Question about Sony VPL-ES1 Multimedia Projector
Beamer cannot be switched on
After a Power outtage, i cannot switch on the beamer, also standby led is not on neather red nor green. I had this problem also bevore month, then after about 2 hours standby led switched on and beamer was working, but this time i wait till 2 days and nothing happened. Has anybody a solution for this problem?
    Problem Solver:
  • 5 Answers
Yes its a semiconductor problem and well known vor various vpl models. it can take up to five days until it suddenly turns on again. very annoying. the semiconductor costs $30 (22€) but i have no clue where and how to replace it. didnt open it yet.
Posted on Aug 04, 2009
Habe einen samsung dlp beamer SP-H710ae. Beim Einschalten leuchtet die "stand by" Anzeige, die Anzeige "lamp" blinkt, nach kurzer Zeit leuchtet die "temp" Anzeige. Kein Bild. Ein Austausch der Beamer-Lampe...
ist der beamer nog innerhalb garantie, dan bitte zuruck zur lieferanten, am sonsten kan mann versuchen die kappen weg zu holen und die ganze sache von innen aus mal richtig zu sauberen, staub kann die sensoren storen, weicher pinsel und staubsauger konnen helfen.
viel gluck
Aug 17, 2013 | Samsung Office Equipment & Supplies
Hello if a connect a pc to the beamer, i only get a black screen. but in the right corner it does says that it is connected :S
plug the projector end of the cable into a monitor and check that the video is OK.
then reconnect to beamer
make sure the rgb socket on beamer is configured for pc and not component video input
Jun 19, 2011 | BenQ PB8250 Multimedia Projector
Motherboard red light stay on and computer won't turn on. Any ideas on what the promblem might be?
First try shutting down you're system. Than turn the PS off at the rocker switch (Back of PS). Ground you're self by touching the the PS. Remove you're memory and re-seat it. Than boot the system.
Check the standby LED. See if it lights green.
Pull the cmos battery and check its voltage. Anything under 2.4 volts replace the battery. Normally the MB LED displays green. (Standby power).
This means the MB is maintaining / charging the cmos battery. If the battery can no longer maintain charge this will cause the MB LED to turn Red. Built into the mother board is a small switch. When the system is shut down the MB maintains power to the cmos. If the standby switch fails to function correctly the LED will turn Red. Lets hope the problem is the cmos battery. The internal switch can not be repaired.
Cheers'
Mike
Feb 02, 2010 | AOpen S651M (918EM10S50) Motherboard
Sanyo plv z2000 warning led it shutdown
Check all the fans if its working or avoid anything that cover the exhaust fan, or the temperature of your room.
Oct 23, 2009 | Sanyo PLV-Z2000 Projector
Nothing comes on except the green standby light on PT-AE900E.
I have the same problem. It seems we have to reset the counter. This reset must be done via the beamer itself and not via remote control, since lamp is not working...
Jul 24, 2009 | Panasonic PT-AE900U Multimedia Projector
Connection to beamer blocks DVD players
Try to get an scan with an good antivirus or malware. If this fail... Only reinstalling OS, my friend... Succes!
Jul 12, 2009 | Lenovo ThinkPad T500
Sharp projector xr10xl standby light flashing and lamp light on what is wrong?
if it's blinking green, nothing is wrong. it's just cooling. if it's blinking red and the lamp is off, the lamp door is open.
Jan 13, 2009 | Sharp XR10XL DLP Projector
Beamer shut down
Hi fene4
You will have to replace the lamp and reset the lamp timer.
May 04, 2008 | Compaq iPAQ MP1200 Multimedia Projector
Beamer BM-TV Vialta
Daniella,
Do you have a CE version of the BM-TV, in UK the TV system is PAL if you bought your Beamer in U.S. chances are you have a NTSC version. As far as "broadband", are you refering to a DSL service or VOIP? Please email support@vialta.com for further assistance.
Support
Aug 21, 2007 | Vialta 370102-00001 (37010200001)
Sony VPL-ES1 Multimedia Projector Logo
519 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
