Question about LG Shine CU720 Cellular Phone
I switched the card in my phone to see if it was
I switched the card in my phone with a different one to see if it was any good and now i can't get either of them to work
I need to use my sim card
not sure if this is what you are after.
Your SIM card allows your phone to connect to GSM networks. When you insert your SIM card into a different unlocked phone, you'll be able to use your service on it. Similarly, if your phone is unlocked, you can insert SIM cards from different carriers into it, which can be useful when traveling.
How to Use a SIM Card to Switch Phones: 12 Steps (with Pictures)
www.wikihow.com/Use-a-SIM-Card-to-Switch-Phones need to use my sim card Google Search
Dec 22, 2016 | Cell Phones
How do i fix my ZTE to to read sim card
If your ZTE is unlocked you can use different sim card from different vendors, otherwise you can only use the same service provider.
Verify that the sim is in good condition, using another ZTE, etc.
Dec 03, 2014 | ZTE Cell Phones
Emergency calls only
Typically issue with the sim card. Try to use the sim card in another phone. Also try a different sim card in your Samsung. If the same sim card does not work in a different phone, contact your carrier. If a good sim card does not work in you Samsung, contact Samsung or where you bought the phone from
Apr 04, 2014 | Samsung SGH T139 Hard Plastic Case Flower...
E71 memory card unreadable
please check it with another battery
May 03, 2009 | Nokia E71 Smartphone
Phone will not turn on!!!!
Friend the problem is your power switch.it is shorted or disconnected. or the hardware called CCONT power supply.it needs resolder ot reheated.ask for mobile techincians help for this hardware probs.good lcuk
Apr 25, 2009 | Motorola Mobility RAZR V3
Lg vx1000s wont respound to sd card
Not all SD cards are created equally. Check that you got what your phone uses. There are at least three different types of 'SD" cards.
SD
SD/MMC
SDHC
Read here: http://it.okaay.com/index.php/how-to/miscellaneous/how-to-understand-the-different-sd-card-types
Good Luck!
Mar 26, 2009 | LG VOYAGER VX10000 Cellular Phone
Downloaded music from my computer, all plays fine from memory card and phone memory, but unable to access music player. displays updating then switches phone off, and phone switches back on...
transferred all my files onto my computer, then proceeded to format the memory card whilst in the phone. transferred all the files back onto the memory card and bingo the music player works fine. Strange that the memory card was from my samsung e900 and worked fine.
Apr 27, 2008 | Samsung Cell Phones
I took my memory card out of my 810i without first switching off now when i turn on the phone all it does is flash a white screen and nothing works i also have to take out the battery to switch off whats...
nothing just reformat the card in the phone itself, the card has got a different filesystem than the phone recognises,
start the entire process from scratch cormat the card in the phone before that backup all ur data on the pc. that should fix the same.
otherwise after removing the card reset the phone to factory settings security code is 12345 0r 0000 that should do the trick again here first backup.
Apr 10, 2008 | Nokia 6288 Cellular Phone
LG Shine CU720 Cellular Phone Logo
47 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
