Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
I have a kenmore dishwasher. While it was in the
I have a kenmore dishwasher. While it was in the middle of the washing cycle, it stopped working and the clean light came on. The light continues to flash 24 - 7. What could be wrong with it
    Scholar:
  • 106 Answers
Hi...
If the cycle doesn't complete, check these....
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
if still it doesn't fix your problem then see whether any error codes are generated....
F1 Water heating fault, selected temperature not reached within 60 minutes · Incoming water temperature too cool
· Heating element burned out
· Thermostat defective F2 High water level · Plugged/Bad water pump
· Defective water inlet valve F3 Thermistor fault · Open thermistor
· Bad wiring to thermistor F4 Fault with water fill (only on machines with level-controlled fill)
Note: Lights blinking, pump running and controls dead indicates an over fill fault 1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
*Faults may vary by model. Use this as a general guide.
i think these details would definitely help you.....thank you...
Posted on Jul 19, 2009
Could you please help diagnose problem...dishwasher consistently stops washing in the middle of wash/sensing cycle. 2005 Kenmore Ultra Wash Quiet Guard 3
most likely the water is not hot enough,,it trying to heat the water,,when it starts to sense open the door and just test the water,,careful may be hot ,,but i doubt it...another easy way to tell is what is your hot water heater set on,,if you have a lot of soap residue is a good sign..
Sep 02, 2011 | Kenmore Dishwashers
The dishwasher stops in the middle of the wash cycle. I then have to push in on the door and it begins again. This happens very often, 10 plus times per wash,
faulty or loose door safety switch,,,check for mounting screws loose,,or wear on door catch,,if not loose or wear,,faulty switch,,replace.
Jan 29, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My Kenmore 110-46462501 washing machine stopped mid-cycle
Can you hear the pump running? It might be plugged or not running
Oct 20, 2017 | Kenmore HE2 Plus Front Load Washer
My MDB8951 dishwasher stopped working after interrupted the cycle
Go to your electrical panel and, disconnect the power to your dishwasher for about 1/2 hours when you repower it your DW should be reset
Jun 12, 2009 | Maytag 24 in. MDB9150A Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwasher "lock on ' control wont turn off
Hold the control lock in for more than four seconds. See if that works.
Jul 25, 2007 | Kenmore 15762 Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
632 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
