Question about LG WM1814CW Front Load Washer
Describe your LG WM1814CW Front Load WasheI cleaned out the screens on the water feed, unplugged the machine for 10 or more mins., and it still flashes "ie" after numerous attempts with the spin cycle. The last expert I asked said "to turn off, back on, put on no spin and the machine should drain, and 1 min should show. Well there is no water in the machine to begin with, it shows 27 or 42 mins and all it needs to do is spin the water out of the clothes what do i do. (when the machine reads codes on the screen does the L on "LE" look like a capitol "L", or lower case? because it looks like an i with no line on top or bottom as a capitol "I" would haver Problem
  • 1,543 Answers
IE is inlet error. (failed to reach set water level within 8 minutes)
You have cleaned the inlet screens. Make sure there is water up to the inlets. (disconnect hose and put end into drain or a bucket and turn valve on to make sure) Re-connect hoses and turn valves back on. Make sure hoses are not kinked. If still no water fill, you should take the top off the machine (bottom screws on the plastic retainers on the back side of the top, then from in front of the machine, push back with a sharp push of the palms of your hands on the L and R side of the top, to push it back about 2 inches, then lift the top off) and then check to see if you are getting any power (120 volts AC) to the water valves when you start a cycle. (Again, you should not get code IE for aprox. 8 minutes) No power to at least one coil on water valve = bad control board. Power to at least one coil, but still no water fill = bad water valve.
(by the way, the LE code is a capital L and E)
Posted on Jul 19, 2009
How do I put hose back in behind lower cover cap? pulled completely out when attempting to drain hose & clean the pump filter.
Go to www.youtube.com and enter
LG WM1814CW
Into search bar on youtube.
You will see various videos on How To Fix your exact model washing machine. :) x
Nov 17, 2014 | LG WM1814CW Front Load Washer
We have an LG WM1814CW washer. For some reason after approx. 10 or 15 min. it will just shut off. Water and soap is still in the drum. The door will unlock and there is no error code. It just quits. We...
Hi tdld6365,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | LG WM1814CW Front Load Washer
Cycle takes forever
IE is Inlet Error. Turn off the water valves behind the washer and remove the hoses from the machine end. Look inside the spot the hoses were attached to, and use a plier to pull out the screen and clean it out. (probably only need to do the cold side) Re-instert screen(s), re-attach hoses, and turn valves back on. (Also, make sure hoses are not kinked behind machine.) Times displayed are estimates, and vary due to water fill rates, and load type and size. In your case, the water fill rate is the problem.
Jan 25, 2010 | LG WM1814CW Front Load Washer
I cleaned out the screens on the water feed, unplugged the machine for 10 or more mins., and it still flashes "ie" after numerous attempts with the spin cycle. The last expert I asked said "to turn off,...
I purchased an LG front loader washer last year in October, Luckily I purchased the extended warrenty. I had to have a repair man come out as I was stumped too. I had washed some rugs in there and it plugged up the pump. The repair man told my husband that the inlet is very small and there are lots of things that could plug the pumps up. If you are handy could tackle this but I think it is best to call someone. My husband is handy at fixing just about anything and he told me to take my rugs to the laudry mat. :(
Jul 19, 2009 | LG WM1814CW Front Load Washer
Error Message/OE
sounds like too much water is coming into machine.check water valve,and water sensor.it is bringing in too much water or not enough.
Mar 06, 2009 | LG WM1814CW Front Load Washer
I have an error message on my LG WM1814CW washer The message
This means the machine did not drain within a 10 minute time period. check the pump trap for debris and clean out. Check the drian hose. Check for drain pump operation diring drain period
I have an LG WM1814CW not getting .
Did you check the simple things first?
Often, one of (up to) three screens are in line with both water feeds; one at each end of the connecting hose, still another at the input to the control valve.
Feb 07, 2009 | LG WM1814CW Front Load Washer
LG WM1814CW
I thank you for your support on fixing my OE error. I cleaned out my filter on the bottom left hand corner of my machine. Problem fixed. Be aware that when you unscrew your filter, you may have a lot of water draining.
Sep 21, 2008 | LG WM1814CW Front Load Washer
Cold water will not shut off even when washer is off.We left unit unpluged over nite and still have same problem LG washer # wm1814cw overfills
You have a stuck cold water solenoid valve.
Try openning the machine and tap on the cold solenoid valve.
If this dowes not work, you may have to replace the valve.
Mar 25, 2008 | LG WM1814CW Front Load Washer
LG WM1814CW Front Load Washer Logo
247 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
