Question about HP Compaq Presario F730US Notebook
My Compaq Presario F700 Turns on and off at boot up and when it finally begins to load it takes about 45mins to pass the start up screen any suggestions?
  • 81 Answers
1, what is the size of your ram ? try make it 1gb i promise u it will run faster.
2. try run a disk clean up to remove some unwanted programms and delete some irrelivant documents.
if all of these does not work the u will need to format your system it means ur system is infected. but am absolute that your system needs upgrading, the ram is too low al least 1gb. thanks. dont forget to vote me when it works
Posted on Jul 19, 2009
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
How to restore a hp compaq laptop
Here try this one. its works with some HP Compaq.
  • During boot. On the HP logo screen Press "F11"
  • Just let the windows load and you will be directed to HP Recovery Manager
  • But before starting this program, Im reminding you that this will erase all the datas in your computer, so if you have important files saved in your computer i suggest you save them first in a flash drive.
  • Now click Next. this will lead to the microsoft system restore page. Choose yes to restore your computer to factory settings. It usually takes 45mins to 1hour defending on your computer speed.
  • Thats it.
Hope my solution will help you. Please give me feedbacks regarding this problem. thanks.
Jul 01, 2011 | HP Compaq Presario C500t Notebook
F700 it turns on and off in continuos loop nothing except a black screen. any ideas?
look into bios check if the hd or cd is booting........not a network boot.......o network no boot
Dec 02, 2009 | Compaq Presario Notebook
My compaq presario v2000 turns on and loads up but it doesnt go to the login screen. it loads it but doent show up so it restarts
when it starts to boot Force it into bios mode and check the win operating system . sounds like you picked up a boot virus and windows is not in control of the system.
Jul 09, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario F700 wont boot. Powers up then turns off again a
that means you might have a hardware failure. possible powersupply. check with local shop.
Jun 17, 2009 | HP Compaq Presario F730US Notebook
My compaq presario F700 won't boot up.It keeps
seems that same System Files have been damaged. Try starting in Safe Mode or use the Recovery Console from the windows disk to repair the OS.
Jun 05, 2009 | HP Compaq Presario F730US Notebook
Compaq Presario F700 keeps turning on and off
At this point I assume you've tried to go into SAFE mode, and into BIOS with no luck. You're right about the overheating but I think the damage is done. If the unit will no longer stay on in any mode or condition then heat has ruined something. First easiest part to check is memory. The check the CPU (most laptops still have a plug in CPU). If neither of these are suspect then take everything off the motherboard, including the screen (I use and external monitor). If the problem still exists then it's time to use a scope.
May 30, 2009 | HP Compaq Presario F730US Notebook
HP Compaq Presario F730US Notebook Logo
657 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
