Webserver inaccessible from lan
I have set up a webserver I can access it from an external ip/proxy but not from internal machine using domain name. I think that it has something to do with the router, not being able to redirect the domain name request to the server as when I type the domain name address into a browser it just shows the router config page.
the router is a belkin f5d7633-4
  • 7 more comments
  • youan Jul 28, 2009
    yes the router does forward the port, and the server is accessible from outside of the network
  • youan Aug 11, 2009
    Does anyone have any idea why this is not working?
  • youan Aug 12, 2009
    So does that mean that I have to add the IP to the host file?
    Why is this the default behaviour, of ADSL routers?
    Is there anyway to change this behaviour?
    Will installing OpenWRT allow me to fix the problem?
    Is there any way to make it work without hard coding the IP or getting new hardware/software, or is there a router or other piece of hardware that will make it work?
    I can always ssh into the router from the command line. I would still do it anyway even if there was no way to access the router, the router is setup and is working fine I see no reason to need to change the configuration of the router. If there ever was a need I could always find a way to change it.
    any recommendations to which router doesn't have this "feature" as default or whether trying openWRT on the belkin could provide a fix?
  •  Sudarsan Parthasarathy
    have you setup the router to forward port 80 to the web server?
  • 135 Answers
This is default behaviour of port forwarding on ADSL routers.
You need to create a local DNS entry in your machine, which will resolve the domain to the LAN IP of the web server.
Posted on Aug 12, 2009
  • 1 more comment
    Lets take for instance, this behaviour is overcome with some solution. In this case, how will you administer your router? Any request to the router IP on port 80, would be forwarded to the web server. Hence, you will loose the administration capabilities on your router.
    Read this http://forum.notebookreview.com/showthre.... Belkin routers have this issue by default. Try sourcing another router make & see if your problem is solved.
    Will check out & let you know.
What is DNS configuraion ?
DNS configuration is what you do to setup the name server for either a website or for your computer. Domain name servers find the IP (Internet Protocol). Everything that connects to the internt has an IP address. IP addresses are for location the machine. They are of the form xyz.xyz.xyz.xyz where xyz is a number between 0 and 255. A domain name would be something like fixya.com, which is easier for people to remember than the numbers. A Domain Name server translates the name to the numbers. Your ISP has one to do the the translation for you. For a web server (computer that hosts a website like fixya.com, the webhost has a Domain Name Server that allows the computer that runs the webserver to be found. Configuration in that case would be to allow the website to find other sites, and to be found by other sites. For your computer, it would be like this, if you are running windows xp: Change DNS Settings in Windows XP
For a server, here is a more complete description: An Introduction to DNS Terminology Components and Concepts DigitalOcean
May 26, 2017 | Computers & Internet
Having problem internal network to connect outside but the router itself can ping the outside domain or public domain/IP. The Internal Network cannot ping the domain or cannot connect to the internet what...
1.Check whether there is ping to router from lan computers.
2. If there is no ping then check the cable b/w lan computers 7 router.
3.Else if there is ping to router, then check ur router for any ip blocks, access lists etc..
4. Turn - off the local firewall, so there also a chance of it blocking access to internet
Sep 27, 2010 | Cisco 881 Fast Ethernet Security Router
Need to get around proxy blockers to check email
Proxy's are generally blocked by URL so try using Command prompt and pinging the Domain and connecting using IP rather than fully qualified domain name, Some proxy's are blocked by IP which you yourself cannot alter unless you own the proxy and own the hosting its on, In which you can assign an new IP to the website using Apache or depending how proxy script connects editing proxy script.
Jun 22, 2010 | Dell OptiPlex 360 Desktop Computer
I purchased a Motorola KRZR2 from Ebay, and although it works great, it cannot connect to the AT&T web. AT&T told me that since I didn't buy it from them, they will not help me out. What are my...
Your WAP and MMS need to be set up.
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
4. Click Web Sessions
5. Click [New Entry]
Fill in the following fields: (some of the fields may already be setup)
Homepage: http://home
Service Type 1: WAP
Gateway IP 1: 10.250.250.250
Port 1: 9201
Domain 1: <leave this blank>
Service Type 2: WAP
Gateway IP 2: 000.000.000.000
Port 2: 8080
Domain 2: <leave this blank>
DNS 1: 000.000.000.000
DNS 2: 000.000.000.000
Timeout: 5 minutes
CSD No. 1: <leave this blank>
User Name 1: <leave this blank>
Password 1: <leave this blank>
Speed (Bps) 1: 9600
Line Type 1: ISDN
CSD No. 2: <leave this blank>
User Name 2: <leave this blank>
Password 2: <leave this blank>
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name: <leave this blank>
Password: <leave this blank>
Click Done
Click Menu
Select "Set Default"
Then...
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
Homepage: http://mmsc.mobile.attwireless.net
Gateway IP: 10.250.250.55
Port 1: 8080
Domain 1: blank
Service Type 1: HTTP
Port 2: 0
Domain 2: blank
Service Type 2 WAP
Time out: 5 Minutes
CSD no 1: Blank
Username: 1: blank
Password 1: blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: blank
User Name 2: blank
Password 2 blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name:blank
Password:blank
Press the left soft key 4 times to return to the main menu.
Scroll to and select Messages.
Press Menu.
Scroll to and select Inbox Setup.
Scroll to and select MMS Message Setup.
Scroll to and select Server Info.
Scroll to "AT&T MMS", then press Menu.
Scroll to and select Edit.
Validate the following settings:
Service Name: AT&T MMS
Server Name: http://mmsc.mobile.attwireless.net
Web Session Name: AT&T MMS
Jan 14, 2010 | Motorola Mobility KRZR K1 Cellular Phone
Can't configure router for Domain name and DNS
dns= domain naming service or something alike...
you don't have normally to anything to your router other than allowing incoming traffic to port 80...once you do that, you should be all set..frrom your computer at home if you type your domain name, your pc actually goes to the internet clowd and accesses you new domain name based on the info gathered by dyndns...then comes back to the ip that your ISP assigned you and hits your webserver...
A couple things to consider;
keep an eye on the ip assigned to you by the ISP..if it changes by DHCP your webserver won't be seen by the outside..
on your side of the home network, assign a static ip address, don't use dhcp as well to avoid the same problem on the pc that you have the webserver. your router should allow you to allow traffic on port 80 to your webserver computer, which has the static IP...
if it does not, buy another one
Feb 07, 2009 | Buffalo Technology AirStation WBR2-G54S...
How to activate vodafone live india in HTC touch P3452?
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
Jul 29, 2008 | HTC Touch P3452 Smartphone
Can't access my computer onthe internet
  1. Make sure that your ISP is not blocking port 80. You can check that here. (Otherwise switch to another port like 8080 or 805)
  2. Have you setup your DDNS service on your router or ensured by other means that no-ip has your up-to-date external IP? (Make sure that your external IP matches the entry at no-ip.com!)
  3. Set your LAN server to a static IP address
  4. Make sure that port forwarding is enabled and pointing to your server.
    - That means: if you run a webserver on port 80, you have to set the external port to 80 and leave the internal blank, unless your internal server listens on a different port.
If this does not help, what exactly do your mean by "Fail to connect"? Is it a 404 error? Please provide details.
I think this might be interesting for some other people too. So please come back and leave a comment!
Feb 14, 2008 | Belkin (F5D6230-3) Wireless Router
Gprs settings
For BSNL South prepaid or post paid use following settings:
Start/ Settings/ Connections /GPRS
Connects to : Internet
Access point: gprssouth.cellone.in
Leave other items blank.
Start/ Settings/ Connections /Proxy
Donot creat any proxy
You donot require any thing else. GPRS will work on your mobile and also in Internet share. Internet share works with cable and bluetooth. Browse on mobile or laptop !!!
9448834529
Dec 10, 2007 | HTC Touch P3450 Smartphone
Computers & Internet Logo
272 people viewed this question
David Payne
David Payne
