Question about Creative Labs ZEN V Plus MP3 Player
One yr old, i let batt die, now does not seem to want to chg. after a bit the scn goes blank.
Thanks, would like to know how to get batt. replaced.
    President:
  • 4,402 Answers
Http://www.gomadic.com/creative-zen-v-rapid-wall-ac-charger.html
Following a tip on another forum, I picked up a Creative wall charger for the Zen Micro. Works just fine with my Zen V Plus and it was only $9.99 ($17 with tax and shipping) off the Creative web site. I like that it has a 5-foot cord. (That little USB cable that comes with the player is a pain.)
Posted on Dec 06, 2007
2004 touareg steering defective workshop on screen my scaner will not comunicate will not start or crank.can anyone help?thanks
start with the battery if it won't crank. turn headlights on and try cranking. If headlights r bright then go very dim when cranking chk batt terminals. If headlights r dim before crank, chg or replace batt.
Sep 21, 2014 | SCOSCHE Vw 03-06 Touareg Installation Dash...
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
My cell get heated when i put charge batt chg circuit of cell isnot functioning i get batt chg from universal charger nokia1100
Usually it is the battery hat is becoming old enough to internally short and this will cause it to work poorly and not ever fully charge, and get warmer than normal or hot when attempting to charge for more than 1/2 hour. Sometimes the chargr can go bad and over charge, thus making the battery too warm. if you have a car cell phone charger that plugs into cigarette lighter outlet , you can atach this and see if battery gets too warm, but these chargers usually charge faster than electric plug-in type, so expect some warmth within 20 minutes, but again if too warm than you know itis the battery. For these unnits batteries are not expensive.
Apr 28, 2010 | Nokia 1100
Palm pilot will not stay powered up. It has power for about 3 seconds then goes blank. There is a full charge on the battery too.
Sounds like it is time for a new battery. Not expensive.
Google for palm 515 battery and you should find a few places. Worth doing if you can do yourself or if you really like your 515 ;-] Labor cost on top of the battery might be the deciding factor.
Mar 10, 2010 | Palm m515 Handheld
Flashing battery light on the dash
check batt volts if under 13volts batt needs replaced.
one other test u can do is to check alternator by undoing neg batt cable when car is running, if car dies alt is bad. cars dont need batt to run just to start :)
Sep 24, 2009 | 1985 Volvo 740
1997 JIMMY,DRIVING DOWN THE ROAD,GOES DEAD,SIT A BIT,START'S.
When was the last time the fuel filter was chg. If you can't remember its time for a new one.If it does not help after you chg. filter, best to fuel pressure test, to see if pump is going bad.
Feb 10, 2009 | 1997 GMC Jimmy
Monitor goes blank after being on for 1 minute
it's not yr monitor problem. it's a basic system problem u need to clean yr ram or ser CPU internal Cables connectors or make sure yr pc is clean if yr pc has dust problem clean with Blower and remove dust then try it's help u..
if u don't know how to clean **** please don't do yrself.. contect yr engineer.
Thanks
Please vote
jo_chinmay
Jan 01, 2009 | BenQ FP71G 17" LCD Monitor
WON'T START, BATT READS ZERO
first i would look to see how old the battery is. i would check connections and if no problem found and battery over 3 years old i would replace it
Sep 12, 2008 | 1991 Buick Skylark
Creative Labs ZEN V Plus MP3 Player Logo
54 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
