Question about Epson Stylus C46 InkJet Printer
Epson C46 green and red lights flashing, saying parts need servic
I have a epson c46 printer which is saying.service-parts inside end of life. I read your previous answer about emptying the ink traps, please can you explain how to do this. many thanks
  • 700 Answers
Care to read this link
http://tricks-collections.com/2008/06/reset-epson-stylus-color-printers/
Goodluck
By the way emptying the waste bin needs disassembling of the unit then washing the ink foam.
Posted on Jul 19, 2009
  • fougzki Jul 21, 2009
    Ok maybe i have to elaborate it further. The link I gave you, is info
    for resetting the printer counter. Manually or by software, the warning
    thing is maybe epson way of ensuring its products error free
    performance.
    And since this warning pre equate with the ink tank if ever it will
    overflow. If you want it to be sure. There's two screws on either side
    or bottom of it, also prying two notch clip in front to oven the top
    cover. You should do this if no power and data cable is attached to it.
    Underneath is ink park, there's a tube going to the bottom with three
    layered foam. You can take it out, rinse it with water, dry it then put
    it back again, top cover then screw. Test it again
    You should reset the printer's counter also.
I can't get compatible ink to work in my epson stylus c46 inkjet printer
Parts inside your printer are at the end of their service life. See your printer documentation sloution
Nov 08, 2009 | Epson Stylus C46 InkJet Printer
This message refers to the waste ink pad in the printer, when this is 'full' this message appears, You can reset this yourself by downloading the right software which you can download from here:
http://www.ssclg.com/epsone.shtml
I have also checked the C46 is supported
Sep 03, 2009 | Epson Stylus C46 InkJet Printer
Green light flashing and red light flashing alternatively. Ink cartridges appear to be full. No print
Cek status monitor ? Service required / end life? Use SSC utility to reset wate ink counter.Menu protention counter. Show cuurent value for checking. If value exceeded maximum, reset protection counter. Or Clear counter overflow.
Jun 30, 2009 | Epson Stylus C46 InkJet Printer
Epson C46 colour printer green and red lights are flashing....but
Basically your printer says that you need to replace the waste ink pads. If this happens for the first time to this printer you can just reset the counter using SSC Service Utility (http://www.ssclg.com/epson.shtml) or if it happened more than once you shoul first replace the ink pads and then reset the counter or the printer may overflow. That's it.
Jun 15, 2009 | Epson Stylus C46 InkJet Printer
EPSON PRINTER NEED SERVICE
your printer wast pad is full so the printer need to be reset if you dont have the tool let me no
Nov 02, 2008 | Epson Stylus C46 InkJet Printer
Epson C62
when u go to --> control panel --> print preferences and maintenance
does it say low ink ? or cartridge unfilled?
Feb 27, 2008 | Epson Stylus C46 InkJet Printer
Epson C45(Red and Green light flashing alternately)
The waste ink collector pads are getting full and this is a protection indicator.
Either get the machine serviced or it may be cheaper to replace it-[depending where you live]
There are tricks to keep the machine going- but eventually the you will get ink leaking all over the place.
Take a look at www.fixyourownprinter.com
Dec 21, 2007 | Epson Stylus C46 InkJet Printer
Problem with my printer
well first here http://emeasupport.epson-europe.com/downloads.aspx?LNG=EN-EU&Search=1&data=1bANIZf8BRVoS83cS1PVis/kIVxbLcWZ9JD5vhjblgJTVeIjQGvfyu2+tOhzwN03 for more info & your drivers but what you need is new ink cartages
May 25, 2006 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
392 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
