Need instructions to add TV button to Zenith AKB36157102 for Digital
Converter remote.
1. While pressing and holding down the TV POWER button, press the CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on (or turned off if you had it on).
2. Release TV POWER button when the TV turns on or off. The remote's TV POWER button will now control the TV.
I NEED THE REMOTE CODES FOR MY ZENITH AKB36157102 TO PROGRAM MY MAGNAVOX TV
Hi....
you can refer to any one of these two links for the details you need exactly.....
1) http://www.universal-remote.net/philipsmagnavox.html
2) www.remotecodelist.com
SOURCE: The Zenith Digital TV Converter DTT900 needs reprogramming
1) While pressing & holding down the TV POWER button, press CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on or off. 2) Release the TV POWER button when your TV is turned on or off. *Each press of the channel button sends a manufacturer code (1-45) to your TV, one after the other. Note: You may have to do this every time you change or remove the battery, as the remote will reset itself to the default code.
SOURCE: I would like to use
hold down the TV Power button while clicking the Channel Up (or Down) button. after 2 or 3 clicks, your TV should turn on (or off)
