Question about John Deere 4020 Gas & Diesel Tractor Radiator
I need to know the proper CCA rating for the batteries on a 1965 John Deere 4020D
    Scholar:
  • 71 Answers
For the guy who wants to know the size of an acre; 1 chain[ 22 yards] x 10 chains [220] yards or any shape which gives 4840 square yards. Not yards square!!
Posted on Nov 27, 2013
    Scholar:
  • 48 Answers
Since that tractor was made before they used CCA ratings could it be possible that no such official rating exists?
How about you use what ever size battery that will fit? If I recall correctly it takes two on each side of the tractor and they are rather long, tall and skinny - so much so that no normal battery would ever replace them physically. I'm thinking electrically just about any pickup battery would be a good CCA equivalent. Provided you are paying attention to the 12/24 volt issue on those dual battery JD setups like the 4020 had. If you have two six volt batteries and they work as one 12 volt then you can't use 12 volt batteries for your pickup, in other words.
In the real world the actual difference between a 500 CCA battery and an 800 CCA battery would be hard to tell until the temp got down around 20 below zero. THEN you might get your money's worth, and you might not. In my opinion and with my budget I won't go with a high capacity battery - they just cost too much more. I also don't live in Alaska, so I don't have to worry about it often enough to be cost effective. I get my warm fuzzy feelings from somewhere else...
If you are having troubles starting with normal rated batteries, you won't escape the same problems with higher capacity batteries. The troubles just cost more.
Posted on Jul 20, 2009
I would like to know the year and the type of fuel it takes gas or diesel fuel 450 C John Deere ser # 2810741T
diesel engine ,219 cu" (3.6L) turbo charged made by john deer
crawler loaders were made in 1965
Jun 23, 2017 | John Deere Garden
Wiring diagram for john deere 4020 1965?
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
May 24, 2017 | John Deere Garden
Wiring diagram for john Deere model # 125
John Deere Riding Mowers
Richard, Check the attached links,instruction and guides for wiring diagram. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Wiring diagram for john Deere model 125 Google Search
John Deere Lawn Mower Battery Keeps Dying
HOW TO TEST REPLACE SOLENOID ON LA125 JOHN DEERE MOWER
john Deere model 125 Schematic Google Search
Apr 08, 2016 | John Deere Garden
I need a diagram showing how to route a mower deck belt on a John Deere model 240 mower deck. My spring has fallen off and I need to know where it goes to put the tension on the belt.
Here's a link to an online John Deere parts store. When you land on the page, look at the top sub categories for the size of deck your mower has. You should be able to access a parts diagram with pictures of your belt's proper placement.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Mar 07, 2016 | John Deere Garden
Replace a fanbelt on john deere 4020 diesel tractor
Most older models had the adjustment on the alternator. loosen it and push it toward the engine. remove & replace the belt. Pull the alternator away from the engine until the pulley cannot be turned by hand due to the tension. Tighten the adjustment bolt to secure it. Don't overtighten the belt.
Sep 22, 2014 | John Deere 4020 Gas & Diesel Tractor...
John Deere Z225 trouble starting - turning the key to start, you hear the starter engage. The engine trys to turn over but struggles. Sounds like the battery is low. Bought a new battery, charged it...
The symptoms described may indicate a bad starter. First check all connections from the battery to ground and from the battery to starter You may want to have the starter tested at Advance Auto or Auto Zone. It will need to be removed from the mower, and I am not sure if Auto Zone, Advance Auto can test small mower starters. They test the starter under load, so if you remove the starter and hook it up to a battery, it will run probably, but it will not indicate whether the starter is good or bad. It needs to be tested under load. Good luck.....
Mar 18, 2014 | John Deere EZtrak Z225 Zero-Turn Riding...
Need to change the battery in a suzuki liana
First be sure you are purchasing the proper replacement battery for your specific needs...batteries are not the same...kind of like cereal makers, batteries are only made by about 6 companies...(many brand names) Your local parts store should be able to offer the proper battery model to start your comparison...Use the rated "Cold Cranking Amps"...CCA for comparison. Your factory battery was probably rated at 650 CCA...you can compare amps from 650CCA to 1000CCA. Depending on your array of electrical accesories, the higher rated CCA's have more starting, and maintaining power...the warranties will range from 3-8 years as of course the higher rated CCA battery will cost slightly more. If you have not purchased the battery yet...compare the Duralast Gold battery from Auto Zone...power, warranty, and price are hard to beat...includes a 3 year free replacement, and 8 year pro-rated warranty...Also, most auto parts stores will install your battery for free:) You can watch and see the simple process of disconnecting both positive (red) and negative (black) terminal cables...then locate the battery hold down bolt...(usually 10MM deep well socket) remove and carefully lift out the old battery...some old and most new batteries have a ******** top that helps in the lifting out...and installing the new battery. Tighten down the hold-down bolt, re-connect the terminal posts...and you should be complete...the engine may run rough for a few minutes while the fuel and air mixtures are automatically re-setting to factory specs...Your parts store can confirm that your problem is the battery and not your alternator, before you invest in a battery or alternator...again for free while still installed in your car...Hope this helps.
Aug 17, 2012 | 2005 Suzuki Liana 1.6
How do I reinstall the main drive belt ?
Here is a picture of the belt diagram. Or you can go to the link below to also get it.
http://www.weekendfreedommachines.com/discus/messages/60944/172491.jpg
Good Luck and please rate 4 thumbs up for the free answer
Jun 26, 2010 | John Deere Garden
John Deere 4020 Gas & Diesel Tractor Radiator Logo
241 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
