I had the same problem. I turned out to be a bad electrical connection to the machine. I think the "F" means fault, as in electrical fault. (Although I had another meaning for it). The machine kept tripping the breaker when the "F" displays. After shutting down the breaker and correcting the connection issue, the "F" never came back, the machine works fine, and no more breakers tripping. If you can't do electrical connections, I recommend getting an electrician. Hope this helps
Don
there should be a number after the f. the f stand for failure and the number that follows tell you what the failure mean. whether it is long drain or board problems door lock. could be a number of things. find out the number and reply back
That code means "No water or Insufficient water supply" Check the water supply valve, the fill hose screen for debris... Good luck let me know if that solved it..
My LG Tromm washing machine just stopped in the middle of the cycle, It started flashing the letters LE, what does that mean. I have had it for 4 years and this has never happened.
