Question about Braun 360° Complete 8985 Electric Shaver
When should you change cutters &/or head? - Braun 360° Complete 8985 Electric Shaver
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 31 Answers
Braun series 5 combi 51S replacement screen foil and cutter block for braun 8985 replacement parts.
when should you change cutters &/or head? - 86830cac-7b91-4740-a4a0-a251c073d9f6.jpg
Posted on May 23, 2013
    Novelist:
  • 124 Answers
Braun recommends replacing the foil and cutter block every 18 months. This is an "average", as it really depends upon the frequency of use and the thickness of your beard.
However, if you are budget conscious, you can opt to replace just the cutter block when it becomes dull (keep the foil for 36 months and then replace it). You can buy the cutter block alone on "that auction site" or from shaveroutlet.com. I think it is just $9.99.
Posted on Oct 22, 2009
Have a microscreen rechargable tha needs blades replaced and screen replaced...can U do that and How much$$$
This is not a service provider.
Amazon.com: Remington SP-72 Replacement Head ...
www.amazon.com > ... > Replacement Heads
Amazon.com, Inc. Rating: 4.5 - ‎12 reviews
Replacement Head & Cutter for all MicroScreen 3 shavers, TA-3050, 4570, 5570 ...rechargeable and saves on batteries, so I'm using the new blade with the old ... Sincethe screen needs replacement much more frequently than the cutter, it is ...
Oct 31, 2015 | Remington Health & Beauty
How do you change the cutter bar bearings on a delta 12 inch planer
You are looking at a major disassembly to get at the cutter head bearings, everything is built around the cutter head. The motor drives the cutter head on one end of it and the cutter head drives the rollers at the other end. Most of the components have to be removed to get the cutter head and it's bearings out. You can go to www.ereplacementparts.com and do a search on your model number for a good breakdown of your planner and see what you need to remove to get at the cutter head and it's bearings.
Sep 03, 2012 | Delta Masonry Tools
How do i change the blades
Disconnect the planer's power cord, then use the T-wrench that comes with the planer to remove the four screws that secure the top of the planer. Lift the top to remove it from the planer.
Remove the three wing nuts holding the dust cover over the cutter head. Rotate the dust cover up to unlock it from the fan housing, then push the cover to the left to disconnect it. Remove the dust cover from the planer to expose the cutter head.
Rotate the cutter head with a piece of scrap wood until the lock on the side of the cutter head engages. All eight screws in the cutter head clamp should now be visible. Remove the screws using the T-wrench, then turn the T-wrench upside down and use the magnet in the head of the T-wrench to grab the clamp. Remove the clamp to expose the knife underneath. Use the magnet to remove the knife.
Press down on the cutter head lock to free the cutter head. Use some scrap wood to turn the cutter head for access to the remaining two knives. Follow the instructions in Steps 3 and 4 to remove and replace those knives.
Mar 13, 2011 | Dewalt Tools & Hardware - Others
Series 3 - 340, my father wants replacement foil & cutter, where can I order one from please.
Braun makes two distinctly different models, both with called seroes 3-340. You will need the type number as written on the shaver to properly identify the correct foil and cutter for his shaver. Both types are available at shaveroutlet.com. See the two links below. You will need to use the type number of his shaver to select the correct one of these two
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-foil-and-cutter-p-141.html
http://shaveroutlet.com/shaver-replacement-parts/braun-series-3-shaver-foil-and-cutter-head-cassette-32s32b-p-835.html
Jan 11, 2011 | Braun Health & Beauty
Cutter plastic drive block doesnt hold cutter pin
It sounds like the drive unit is the problem. This part can be purchased from shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
May 29, 2010 | Braun 360° Complete Electric Shaver
Need to change cutters, replacements I bought have no instructions.
remington SP69 replacement screen foil and cutter blades for electric shaver remington ms2 390 heads replacement parts.
May 02, 2010 | Remington MS2-390 Electric Shaver
Hobart airforce 250 ci has power but will not operate
make sure that there is air to the plasma and set at the proper psi. Make sure that the contact tip and nozzle is in the cutting head correct.
Dec 18, 2009 | Hobart Airforce 250ci Plasma Cutter 12...
Cutter
Usually you remove the head and rotate the cutter assembly 90 degrees. A lot of them will be removed by this method.
Otherwise if you pull gently up on the cutter head it should be removed easily.
Mar 25, 2009 | Braun Health & Beauty
Braun 360° Complete 8985 Electric Shaver Logo
164 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
