Question about Frigidaire Dryers
FRIGIDARE GALLERY DRYER - NEED TO TAKE APART THE DRYER. HOW DO I GET THE BACK OFF?
5 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: I think I need a
try taking front off dryer you may find it easyer
Posted on Feb 19, 2009
hunter19_46m
  • 7482 Answers
SOURCE: the dryer belt has slipped off, how do I get to
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. You can now replace your belt but I recommend that you go a little farther. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7.
Good luck, I hope this helps Please do not forget to rate me Thank You
Posted on Dec 09, 2009
  • 382 Answers
SOURCE: We have a Frigidar Gallery dryer. The across the
they tend to get hot but excessive heat I would contact a reputable appliance repair and ask them also how old is dryer I do not know if they are still being made Gen.Motors sold them off 30 yrs ago
Posted on Dec 18, 2009
heatman101
  • 43501 Answers
SOURCE: Frigidare Gallery Dryer FSE748GFS1 makes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Jul 23, 2011
REmove the front panel of a frigidare gallery washing machine
Most tops lift up and hinge at the back. stick a blade under the front corners and release the catch.
Jan 17, 2015 | Frigidaire Washing Machines
Frigidare Gallery microwve will not operate because door will not close properly. I suspect the problem is in the door latch but can't seem to figure out how to take the door apart or even if possible. Any...
Good Morning Friend,
I understand that your Frigidaire Gallery microwave will not operate because the door will not close properly. Being that you are dealing with your microwave, I suggest contacting your local authorized technician. You do not want to try and take apart anything on your appliance, as you do not want to damage your appliance any more, or even worse, bring harm to yourself or your family. The technician will be able to diagnose your microwave and determine what is causing the door to not close properly and your appliance to not operate. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Microwave Ovens
Brown Burn Stains and little holes from FRIGIDARE GALLERY HEAVY DUTY STACKABLE DRYER
If you are using LP gas make sure the dryer is set to LP on the regulator. If a natural gas dryer is run on LP you will get way to much flame.
Jan 02, 2014 | Dryers
Frigidare dryer gleq215ee won't heat then shuts off after about 10 minutes. 4 lights on right flash. no error code comes on. I am pretty handy and can take apart and fix. would need to know what t
Hello John Sterns - First, try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective then typically this is something that a professional would need to diagnose. Since it is such a complex unit, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch.
Dec 09, 2012 | Frigidaire Electric Dryer
ERROR CODE E64 FOR FRIGIDAIRE AFFINITY
Please CALL Frigidare. We have had the same problem with our dryer and now the washer quit! Our set is only 3 years old! With all of the problems reported on the Internet there should be a recall on this set! They need to be informed! I am highly disappointed in the short lifespan of the Affinity Washer and Dryer. Dont know if I would purchase this brand ever again!
Mar 02, 2012 | Electrolux EIED55H Dryer
Frigidare Gallery Dryer FSE748GFS1 makes squealing sound intermittently when drying. Is there a repair manual for this dryer?
heatman101
Jul 20, 2011 | Frigidaire Dryers
ITS A NEW FRIGIDARE IT WILL NOT COLD TO FREEZE
Possibly stuck on defrost... locate the defrost timer and turn the timer dial... the fridge should come on.... but you still need to replace the timer
Jul 19, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidare gallery not heating. possibly heating element is gone out how hard is it to replace
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 01, 2010 | Frigidaire FER231A Electric Dryer
Dec 18, 2009 | Dryers
Dryers Logo
201 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
