Question about Canon PowerShot S5 IS Digital Camera
Canon s5 is battery cover will not open - Canon PowerShot S5 IS Digital Camera
    Novelist:
  • 164 Answers
Unfortunately there is only two solutions for your problem:
1. Gently but firm, press the battery cover lid down and at the same timemove the button to open it, and at the same time, slide to the side the battery cover.
Try it as much as times are needed.
2. If still is stuck, then you will need to disassembly it, or pay at a repair service for it.
If is stuck, and force to open it with a tool (pry tool or similar), you have the risk of break the slide plastic channels in the camera body, or break the battery cover, or break a switch located in the mainboard that senses when the camera door is closed, or everything at the same time, making worst the problem and causing you to spend more on repairing it.
Of course that if it has warranty, I do recommend you to make it valid prior to try in send it to repair.
If is out of warranty, Canon charges $120.00 for any repair (or so), so you will need to find a cheaper repair shop for it.
Best regards,
Posted on Jul 25, 2009
My previous question should have read.Can I purchase a replacement battery cover with contacts to suit my cannon power shot S5 IS
Sorry, didn't read the question properly ! Yes, it should be possible, but obviously not from Canon. Try eBay, but be very specific about the fitting.
Alternatively, you may find a source via this link :
Canon Forum
Good luck
Nov 27, 2017 | Cannon Cameras
Tip
Hi guys.. try NiMH rechargable battries with 2500 mAH or 2700 nAH. These...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Aug 20, 2008 | Samsung Digimax D53 Digital Camera
I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
Contact failures may have occurred between the camera and the batteries.
Confirming that the [Memory Card / Battery Cover] is securely closed
If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
batts_step1.gif 3. Insert the batteries as shown.
batts_step2.gif 4. Close the battery cover.
batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
Example 1:
  2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
  3. Insert the batteries as shown and close the battery / memory card cover.
Example 2:
  2. Slide the battery cover lock in the direction of the arrow, and open the cover.
* For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
Dec 05, 2010 | Canon Cameras
I bought my canon S5IS 2 years ago.For these 2 years it worked fine but now it is showing "Low battery problem" even when the battery is full charged.I also bought new batteries but that also in...
Make sure that the battery terminals in your camera are clean (rub them with a pencil eraser, q-tip or micro fiber cloth). Dirty terminals can cause poor contact with your batteries, therefore, impacting there performance.
Also, if you are using rechargeable batteries, your batteries may simply need replaced. Try testing the camera with a new set of alkaline or NiMH batteries.
Nov 09, 2010 | Canon PowerShot S5 IS Digital Camera
Hi, I have problems with my Canon powershot S5 IS, no matter what I do, my batteries are dead within 30 seconds. I've used a new pack of batteries to make 6 photo's. Anybody got advice?
it looks like the Camera Shortend the batteries
its a problem with the internal power unit one of the components is short and cause this problem
ecrdn@yahoo.com
Jack
Oct 20, 2010 | Canon PowerShot S5 IS Digital Camera
Flash not working
Before you give up on the camera:
There are many setting that can affect whether the flash works or not.
You may have inadvertently set something that is stopping the flash from working.
Get out your User Manuals and use the index at the back of the book.
Look for something about "Resetting the camera".
This will reset the camera to factory specifications.
Then see if the flash works.
If that does not work ... recharge the battery and try again.
If that does not work, the flash is likely dead.
Nov 24, 2009 | Canon PowerShot A590 IS Digital Camera
I turned on powershot then opened the battery
If you install fresh batteries, close the battery door the lens should retract. If it did not, make sure the batteries installed are properly. And don't do that again you will lose all pictures on the card and may ruin the card permenently.
Sep 09, 2009 | Canon PowerShot S5 IS Digital Camera
Date and time setting dont save, I changed the CR 1220 battery. Still doesnt save. Every time I turn on the camera the date / time setup appears.
In another forum I found a solution:
Remove the watch battery from the camera
Carefully bend the contacts inside the camera toward the opening that the battery fits into. - I used a heavy safety pin to bend the contacts.
Put the watch battery back in.
http://forums.steves-digicams.com/canon/131158-canon-720is.html
Aug 16, 2009 | Canon PowerShot S5 IS Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
260 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
