Canon MV550i Mini DV Digital Camcorder Logo
A
Anonymous Posted on Oct 26, 2016
My Cannon MV550i Digital camera when switched on does not open to see what I wish to record i.e. blank black screen the lens cover is off. Any ideas?? thank you
5 Related Answers
evans_lloyd
  • 41 Answers
  • Posted on Sep 27, 2007
SOURCE: blank lcd screen
wires have come off the ccd ! canon will fix free of charge,go to canon support
Anonymous
  • Posted on Mar 07, 2008
SOURCE: no image displayed through viewfinder or lcd screen
could be one from a batch with faulty CCDs - check out this fixya link (solution 2) - http://www.fixya.com/support/t115316-canon_mv30 - it's copied from a page at imaging-resource.com - my MV600i was out of warranty and I sent it back to Canon at the end of 2007 and they got it going again free of charge within the week - unfortunately within weeks a very similar fault appeared and now they're trying to charge me for the repair !!! even though they say repairs are under warranty for six months -
Anonymous
  • 8 Answers
  • Posted on Oct 28, 2009
SOURCE: Cannon NTSC ZR85 is unable to record video but can
canon has released a service advisory for this condition, its a bad ccd connection, and is offering to fix at no charge. contact canon in your country for details
Anonymous
  • Posted on Dec 20, 2009
SOURCE: Hello, my canon zr90's screen is black, if i
Hi - Canon has an advisory on this and may still fix that particular problem well past the warranty expiration date. You should check their website.
Anonymous
  • Posted on Feb 01, 2010
SOURCE: When I turn on the camera, nothing happens and the
i know exactly whats wrong! the same thing happend to me.
1. turn off the gl1 2.look at the record button with the lock and standby switch 3.flip the switch all the way to standby because it might be stuck in the middle 4. turn on your camera
My cannon power shot sd780 lens cover does not open when turned on. Just a black screen. The barrel does extend. Is there something I can do to fix it?
Its not easy to dismantle this kind of gadget, a broken gear inside or some mechanical parts of the lens assembly caused lens not to open or a motor controller itself, so better to find a cannon service center ear you.
Lens screen blank
The black screen problem means the lens sensor is spoiled due to over exposure to heat. Its better to give it to cannon service centre. If your camera is under warranty period its well and good they will replace the lens sensor for free of cost.
Thank you
4helpful
2answers
Cannon NTSC ZR85 is unable to record video but can view tape on the mini screen. The camera works fine but the screen is blank/black and mic still picks up sound. Would you know a solution
My cannon s21s has a blank screen
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture.
You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
1helpful
Sound but no pictures
It seems problem of defective ccd imager IC, please confirm is this DCR-HC18E model Sony camcorder to guide you further.
Sony handycam DCR-HC20 Screen blank
i want driver of sony digital 8 ready shot camera
V570 Dual Lens, will not switch to ordinary lens.
Hi, My V570 works fine on widescreen lens (the default on startup) but when I zoom up to switch to the other lens it goes to a dark blank screen and will take a similarly dark blank picture. I can hear the zoom activating as I click it so I think that is ok. I opened the camera
2answers
Records audio but no video
Replace the ccd base assumbly and check.
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
