Question about Plumbing
Well pump not shutting off and tank never reaching full pressure
Our pump was moved from the well to inside the basement of our home many years before we purchased the house. Home is over 50yrs old if that matters.
Last night I noticed that the pump never shut off. The holding tank pressure and the pump pressure is set for approx. 40psi and it was not going any higher than about 25psi. We ended up just turning the switch off so that it would stop running until we could think on it this morning.
We turned the switch back on this morning and the same thing happens. It runs and runs but never gets any higher than about 25. So this tells me that our fear that the well is dry might not be the case. The lines and tank are cold and seems as though water is flowing.
So at this point we can function with very low pressure and turning the pump switch on and off to fill the tank to flush toilets and wash some, but still don't know what the problem might be.
These are not the same symptoms as when the tank needs to be pumped again. Usually that just makes the pump cycle more frequently and we empty and pump the tank and that fixed it.
Can anyone give some ideas as to what might cause this?
Thanks.
  • 1 more comment
  • dalyj68 Jul 21, 2009
    W/D
    Here's what we've done so far. (fwiw, it's a Myers indoor pump and shallow well)
    Pressure held in tank, so assumption was a faulty pressure valve. Replaced valve yesterday with a standare 20/40 valve, but could not get water to pump through. Realized that pump was not primed and tried that this morning. Because of the 90's in the lines, that is difficult but not impossible. Pump is still not pumping water. Once we can get the pump pumping again, if that doesn't fix the pressure, I guess the next step will be to investigate the foot valve in the well.
    Any other suggestions?
    Thanks.
    W/D
    Thanks.
  • dalyj68 Jul 23, 2009
    Thanks for your info.
    We ended up calling a well and pump specialist yesterday. They replaced the foot valve and jet assembly, primed system completely, and were still not able to get it working. Their assumption was that the pump parts were just old and worn, because they had done everything else.
    They ended up installing a whole new submersible pump and tank system. All is working and water is running.
    Thanks again.
    President:
  • 1,273 Answers
50 years old isn't bad..... but technology has changed a bit. I do have a few ideas. I'll list out several problems/solutions, and you'll have to pick and choose, depending on your particular circumstances. It will be a long read, but I would suggest that you read to the end before picking a course of action. Hopefully, others will offer advice as well.
Make sure that you have a working pressure gauge. I only say this as all of your (and my) assumptions have and will be made off of the gauge. It's critical. OK, with a working pressure gauge....Are we seeing the same pressure? If the pressure is actually higher, say, in the range that you are regulating for, or higher, the pressure switch is suspect and should be investigated/replaced.
When you shut off the pump, does the water pressure fall off? If it does, this might indicate a leak either internally (well/pump) or externally (faucet, etc.). Locate the regulator on the side of the pump. With the pump running (and a good pressure gauge), turn the regulator adjustment several flats, rembering your original position. This is best done with the pump at max pressure. Operate it in both directions, say four flats one direction, back the same to the original position, then 4 in the opposite direction, and back to the original position. Note the pressure on the gauge each time you make an adjustment. If any improvements are noted, work with it.
The most common problem with pumps not putting out enough water usually isn't the pump, but the well itself. Most wells have a foot valve and jet valve assembly. The foot valve has sealing rings on them known as leathers (although these can be made out of other materials). If the well is shallow, say 20 feet or less, the pump will normally pick up water without too much difficulty, even if it won't maintain pressure at the tank. Not knowing the depth of your well and the age of your equipment makes it a little harder to diagnose. Slippage within the pump, allowing some of the water to spill back, is a possibility, but you would expect the pump case to heat up over time, and this doesn't sound like the case. My guess is that you have some leak-by in either the jet assembly or the leathers, allowing some of the water to leak back to the well. The foot valve would keep the water pressure from dropping to zero. I'd trip the breaker to the pump motor and break the well head away from the pump (leaving the cast iron piece on the inner pipe). You should have a triangular piece around the outer well casing. Loosen the three bolts, then remove the two bolts that hold the pump to the well head. Gently separate the two, and set your pump off to the side. The aim with "gently" is to avoid tearing the gasket. (If it does tear, you can purchase gasket material and hammer one out, if replacement gaskets aren't readily available). Once the pump is removed, you can remove the inner casing to which your jet and foot valves are attached. Careful when removing it,though. You do not want the inner casing to unscrew from the well head and fall down the well. If there is a lot of sediment in the well, it will be more difficult to remove the inner casing, as the leathers press against the outer casing making the seal. I have always put several gallons of bleach down the well, although recently, a neighbor had muratic acid put down his well. This is dangerous, however, and only trained and skilled personnel should attempt. I let the bleach sit for several hours, allowing time for the bleach to soften the leathers. Once done, extract the inner casing, pulling the well head, inner casing, jet valve and foot valve as a unit. You'll have to pull it in a big arc and lay it out slowly as you go. More hands are better for this task. You may need to get creative in supporting the line it it's PVC. Once extracted, visually inspect the lower components. I recently saw one with a hole eaten in the top of the jet valve, producing similar results to your issue, but worse. Anyway, if this is where you are at, I would, at the very least, replace the leathers. And, I'd double them. Truth is, when I go to that much effort, I replace everything at the bottom of the well, foot valve, jet valve, leathers....
We havent hit on the tank yet. Older systems had an air injection system where a shot of air was injected every time the pump cycled. If no air went into the tank, the tank would become "waterlogged" over time, and would cycle constantly. This system was prone to failure. The remedy for this was to drain the tank, and start over, and to replace the air injection system. This usually called for the pump to have to be reprimed as well, at least at my house... Newer tanks have bladders in them with a pressure set on them to provide the same air cushion that the older systems provided. The air pressure on mine is set to 28# via a schraeder (bicycle tube) valve at the top of the tank. Check yours if so equipped.
Well, that's about it for now. Make your checks and please let me know what you turn up. I'll check back.
Best regards and good luck,
--W/D--
Posted on Jul 19, 2009
  • woobie dog
    woobie dog Jul 23, 2009
    Since you were hooked onto your neighbor's house via the hose line, you can back water into your pump to prime. Should help. Keep me posted and I'll try to offer whatever advice I can. Good luck, --W/D--
Has spark but will not start
Then gas must not be reaching the cylinder. Pump the pressurization bulb if it has one until it is hard. Make sure fuel cap is tight. Take out the spark plug and drip some gas into the cylinder. I use the old straw trick - stick one end into gas, plug the other with you thumb, move to saw and remove thumb. Immediately reinstall plug and wire and start it with choke off. If it starts and will not stay running, try one more time with choke on. If it won't run, the carb is probably bad, especially if it has sat a long time. Time for a shop visit. BTW, if stored long time with half full tank, condensate forms inside the tank during temp changes and new moisture enters when fronts change the air pressure. The water will be in the bottom of the tank where the pick up is. Empty the tank and refill with fresh fuel. Always store with the tank full.
Mar 09, 2015 | Garden
How does a home well water system work?
Deep well.
Pressure valve located on front of above-ground-storage-tank will turn pump on-off depending on amount of water pressure inside tank.
When water is consumed inside home, the pressure valve responds to the lower pressure and closes electrical contacts... sending electricity to water well pump located deep underground.
The pump turns on and lifts water through a pipe into the above ground storage tank.
When the tank is full of water, the pressure valve senses the higher pressure and turns off electricity going to pump
Pump shuts off.
There is a one-way check valve on the water line going down to pump, and this keeps water from flowing back down into well.
The above ground tank maintains water pressure for the house.
When pressure is reduced by taking a shower, the pressure valve turns pump on again, and cycle repeats.
Aug 20, 2014 | Water Heaters
Utilitech pump
the diaphragm in the pressure switch might be hard, after years of service the rubber gets stiff and the pressure switch just will not work anymore. even if the tank is full of water it should switch on and off rapidly if the pressure switch is good..
Aug 11, 2013 | Plumbing
How do pressure tanks such as varem work?
Varem pressure tanks are simple pressure vessels. They have a chamber where the fluid comes in and a bladder that is pressurized on the other end that the fluid pushes against and compresses the air or other gas that is inside the bladder. When the pressure on the fluid line reaches the pressure switch setting, the pump shuts off and the gas pushes the water back out of the tank (if it is being used) until the pressure switch lower limit is reached and the pump kicks back on, pushing fluid back into the tank. This cycle continues until the fluid is no longer being allowed out of the system.
The bladder pressure is set when the system is empty of water and is set to a couple of pounds less than the low pressure cut on setting, that keeps the bladder from pushing all the fluid out of the tank before the pump comes back on resulting in a zero pressure moment which with some pump switches means it shuts down and has to be manually restarted.
Aug 29, 2012 | Ace Hardware Plumbing
My bostich 6 gallon pancake compressor won't shut off. It get so hot it stinks and I turn it off. The pressure gauges show that it should.
You didn't state your model number so I won't be able to tell you what specific parts you may need. If your guages are correct and the tank is coming up to pressure as it should but the motor doesn't shut off when the peak pressure is reached, you have a bad pressure regulator. They're easy to replace. If it's possible your guages are off and the shut-off pressure isn't being reached, the motor will continue to run as long as it has power. Reasons for not reaching peak pressure in the tank could be a leak somewhere like the pump to tank line or drain valve, a bad valve plate that isn't sealing properly or damaged piston or cylinder assembly.
Aug 16, 2012 | Air Tools & Compressors
My water system is loosing pressure. The pump runs until it gets to the preset of 50 psi but when it stops, the pressure drops right away. if I shut off the pump, it drops to 0 psi. I checked the pressure...
There is a screened check valve that should be attached to the pick up / suction side of the pump on the very end of the plumbing in the bottom of the well. If you have shut off the water output going to the home / what ever and the pump still drops pressure to zero as soon as it shuts off the shallow well foot valve is stuck open / has failed.
Some systems use both a foot valve and an in-line check valve to prevent the symptom you currently have.
Foot valve example:
http://www.docolfaucets.com/ingles/produtos_detalhe/docolvalves-24/check-valve-and-retention-valve-93/foot-valve-for-well-w-check-valve-line-bsp-thread-348/foot-valve-for-well-w-check-valve-1928
More examples:
http://www.plumbingsupply.com/wellpart.html
http://www.plumbingsupply.com/images/well-footvalve.jpg
If this valve has failed... there is nothing to prevent the contents of the pressure tank from dumping back into the shallow well.
I doubt you have a shut off on the pump suction side but if you do once the pump shuts off close this valve. I would bet your pressure tank holds the pressure. If you do not have a shut off valve... just feel for a rush of water in the suction pipe AFTER the pump reaches pressure and shuts off. If your feeling water flow with the pump off and the tank at pressure / loosing pressure the foot valve is bad.
Thanks for choosing FixYa,
Kelly
Apr 18, 2011 | Sta Rite 3/4 Hp Above Ground Pump Ne640
1988 chevy celebrity No fuel to the carberator.
without starting the engine position the key to the on position.
you can hear the fuel pump operationing for 4 to 6 seconds upon having the key on.
if not heard running check the fuel pump fuse, the fuel pump relay, and the engines oil pressure switch.
they all work the pump you see
the engine oil pressure switch runs the pump untill the engine reaches normal pressure
once the pressure is reached to the normal range the computer shuts that circuit off and turns the fuel pump relay on
May 22, 2010 | 1988 Chevrolet Celebrity
My car turns over starts then cuts off
The fuel pump operates off two items upon starting the car. When you first turn the key to the ON position you can hear the fuel pump faintly running inside the fuel tank. If you can not hear it it seems it is working for you stated the engine starts then cuts off. That tells me the engines oil pressure switch is working the fuel pump. On the oil pressure switch this switch has a third wire which is directed to the fuel pump. When the engine reaches full oil pressure the computer shuts off the signal from the oil pressure switch and then the computer turns on the fuel pump relay which stays on until you shut the engine off. I do beleive the fuel pump relay is what you need for it is not working no longer. This will have many relays with the same part number on it. You can easily swap any relay that looks the same with the same numbers on it and try it once to see if the engine stays running.
Apr 09, 2010 | 1990 Oldsmobile Cutlass Supreme Conv
No water from well.
If the water pressure reads 50 psi, then, the submersible pump is running okey. Do these:
1. Shut the power off.
2. Release the pressure of the tank by opening the
gate valve and free the air inside.
3.Drain the water inside your pressure tank empty by
opening the drain plug at the bottom.
4. Then, replace the drain plug .
5. Check the flow control valve. From full close
position, adjust to 1/4 open position. However, if it
is using a gate valve as flow control, Just open two
full turn counter clockwise.
6. Put the power on.
7. And start the submersible pump and allow it to
run until the pressure tank is pressurized.
8. At 20 psi pressure, open your faucet, and see if
you've got water.
I would like to know the result, so just send in your e-mail . Thanks and God bless you.
6.
Oct 26, 2009 | Plumbing
Pump spinning but not getting up to speed then shuts off
You have a pressurized system using a pressure tank.This is a case of an air logged pressure tank. Meaning there is more air than water in the pressure tank. The pressure tank must hold 2/3 water and 1/3 air of its total volume. Installed at the tank is the air volume control to take care of this proportion. Should the air volume control malfunction or becomes defective, the air-water ratio is affected. And then,
the pressure tank becomes either air logged or water
logged.
SOLUTION:
1. Shut the power off, and open the discharge line
gate valve to flush the water in the pipe lines.
2. Open the drain plug of the pressure tank to empty
all the water at the pressure tank.
3. Close the drain plug, and put the power on.
4. Start the pump, and set the flow control valve 1/4
open.
5. The pump will normally run.
Send your e-mail for us to know the results, and for
further assistance.
Jul 04, 2009 | Plumbing
Plumbing Logo
1,516 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
