Question about Maytag Admiral AAV7000A
My maytag washer is throwing off a musty stentch. What should I do about this? It is stinking up my laundry room and the entrance to my condo.
  • Maytag Master
  • 3,740 Answers
There is a soap buildup underneath your agitator. Look for a screw on the outside of your agitator just above the lower large part with the agitatotr blades. Memory is fading but it is either a 5/16 or 1/4 ince socket that will be required to remove the screw. Once the screw is removed simply lift the agitator out then begin cleaning the tub with PLASTIC bladed putty knife. As for the agitator use something like Mr Muscle or Eliminate to clean the botttom and inside of the agitator itself. (any product that will remove soap or calcium buildup) \You can also use those same products to clean what is still on the top face of the inside bottom of your wash tub. Once you finish cleaning simply align the splines on the agitator and re-install the screw. You will NOT damage your machine running it empty. Make sure you run at least a full rinse cycle before washing clothes again as there will be some residue that will need to be washed out of your machine. Once you install the agitator push the tub stiffly in 90 deg quadrants and look at the top of your wash tub cover. Soap build up in that area can also result in an odor. The is something you can do yourself. Good Luck.
Posted on Jan 05, 2010
  • 867 Answers
Try doing a full load of whites with lots of bleach (dont burn your clothes though!), extra soap, hot wash and hot rinse, heavy duty clean cycle. this will give your machine a good internal cleaning. machine should never be run empty.thats why we have clothes in the washer even though we just want to clean the machine
Posted on Jul 19, 2009
Water in the washer.
First I would have posted this in the washer section not the vacuum section. That being said:
This is normal for a maytag Neptune. There is a liquid filled balance ring on the Neptune washer drum. That is the sloshing you are hearing. The smell is from the water trapped between the door seal and drum. You can wipe down this seal with an old cotton towel or sock and then throw it in with your next load. Also, just leave your door open a crack after your loads are done and the water will evaporate and not sit and get moldy.
Jan 26, 2014 | Washing Machines
Washer stinks terribly and has become so loud you can hardly be in the room when it is on.
Check out this tip I wrote about the noise and vibration thatfront load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 18, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
Error code f 70 and 71
F 70 overloaded
F 71 suds detect
To review: You got too many clothes up in here and you is using too much soap. These machines measure the weight. Take some things out or if you only have a small load add some things. It also measures the water quality in a load to determine IF a load is clean enough. Too much detergent throws the machine off. Then it trys to correct the problem many times and that heats up the motor and wrecks the sensors.
Basic rule of thumb:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) Errors/Interrupted Cycles
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged sensors
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Apr 11, 2010 | Maytag Bravos 4.5 Cu. Ft. Washer
Maytag front load washer - smell musty
the water in the unit is normal, to kill the smell when you are done doing wash for the day dampen a rag with bleach and whip down the door gasket. You can buy a cleaner called "afresh" it works as well. If your unit is a neptune check with maytag it might have a recall on the door gasket for growing mould
Nov 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Takes the dryer over two hours to dry one load of laundry. It appears to be putting out hot air. When I stop it to check the clothes, the clothes are usually really warm yet still wet. This has been going...
You have a venting problem. Some makes of condo size dryers have a lint screen inside the drum at the back. Check and clean. If not then there might be a screen in the wall or the ceiling of the room the dryer is in. Trace the vent from the dryer to the wall or ceiling. There should be a vent fan in the ceiling. Try asking the condo property management if there is an exhaust fan in the wall that needs cleaning.
Jun 21, 2009 | Dryers
MY FRONT LOAD WASHER STINKS! THERE IS A MUSTY ODOR COMING FROM INSIDE.
Switch from liquid to powder detergent, no fabric softner (I know...I love it too), clean the gasket and run a cycle with bleach only. Leave the door open whenever possible. This fixed my smelly washer, now if it would only spin!
Jun 02, 2009 | Frigidaire ATF6000ES Front Load Washer
what kind of washer?
all front load washers get this issue
the way to get rid of the smell is by doing an acid wash to your machine
set the washer to the highest temp setting (sanitize would be best)
mix in 1/2 to 2/3 cup of javex or white vinigar, either one will do it
run your washer through the longest cycle possible with no clothes in it
may need to be done more than once. and up to once a month
the smell is caused by leftover detergent and leftover fabric softner gathering on the interior shell and in the rubber boot at the door.
front load washers do not require much detergent at all, and even less fabric softner.
be careful on how much of these you are using, more is not better
this will help prevent the odor from comming back
as well when laundry is not being done, the front door should be left open a bit to allow air movement in the washer.
hope this helps
May 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Musty smell
Run your machine through its cycle with NO clothes and when it is filling up with water put bleach in the water. Put bleach in only at the start of cycle.
Before you do this clean all inside parts the best you can yes with bleach and you can run something like fleecy to make clothes soft and smell nice when you wash your clothes as well. Our machine has a special holder to put softener in.
Do NOT have clothes in when running the heavy bleach through it. This should kill the bacteria .
Aug 12, 2017 | Maytag ATW4475TQ Washer
Laundry stinks
I find that the dryer does not dry the clothes enough. The washer can take a lot of laundry at one time but the dryer is not able to handle the load. The stink usually comes from a bit of moisture left in the the clothes, especially the towels. Break down your dryer loads or dry them on a timed cycle for a longer time.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Epic Z
heres a product that might be helpful http://www.apwagner.com/index.php?main_page=product_info&products_id=148095 really had good results with this since inroducd a year ago, $ 30 bucks its worth a shot!!!!
Oct 17, 2008 | Washing Machines
Maytag Admiral AAV7000A Logo
210 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
