Question about Refrigerators
Jenn Air Refrigerator- re-programming
Replaced my circut board on my Jenn air refrigerator Model #jfc2089htb serial #10550872GE
It's the #21 circut board on the manufactures diagram. When I plugged it in it came up with -PEO and 000. I think it needs to be programmed. the pramming code is 0101 but I don't know how to program it. Please help!!!
  • Refrigerators Master
  • 19,396 Answers
To start try holding Door Alarm keypad and Freezer Temp Down - keypad, then releasing Door Alarm for 3 seconds. If that does not help , unplug power cord to reset pcb, wait ten minutes, plug back and repeat the problem.
If the keypad is completely irresponsive, and the procedure above does not work then call Jenn Air. This is a common problem on certain Jenn Air, kitchenaid and Maytag models that mount this same pcb, and usually they send a new keypad/control assembly free of charge when this happen.
Give them a call and let me know.
Testimonials.
I have a Kitchen Aid Side by Side refrigerator
MAYTAG refrigerator (MF12568AES) entering code
Posted on Jul 19, 2009
Top door not aligned with bottom
The parts diagram link that I am sending shows the hinges. You can adjust them. http://www.appliancepartspros.com/left-refrigerator-door-parts-for-jenn-air-jfc2089htb.html Loosen the screws and shut the door and then tighten them
Apr 07, 2014 | Jenn-Air JFC2089HTB French Door...
Doors don't want to seal tight
JFC2089HTB S/N 10551059GE
DOOR LIKES TO STAY AJAR. BEEPER TO NOTIFY ME DOES NOT WORK
Feb 20, 2012 | Jenn-Air JFC2089HE French Door...
How do i locate and replace a dual water valve on a jenn air jfi2589aep french frig ?
The dual water valves is located in the back of the refrigerator. You will have to remove the panel in the back of the fridge in order to access them. Use wire markers to mark the connectors to identify which commector goes where after replacing the valves.
Dec 15, 2010 | Jenn-Air JFC2089HTB French Door...
I have a Jenn-Aire side-by-side refrigerator Model #JCB2280HES, Serial #10024253EP. The warranty expired in February 2010. The food in the bottom half of both the freezer and refrigerator is frozen and...
Hi!!
Check to see if the evaporator fan behind the freezer wall (remove wall) is running. If it isnt the air will not flow properly in the unit. Replace the fan motor and it will fix it.
Good Luck!!
Jul 29, 2010 | Jenn-Air JCB2280HES Side by Side...
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Oct 01, 2009 | Jenn-Air JCD2389G Side by Side...
What exactly is "covered" by the 5 year warranty? What does that mean? The repair person charged me a couple hundred dollars to replace the small electrial thing on top of the compressor. I thought that...
The compressor,internal and external coils for refrigerant routing are the sealed system. All other parts including the electrical part you had replaced is not part of the "sealed system".
Sep 28, 2009 | Jenn-Air JFC2089HTB French Door...
IS THERE A RECALL ON JENN-AIR REFRIGERATOR, MODEL #JCD2389GE ?
MAYBE!  Our Jenn-Air side by side has a similar model number to yours and it was recalled on March 10.  Check on maytag's recall page to see if your fridge has been recalled by entering your model and serial number.
Mar 11, 2009 | Jenn-Air JCD2389G Side by Side...
Compressor is out on Jenn-Air model JFC2089HTB
CALL WHIRLPOOL (THEY JENN AIR) 18002531301 ASK FOR POLICY ADJUSTMENT SEE IF THEY WILL COVER REPAIR
Dec 14, 2008 | Jenn-Air JFC2089HTB French Door...
Refrigerators Logo
136 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
