Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Kenmore side-by-side fridge icemaker
Water line is not frozen, and optics are good, however the icemaker will not work. Took the cover off the module, and one of the two little plastic gear clips in the middle had broken off. Could this cause the icemaker to not function? Thanks.
  • tervlady Nov 19, 2007
    One more thing -- the repair website that we found for this refrigerator offered helpful photos. One of the suggestions was to jumper the connection in the module, and showed a small U-shaped jumper. Is this supposed to come with the refrigerator? Ours does not have it ... where does one obtain this jumper? Thanks.
  • WarrenG Nov 20, 2007
    My Kenmore Elite seemed to be making ice erratically, would also get jammed and then stopped making ice all together. I took it out, defrosted it and took it apart. I found that the "coil" or loop under where the ice cubes are formed was heavily corroded. Would this prevent the ice maker from working properly? Also, we have been getting icycles hanging/dripping from the ice maker for awhile.
  • 213 Answers
Yes. replace the icemaker modual and your problem is solved
Posted on Nov 19, 2007
How to defrost the water line coming into the icemaker? The water line that goes from the fridge to the freezer is frozen and the icemaker does not have water to make ice and the water dispencer does not...
Good day,
The machine has problems and they hve to be addressed.
The machine needs to be shut off, and the food moved.
I do not recommend using a hair dryer since it can melt things you never want to melt.(Those components are plastic and vinyl).
The DUAL WATER VALVE in the bottom back of the machine, needs replaced at the same time, since it's the cause of your problems.
As well, the line to the water outlet could be frozen, which means defrosting the freezer door completely.
Looking at a 12 hour minimum off time, with the machine unplugged.
Using a floor fan blowing into the freezer compartment will reduce that time to approx. 8 hours.
Dec 29, 2009 | Kenmore 57029 Side by Side Refrigerator
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
Water and ice won't work on kenmore side by side fridge
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Mar 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Jan 25, 2009 | Whirlpool ED5SHAXM Side by Side...
Icemaker doesn't work and it was working fine. What do I need to check.
Look at the "fill" tube that fills icemaker with water. If it is frozen, replace water valve located behind fridge in compressor department, hint: it is blue... If not frozen up, it may be the icemaker... It's either the icemaker or the water valve UNLESS your ice bucket is located in the door, then it could be the "optical" computer board eye that "see's" accross the ice bucket....
Nov 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Kenmore fridge icemaker doesn't work after move
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Oct 11, 2008 | GE Profile PSI23NCR Side by Side...
Fridge Leaking
the icemaker can overfill causing water to run over into the freezer
the fill cup on the back of the icemaker could be frozen letting the water overflow into the freezer
if the fill cup is not frozen then you need a modlue for the ice maker if it is whirlpool built, if ge or frigidaire design then replace the icemaker
May 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker stopped working
pull the front cover off of the icemaker and see if the drive gear is broken (there are 2 tabs in the center of the gear make sure these arent twisted or broken as well) if so replace the module on the fron of the icemaker. if that checks fine check for frozen fill line..
Dec 16, 2007 | Refrigerators
Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Nov 07, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore fridge optical icemaker hosed
ice maker module assembly is probably broken
Sep 27, 2007 | Refrigerators
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
104 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
