Question about Technics SA-AX910 Receiver
I have a technics sa-ax710 receiver that went into power overload I have disconnected all wires and i still get overload when i power on brian
  • 11 more comments
  • 3100 wanker Jul 19, 2009
    I have the unit opened where are the amplifier outputboard and power supply located on the 710
    brian
  • 3100 wanker Jul 20, 2009
    I have resoldered most of the joints none looked bad no improvements
    I do not seem to be getting 12 volts to th fan are there any voltage checks i can do
    Brian
  • 3100 wanker Jul 22, 2009
    HI
    Can you give me the board # for the twin 5 watt resitors, output transistors and driver transisters
    brian
    what is there number on the board or where are the resistors
    brian
  • 3100 wanker Jul 24, 2009
    Is this voltage 0.7v dc or ac voltage
    brian
  • 3100 wanker Jul 27, 2009
    yes the ic is bad i have ordered a new one before replacing it should there be anything else to check
    brian
  • 3100 wanker Jul 28, 2009
    have removed bad ic 602 but stills shows overload
    brian
  • 3100 wanker Jul 29, 2009
    Pin locations 1 and 4 on removed ic 0.00dcv pin location 1 and 4 on installed ic 0.03dcv
    still reading overload
    brian
  • 3100 wanker Jul 30, 2009
    can you tell me the number off this wire
    brian
    the output chip is that 601 or 602 which i have just replaced
    brian
  • 3100 wanker Aug 04, 2009
    If you check past comments all this has been done board out, new chip installed, no fan works on overload
    brian
  • 3100 wanker Aug 05, 2009
    Thay may not be avalable from panasonic but they are avalable i have already replaced output ic
    brian
    ps its looking like you can not help me anymore is this true
    no i have only replaced one but i do not think it was bad
    brian
    President:
  • 2,185 Answers
Here are some possible solutions.
1. This means the protection circuit is detecting a fault..in this case it could be shorted wires on the speaker or shorted speaker as well.
2. Also, it's probably quite hot somewhere internally. Have you checked to see if the fan is spinning as fast and as such not moving as much air?
3. Check for capacitors or fuse that's blown.
4. The problem is a broken solder joint between a pin on one of the power transistor modules and the circuit board. To fix it, I removed the circuit board from the case and resolder the borken joint. Opening the case is easy. First remove the top of the case. Then remove the 3 screws in front. The front panel can then be pulled off. After that, remove all screws holding the connectors on the back. The circuit board can be detached from the case by removing all the screws from the top of the board. Broken solder joint is probably one of the most common problems with modern electronics.
Posted on Jul 31, 2009
  • 4,806 Answers
Unplug it from the mains wall socket for an hour or two to see if it will reset.
While its off you can also check to see if the internal fuses and capacitors are in tact.
Please post back if you need more advice or if you find something.
Regards.
Posted on Aug 05, 2009
  • Lee Hodgson
    Lee Hodgson Aug 05, 2009
    Hi sorry about that, the whole page has only just loaded up.
    I see you have replaced a few caps and IC's.
    The problem has got to be on the powerboard itself, something causing feedback to overload the system.
    Have you looked for any blown semiconductors and the main powercoil?
    You could also try re-floating the circuit boards.
  • Lee Hodgson
    I have found a workaround.
    What is strange the overload switches on only at the beginning when you turn on the receiver.
    Later, when it has already warmed up, this problem (apparently) does not occur. Let it warm up a little and see if the message disappears.
    Damaged transistors are usually Q704 - 2SC3311 and resistor R704 3.9Ohm
  • 4,234 Answers
With all of the speakers disconnected, the message indicates that the problem is now internal to the unit. Most likely the final output stage is smoked.
The bad news is that neither of the amp-pac ICs inside this unit are available from Panasonic any more. For reference, the part numbers and costs are listed below.
Dan
RSN36S5A-P $91.26
RSN33M5-P $114.76
Posted on Aug 04, 2009
  • ABRsvcs Aug 05, 2009
    Until just now, I did not see any of your previous responses, only the initial one. After reviewing your responses, I have a question: Have you replaced both large ICs ? Either one can cause the protect message. In my experience, the one that handles the surround channels is more likely to fail. Also, if these are not installed, the unit will still show protect as they provide feedback signals that must be present for the unit to detect the correct status.
    Things to check:
    1) Check the voltage regulators (specifically the +5 and +12). Make sure that the solder connections are good.
    2) There are "feeder" resistors that should be connected directly to the power pins on both ICs. These are small valued resistors (100ohms or less) that are usually flameproof. Check these with an ohm meter to be sure that they are not open.
    I'll look up the schematic later today and try to post some additional checks.
    Dan
    Novelist:
  • 123 Answers
You`ve probably blown the output chip which powers the speakers. Unfortunately the damage is done, You`ll need to take it to an engineer but BEFORE you get it back after repair, check ALL your speaker connections, NO tape joints and good tight connections to the terminals at the back of the set and speakers. If you do have to patch the cables, employ good quality soldered and stagger the joints or you will be paying out for the same repair again. Ian
Posted on Jul 30, 2009
  • 11,896 Answers
There is a circuit protection wire that goes from volume control to main board. Pull this wire, leave stereo unplugged for 24 hours so all memory is lost in stereo. Then re-try
Posted on Jul 29, 2009
  • Nate Stansfield
    Nate Stansfield Aug 04, 2009
    You may have faulty capacitor in the board. Check for any swollen or burnt capacitors or burn marks on the circuit board. Usually there is just one wire that goes to protection unit to volume. All other wires besides this one needs to be hooked up
  • 5,807 Answers
Measure the voltage on the resistor, you're talking about
if reading is over 0.7v, the transistors connected to it out,
and measure the voltage again
Posted on Jul 22, 2009
  • 13 more comments
  • Rommel Cana
    Rommel Cana Jul 23, 2009
    look for IC- 601
    IC - 602
    they are the candidates
    if ever voltage on pins 1 and 4 exceeds 0.7v replace that Audio IC
  • Rommel Cana
    here is the guide
  • Rommel Cana
    Rommel Cana Jul 24, 2009
    0.7V DC,
    is it over?
    if it is then , it is bad
  • Rommel Cana
    Rommel Cana Jul 25, 2009
    you can also hang the two pins on each amp
    if one of them output more than 0.7V hang the resistors connected to pin 6
    and pin 7
  • Rommel Cana
    Rommel Cana Jul 27, 2009
    you can extract the bad IC
    then try to power up the unit.
    it should not show overload anymore
  • Rommel Cana
    Rommel Cana Jul 28, 2009
    check the other IC for output voltage it might have over 0.7V dc also.
    recheck the output pins of your extracted IC on the circuit board it should not show any voltages at all
  • Rommel Cana
    Rommel Cana Aug 04, 2009
    hi ,
    if you have replaced the outputs of the main amplifier and still on overload
    there might be still trouble on the over voltage detection circuits
  • Rommel Cana
    ok , try extracting all the ic, 601 and 602
    power it on, and post again if the overload indicator is still there ,
    while i am seeking again the schematic of your unit
  • Rommel Cana
    Rommel Cana Aug 20, 2009
    try to extract Q1151
  • Rommel Cana
    here is additional info for you
    here is the part 2
    Replace Q773 2SB621, if these transistor fail there will be sign of overload
    hope i have helped you, thanks for using Fixya!
  • Rommel Cana
    include R776 4.7 ohm 1/2 watt resistor might be open too.
  • Rommel Cana
    here is also additional, in case
    you may need to replace Q708 if there is no -15.2v on Q773
  • Rommel Cana
    Rommel Cana Aug 21, 2009
    did it work? or still looking?
  • Rommel Cana
    Rommel Cana Aug 28, 2009
    how is it doing? did it work?
    i do hope it is already OK
  • Rommel Cana
    Rommel Cana Sep 02, 2009
    i have sent all the possible solution to you
    i do hope you have fix it well.
  • 410 Answers
The unit will not come on when there is a real voltage problem being sensed. Hence the 12v to the fan stays off. Keep everything (spkrs and inputs) unplugged from the chassis. While turned on measure with a voltmeter at the center lugs of the large-twin-5 watt resistors in front of the power output transistors. If you have voltage on one but near zero on the other, the channel with the higher voltage is the side with shorted parts. (usually the output transistors) Check those guys with an ohm meter and no power on. Also check the resistors feeding power to the driver transistors. (the transistors that drive the outputs) You may need some service work on this baby.
Posted on Jul 20, 2009
  • 10,594 Answers
"overload" message shows that protection circuit in amplifier detected error in amplifier output section and activated for some reason.
Please check any dry solder joints on amplifier output circuit board and power supply section and resold them to fix that problem.
In case output section got serious problem then receiver needs qualified tech to replace defective parts.
Thanks.
Posted on Jul 19, 2009
  • Shahid Electronics
    Shahid Electronics Jul 19, 2009
    brian
    There is big heat sink and Output chips are mounted on it, it is amplifier output section and dry solder joints should be checked underneath, on circuit board. If you follow AC cord that will take you to power supply section in receiver.
    Thanks.
    Below image will help you to locate output section in receiver.
It keeps saying overload whats that mean
you have a blown or shorted speaker, or you have a blown input/output in the unit.
Look up my tip on transistor checking, and look for bad capacitors too.
Mar 04, 2011 | Technics SA-AX710
Our SA-AX7 says overload. What do we need to do?
Do not continue further. There is a short circuit in the power supply or output amplifier stage. Disconnect power. The unit is preventing a fire or further damage to the system. Also, check the speaker output terminals for wires shorting the terminals together. Otherwise, an audio repair shop must isolate the problem. More than likely a transistor has shorted in the output stage.
Nov 12, 2010 | Technics SA-AX710
On switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
Mar 08, 2010 | Technics SA-DX750 Receiver
When someone stomps or base hits back right surround speaker crackles also overload comes up and system cuts out
There's a loose connection somewhere. Follow the speaker wire to the speaker. Somethings vibrating and causign a temporary short.
Dec 27, 2009 | Technics SA-AX710
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
Receiver
My SA-AX710 overloads intermittently. The problem is a broken solder joint between a pin on one of the power transistor modules and the circuit board. To fix it, I removed the circuit board from the case and resolder the borken joint. Opening the case is easy. First remove the top of the case. Then remove the 3 screws in front. The front panel can then be pulled off. After that, remove all screws holding the connectors on the back. The circuit board can be detached from the case by removing the screws from the top of the board. Broken solder joint is probably one of the most common problems with modern electronics.
Mar 03, 2008 | Technics SA-AX710
Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Jan 15, 2008 | Technics SA-DX950 Receiver
first of all, check all the capacitors. Other than that, it needs a repair guy to have a poke about inside it with a screwdriver. Has anything happened to it lately that could have upset it a little bit? such as a powercut or had anything done to the plug? (e.g. change of fuse, and put in one that was a different rating) And is it plugged into a surge protection socket, or a plain old fashioned electrical socket?
Nov 22, 2005 | Technics SA-AX710
1,060 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
