same problem i am having you may need a new clean tank here is the manual for your machine
Godbless
May 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Machine will not **** up the water.
E-mail me for the parts manual (firehead@rogers.com)then do the following
Go to figure 3.1 and clean the filter if necessary. Goto figure 3.8 and make sure pate E is clear. Make sure the part isslides up against when inserted downward is clear. Go to figure 3.11.The slotted holes in the recovery tank lid must be clear. Finally therecovery tank lid must fit snugly and air tight. I hope this works
Jan 03, 2009 | Hoover F5835900 Upright Steam Vacuum
Lost manual for bissell pro2X rug cleaner can I get inst. on line?
hi,
Just recently purchased proheat 2x rug cleaner ,miss placed my manual and can't get the water sucked up . Please Help
Thanks
Jun 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Tank not sitting tight
some bissell models this cant really be fixed but some can look at where the tank connects some bolt down some twist in and some have a rubber gasket between the the tank and the machine if this is the case, with the age of the machine the rubber gasket is probably worn out. try replacing it. that gasket flattens out with time and the connection gets loose and it sucks air and dont work. when you said if you pushed down on it it wotked that is a good sign that the gasket is shot. if nothig else find one that you can fit to the machine that will eliminate the loose fit. this will fix your prioblem.
Dec 05, 2007 | Bissell 8910 ProHeat Clear View Upright...
Lost manual
send your email address to maddy1w@yahoo.com I found the pdf manual file for this unitl
Aug 27, 2007 | Hoover F5906-900 Upright Steam Vacuum
Kirby sentria carpet shampooer
you dont **** out the water....if you use the reccomended Kirby shampoo there is no need to **** out the water because it is a semi dry liquid ...it will dry by its self in about 1 hour....I,ve been with Kirby for 16 years now ...i will know
Jun 13, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
