Question about HP PSC 1510 All-In-One InkJet Printer
Cant get hp1510 printer to print - HP PSC 1510 All-In-One InkJet Printer
  • Brett Duxbury
    Brett Duxbury Oct 26, 2016
    Hi Janet vest, we can't help you with the limited information you have provided the brain trust. We want to help you with your question, but I need more information from you. Can you please add details in the comment box like how the printer is connected to the computer (USB , Networked , Wi FI ??) Has anything changed in your setup like did you buy a new computer or upgrade the operating system , what operating system are we dealing with , Has p.c got drivers for printer installed ?
Ada masalah dgn printer HP1510 tidak bisa print word atau excel tp untuk photo dan PDF bisa.apa kira kira ya
So you cannot print using the print dialog to your HP1510 printer in word or excel but you can print to PDF? Is that correct?
Jadi Anda tidak dapat mencetak menggunakan dialog cetak ke printer HP1510 Anda dalam kata atau excel tetapi Anda dapat mencetak ke PDF? Apakah itu benar?
Jan 29, 2015 | HP LaserJet Office Equipment & Supplies
Make font larger on HP1510 printer
What font are you referring to? Have you prepared a document in a word processing program, or added text to an image file, and are disappointed because you want to see the text printed larger? If so, your best solution is to edit the document or image and change to a larger text size. For example, most text documents will normally default to either a size 10 or 11 text which is readable but small. Changing to size 12 or 14 will make the text look larger onscreen, and the text will also print larger. The font name and font size should be displayed on one of your processing program's toolbars, and is easily changed to a different font name or size. If you are simply copying an already printed document and want the text to appear larger, you should refer to your printer's User Guide. If you don't have the User Guide, you can download a free copy at this link:
HP PSC 1510 All in One Printer User guides
Nov 15, 2014 | HP PSC 1510 All-In-One InkJet Printer
My printer hp1510 how do I scan
Easiest way is to use the hp software but if you haven't got it go to Start>Accessories>Paint>File>From Scanner or Camera then click Scan
Aug 21, 2009 | HP Office Equipment & Supplies
Printer can't on...hppsc1510 is not working?
Friend, be sure to check the power supply cable be sure it is attached firmly. Try to check the power button if it still click for functionality. Then check the CS utility software through www.hp.com
Jun 08, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP1510 How to change out ink [email protected]
there is pull down face just above the paper tray, put you finger in the slot and pull it down you'll see the ink cartridges on the right.
Jan 28, 2009 | HP PSC 1510 All-In-One InkJet Printer
Hp 1510 and Dell Inspiron not connecting
I AM TRING TO CONNECT MY EPSON LX-300 TO HP DX2390 CPU USB PORT. HOW CAN i DO
Dec 10, 2008 | Epson LX-300 Matrix Printer
The alignment is off and the type is blurry
try to clean the unit if you can with a cotton swab and some alcohol. if it is an HP Officejet 1500, find the nearest trash can, that is the only solution to fix that particular model. been there, done that. i had to deliberately "misalign" the cartridge to be able to use it at all.
Apr 04, 2008 | Office Equipment & Supplies
Color cartridge problem
the color cantridge u changed is genew or u have token the other and just fill them fith ink???
if u have bought new cartidges go try print a test page and check if u have installed the cartidges corectly
if u havn bought genew cartidges i seems that the heads are blocked with ink!! go buy some new ones and i believe u will be fine
dont forget to vote!! :)
Stratos
Nov 17, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
